Question about Refrigerators
FRIGIDAIRE FFU21C4CWO FREEZER Frigidaire manual defrost freezer 7 years old. All of the sudden I had ice forming inside top of door in freezer. Had it looked at by tech and he said seal looked fine and couldn't figure out why it was doing this, he did some adjusting of the seal which didn't work. He checked plug drain seal in bottom and that was fine. Now outside door is sweating and very cold to touch. Do I need to replace freezer?
    Problem Solver:
  • 17 Answers
No need to replace freezer only replace bi o metal thermostat
Posted on Dec 31, 2010
Freezer defrost working but leeks
Hey friend, I appreciate the post!
I understand that your refrigerator is defrosting but you are getting a patch of ice to form due to water leaking inside the freezer. It may be a moisture build up in your freezer. Which may be caused by the door being slightly opened, when that happens warm air can enter the refrigerator and cause a moisture build up. You could also check to see if your door seal is bad, the way to test that is to place a dollar bill between the body of the refrigerator and close to the door. Pull the dollar bill out, if it sticks it is good, but if bill comes out easily the gasket need to be checked. Hope this is helpful- Matt
Jul 19, 2014 | Frigidaire Refrigerators
What could be causing my 7 year old upright Frigidaire Model FFU21K2CW0 Freezer to NOT freeze? The inside (of the compartment) coils feel cold, the seal is good, but the ice cream is VERY soft. The...
Your freezer is probably running constantly as well. Lift the bottom vent panel (the one with all the holes in it) and look at the bottom of the back panel. There should be a half inch gap for the cold air return. If you see a solid wall of ice in that gap your coils have frozen over. You need to clean out the freezer and defrost it. Look in the back near the compressor. If your model does not have a drain plug in the bottom then you need to leave the door open and mop up the water as it melts off the coils from the inside. If you can, wheel it outside on a dolly and let it defrost where it can drain on its own. After you are sure it is totally defrosted, plug it back in at a control setting of 5 for at least 4 hours, preferrably overnight, and check the temp. Setting the freezer at 7 will encourage ice buildup. Your problem may be a bad defrost timer, which your local appliance parts store may have.
Aug 03, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire ref not cold
Refrigerator or freezer is not cold enough check this part:
* Check the temperature setting
* Assure that there is enough room for air flow in the refrigerator or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condensor coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Mar 29, 2010 | Frigidaire PLRU1777DS Stainless Steel...
I have a frigidaire freezer upright model#ffu20f9gw3
Without any additional info, there are a lot of possibilities:
1. Condenser coil (underneath unit) is dirty and clogged.
2. Compressor is failing. (need A/C tech)
3. Metering device is clogged. (need A/C tech)
4. Refrigerant charge is low. (need A/C tech)
5. Door seal is broken (frost will form around door).
6. Defrost heaters are stuck on (replace defrost timer located underneath unit at front).
7. Condenser fan has failed (underneath freezer on back).
8. Evaporator fan (inside fan) has failed (ice will form on cooling coil).
This should get you started...
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Frost forming on top of inside door by hinge
you probably have an air leak. if the gasket is bad it needs to be replaced. Air could also be coming in through the door flap if you have water and ice dispensor on door
Sep 17, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My frigidaire refrigerator is sweating on the inside. what should i do? its a one door model with ice maker and freezer on top. i don't remember the model. 5 years old.
High humidly could cause condensation or the magnetic seal could be bad.
A couple of things to try;
The easiest thing to do first is to clean around the rubber seal very good with mild soap and water and the metal which the magnetic rubber seal contacts to seal the door. If you find a crack or a deformation of the seal it will let condensation it the refrigerator.
Does the freezer auto defrost or is a lot of ice bult up around the freezer walls? If so manually defrosted the freezer.
Dripping from the Ice maker water supply?
Jul 15, 2009 | Frigidaire Refrigerators
Ice forming and freezing in the freezer bottom
Need to find out if the refrigerator is going into defrost normally, about every 8 to 10 hours. If it does defrost normally, does the drain inside the freezer panel and under the evaporator coil drain without blockage? Defrosted ice, (water) should go down a drain pipe and into a pan near compressor. Let me know, Thanks, Sea Breeze
Mar 22, 2009 | Frigidaire Side By Side Refrigerator 26...
Fridge losing coldness
Defrost problem. Either defrost heater, defrost thermostat, or defrost timer is bad.
Sep 05, 2017 | Frigidaire GLRT184RA Top Freezer...
Open Questions:
Refrigerators Logo
107 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
