Question about Craftsman 8.0 amp Reciprocating Saw
The blade broke off in my craftsman compact reciprocating saw and I cannot remove the broken blade
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: Reciprocating saw-snapped blade-cannot be removed
What I would try is to spray some WD40 on the pin first and then see if you can find a small screwdriver or punch and try pushing the pin in further to release the broken blade. It doesn't sound as though it is anything major, maybe a burr on the side of the pin or possibly rust or debris. DON"T hit the pin because you might damage it or push it in and never get it back out. Looked at a diagram and it appears that they used roll pins to hold the clamp in place so it might be that one is cracked or mushroomed and you might have to drive them out. I suggest that you go to Searspartsdirect.com and type in your model number to look at the same diagram.
Posted on May 26, 2009
SOURCE: Blade won't lock.
There is a ball lock in it and you have to twist the ball lock but if the ball lock is frozen generally WD40 will help unfreeze it and work it until the ball is free and should work just fine.
Posted on Jul 22, 2009
jrox55
  • 66 Answers
SOURCE: The blade lever on my sawzall is stuck in the up position
oohh, that a tough one. you gotta, very carefully peal back the hand gaurd, the rubber where you hold onto it, at. Then releas the screws undeneath. Seems like you should be able to cycle the saw to its furthest out position, then remove the blade gaurd, uning some pliers of some sort you should be able to make the release, release.
Hope this helps
Posted on Mar 09, 2010
  • 2006 Answers
SOURCE: How do I remove a broken blade on a reciprocating
Sometimes if you take the set screw completely out and then use a flat blade small screw driver to wege open the throat you can use a dental pick to get it out. Spray it first with wd40.
Hope you weren't using those cheap blades from harbor freight - that is how I learned that trick - bought the dental picks from harbor freight.
Posted on Jun 20, 2011
How do I replace the tool-less blade clamp in a craftsman 8 amp reciprocating saw
Craftsman Reciprocating Saw replace the tool-less blade clamp
Jun 10, 2015 | Craftsman Saws
How do I remove blade that's broken off in a Skil 9216 reciprocating saw?
Turn the release as far as it will go, then tap on something blade down till it emerges.
Aug 03, 2014 | Skil 9216-01 9.0 Amp Variable Speed...
How do i remove a broken blade in the bosch rs 325
Open the chuck and try gripping the bit of broken blade with some tweezers or flick it out with a small screwdriver.
Nov 30, 2012 | Bosch RS325 Compact Demolition...
How do I remove a broken blade on a reciprocating saw? The blade broke off at the place where it attaches to the body. Unlocking the blade by the usual means doesn't free the small piece remaining in...
Jun 20, 2011 | Dewalt DW303 Heavy Duty 65 Amp...
How to remove a broken blade from a craftman recipricating saw shaft
Unplug the unit, us a stiff pliers ( a locking pliers if you have one) and yank! make sure any quick release mechanism is disengaged before you start.
Mar 03, 2011 | Craftsman 8.0 amp Reciprocating Saw
I have a sears reciprocating saw with a broken blade.I can't remove the busted blade.Is there any way of removing it?
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
Aug 19, 2010 | Craftsman Saws
Shaft or rod seems to be broken
The gears are stripped internally in the saw...it will need to be repaired..usually there are regional service centers for repair...look for the one closest to you...
heatman101
Jul 26, 2010 | Craftsman 85 reciprocating saw 926770
May 26, 2009 | Craftsman 8.0 amp Reciprocating Saw
REPLACE BLADE IN MOD #172.171800 8.0 A, CRAFTSMAN, RECIIP SAW
If you see a set screw where the blade goes, loosen it a few turns. Then run the saw, it should spit out the broken blade. If it has a manual release for the blade, press the release while tapping the blade holder.
Apr 29, 2009 | Craftsman 8.0 amp Reciprocating Saw
Craftsman 8.0 amp Reciprocating Saw Logo
129 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
