Question about Nintendo Wii Console
Hello my wii turns on via the power cable no problems but its connecting the wii with the AV cable. it worked before on the same TV. my guess is that the AV cable has gone but im not so certain of that as i am not an engineer.
    Master:
  • 508 Answers
You need new a/v cables your correct.
Posted on Dec 30, 2010
Testimonial: "thanks sean thats what i thought, iv got couooke coming to me :) cheers bro :)"
There are no connections for the red whits and yellow AV cable in the new smart TV can i eliminate this cable and use a USB cable in its place this is for a wii
The usb port in Wii is for input devices (i.e. external HDD, Wii keyboard etc.) and can't use it to output signal going to your TV , its only the AV cable supplied by wii you can use to connect to tv. If the TV has no RCA input (yellow, white & red connections) you can buy AV to HDMI adaptor or AV to VGA adaptor to connect your wii to your new tv model.
Sep 29, 2014 | Nintendo Wii Console
My wii when i turn it on it only has lines going across the screen.. about a week back it was saying something about the memory. now it wont load the wii menu nor will it load any games... if anyone knows...
Picture Is Black and White or Does Not Appear
Situation:
The console powers on and shows a black and white image on the television screen
The console powers on and there is no image on the television
What to do:
Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
AV Cables
Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
Try another set of inputs on the TV, or hooking the Wii console up to another TV.
If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
Component Cables
Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Was this information helpful?
Nov 02, 2012 | Nintendo Wii Console
Wii in black and white
Picture Is Black and White or Does Not Appear Situation:
  • The console powers on and shows a black and white image on the television screen
  • The console powers on and there is no image on the television
What to do:
  • Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
  • AV Cables
    • Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
    • Try another set of inputs on the TV, or hooking the Wii console up to another TV.
    • If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
  • Component Cables
    • Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
  • If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Apr 17, 2012 | Nintendo Wii Console
Why cant i get my wii console to work in color
Well it might either be the tv or the av cables that is causing the wii system to be in black grey and white then.
What to do:
  • AV Cables
  • Component Cables
Still Not Resolved:
Mar 06, 2012 | Nintendo Wii Console
The picture appear black&white. I have HDTV.
I had this problem with a 'universal' console component video cable. Had a B&W Wii screen, and couldn't set the Wii to HDTV.
Spent most of an afternoon switching the Wii between LCD televisions, annoying Samsung tech support (who are a very, very good tech support system, by the way) and so on.
Took back the cable and the guy said, "Did you remember to turn the little TV/HDTV switch here?"
There IS a tiny little switch on these combo cables, right on the common point of the various console connector plugs. I switched it. It worked. All is good again. Hope so for you too.
Dec 28, 2010 | Nintendo Wii Console
On a Daytek 46 in LCD TV, no AV Digital Cable Signal, but HDMI OK
Had the same problem.
Fixed by unplugging everything from the power source, leaving for 2 minutes then plugging back in.
Works fine now.
Aug 11, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Nintendo Wii AV Cables not work
It could be a problem inside the Wii where it only outputs a signal through HD. Have you tried a different TV using the original cables? If the problem persists I would recommend calling Nintendo.
Jul 27, 2009 | Nintendo Wii Console
Power light is green but nothing on the screen
Check the AV cables may be not connected right or the AV cable is broken.
Mar 27, 2009 | Nintendo Wii Console
PS3 No picture or sound
When you connecting sony via hdmi sony and tv must be shut down.First turn on sony then tv.Connect also and av cable or scart then go to sony settings and change out signal via hdmi or scart or av cabel and confirm.That should work
Jun 25, 2008 | Sony Playstation 3 (PS3) Console
Connecting Wii through Component cables and Phillips switcher
I just did some more checking...
When you have the Wii connected to the AV Switch, try turning on the DVD player too, but have the switch set to show the Wii on the TV. It is odd, but that has worked for me.
Jun 19, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
54 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
