Question about KitchenAid 24 in. KUDP02SR Built-in Dishwasher
Turn on dishwasher hear noise solenoid clicks water valve works but no force of water to turn tines and no clean.
    Problem Solver:
  • 6 Answers
Sounds like you may have a bad solenoid valve. you can check this by opening line that feeds the valve to see if you have sufficient water flow. GET SOME TOWELS READY THIS MAY GET A LITTLE MESSY!
  1. turn off the water valve that feeds the dishwasher.
  2. remove the line to the dishwasher solenoid valve.
  3. slowly turn water back on that feeds the dishwasher.
  4. verify sufficient water pressure flows onto the towels.
Posted on Dec 30, 2010
When first lets water in makes a very loud clicking noise. It still seems to be working fine otherwise. Later in the cycle the noise kicks in again. It's a slimline DE2541.
Two possibilities come to mind. One is that the noise is caused by a loose part in the solenoid valve. Another is that a foreign object in the water inlet is slamming into something when the water hits it. The dishwasher fills at least twice (for wash and rinse); that's why you hear it a second time.
Mar 11, 2011 | Dishwashers
Does not fill up with water
Hi, Make sure you have power to the water solenoid valve. You should hear it click/energize when you turn the dial or push the fill button to start the fill cycle. Check this. If there is power, and it does energize, kill power, shut the water off, and take the water line loose and off at the solenoid. There is a screen there to catch water sediment, check to see if it is plugged or clean. Get back to me after you have done these things and let me know where you stand.If I solved your problem, please be kind when rating me as being helpful as I know you will. Keep me posted if you need more help. If you hear no click when you touch it to feel if it is energized and you feel nothing, you need to check across the 2 terminals with the wires on, and pulled back for 120 volts. If you have power, you will need to replace the solenoid valve. You will need to get one at a appliance parts house.
Sincerely,
Shastalaker7
Jul 13, 2010 | Haier HDP18PA Stainless Steel...
No water is coming thru the water valve to fill the dishwasher. The water is turned on. I had a Kenmore portable dishwasher and we just converted it to a built-in. The electricity is on and the water line...
Most probable cause a faulty intake solenoid.
OK start simple and go from there.
If your have power and light etc come on then we know you are good for power. I'll assume that is OK.
If you are not getting any lights on the machine you have a power issue or a stuck float valve. That requires another explanation.
Check the shutoff for the water supply to the unit.
I will also assume there is no water collecting inside the unit.
Water enters this machine under city water pressure. It is not pumped in. A solenoid switch opens the system and allows the water in. The solenoid is controlled by the timer. So those at the two things you need to check.
When the machine starts you should hear a click as the solenoid opens. The solenoid in located under the machine. Turn the machine on and listen for the click. If you do not hear a click we have a problem.
Remove the machine. It is usually screwed to the underside of the counter. You may have to lower it by turning the feet with a wrench. Usually you can lift it enough to get it to slide out.
With the machine on in the start of the cycle your timer should be telling the solenoid to open. To test put a test light or voltage meter across the terminals of the solenoid. The solenoid is located where the water supply line connects under the unit. If you have power the timer is working. You would replace the solenoid. If you do not have power the timer is faulty.
Chances are it is the solenoid. Just unscrew, disconnect the water lines and find a replacement part. Installation is the reverse of removal.
Hope this helps. Please rate this answer if it helps you.
Mar 13, 2010 | Dishwashers
No water in dishwasher. When turned on all we hear is a clicking noise.
The problem you have here is the solenoid valve is either not opening or there is no water to the dishwsher. For more help check out this tip.
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
Heatman101
Feb 03, 2010 | Whirlpool 24 in. DU1055XTP Built-in...
Not cleaning
If the water doesn't drain from your dishwasher, check these:
  1. Drain line/air gap A clog in this part is the usual reason that a dishwasher doesn't drain. Remove the drain line to clear any debris from the hose or hose connection at the household drain line connection. Reattach the hose before starting the dishwasher again.
  2. Pump You can reach the pump from inside the dishwasher. Remove the lower rack, spray arm and support. Look for an impeller, a device that spins around and forces water through the spray arm. This is the wash impeller and beneath it is the drain impeller that pushes the water into the drain port. Replace it if found defective or worn out.
  3. Drain valve/solenoid The drain valve may have a solenoid with lever that sticks or frozen and prevents the dishwasher from draining. Free up the solenoid and lubricate the lever.
  4. Belt A certain brand of dishwasher uses a belt to drive the pump. Replace it if broken or worn out.
  5. Motor Check it if turning or working.Turn the rotor manually to see if stuck and free it up. Replace if defective, it is not serviceable.
Nov 06, 2009 | Bosch Classixx WVF 2402 Front Load...
No water getting into the dishwasher
At the bottom of the dishwasher remove the kick panel . Then turn on the dishwasher , and then locate the water inlet valve , it should be on the left hand side with hose going to it . the pipe might be copper or plastic or stainless steel . listen for a humming noise . If you hear a humming noise . there is no water getting to the unit . make sure the hose is not kinked and the water is turned on and clean the screen on the valve . if there is no humming it is bad water valve . ( cleaning the water valve ) remove the incoming water line and remove the screw that holds the valve in . Then remove the 90 degree fitting on the bottom . you will see the screen .
Oct 31, 2009 | Dishwashers
Wont drain hear clicking noise
Hi
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 03, 2009 | Electrolux Kenmore 24 in. Built-In...
KitchenAid KUDP01DLWH6 dishwasher filter clog
Follow the main water supply line. It goes to a solenoid valve which is normally located front left side under the dishwasher.
1. Turn off the main circuit breaker for the dishwasher.
2. Turn off Water supply to the dishwasher.
3. Remove lower front panel.
4. Remove Water supply line from solenoid.
5. remover wire connections from solenoid.
6. Remove 2 mounting screws from solenoid.
7. Take solenoid valve out.
8. Look inside the valve where the water supply line was connect to, You will be able to see the filter. it is just a screen and you can easily clean it.
Good Luck
Jun 27, 2009 | KitchenAid 24 in. KUDP01DL Built-in...
Dishwasher not starting when door closes
What your saying is suggesting a water supply issue. The Model number you've given can not be found on the Neff website.
You will need to disconnect power, turn the water supply off (under sink or behind dishwasher), disconnect the water line, put the end of the hose in a bucket or cup, turn water back on slowly and make sure water flows. Turn back off. If water flows -
Then check that there is not a restriction in the water solenoid valve. If you know how to use a multimeter, check the water valve solenoid for continuity.
Plug the unit back in, and initiate a wash cycle, and watch for voltage applied to the water solenoid valve. If you get voltage, you should hear the valve open.
Power the unit off, connect the water line, and repower the unit. Check again if water does or doesnt flow.
Let me know what you find.
Jan 25, 2009 | Neff 24 in. S5456 Built-in Dishwasher
NO WATER COMING THROUGH ON DISHWASHER JUST LOUD BUZZING NOISE
The buzz that you hear is the water line solenoid. It probably is not opening up to let the water through. You should replace this solenoid and it will fix your problem as long as you have water coming up to the diswasher's solenoid valve.
Dec 03, 2008 | Smeg 18 in. DWF409WH Slim-Line...
KitchenAid 24 in. KUDP02SR Built-in Dishwasher Logo
149 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
