Question about Maytag Dryers
The dryer isn't heating and the timer dial isn't turning as the cycle progresses...
  • Maytag Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Dec 31, 2010
Timer knob not turning and its not heating up
If you are setting the knob to begin a cycle AND the drum turns when you start it AND the timer knob does not advance, the timer is likely defective.
Some dryers with truly automatic cycles (using moisture or temperature sensors) will not advance the timer if there is a no-heat condition due to a bad thermostat or heating element. This would show as the dryer tumbling a load forever and the clothes are cold and wet when checked.
If the dryer will not do anything at all AND the timer knob does not advance, check the power (circuit breaker/fuse), then the dryer door switch. When the door switch is defective or the door isn't fully closing, it stops everything, period. There is a thermal fuse on some machines that will also cause this problem.
Good luck from Detroit, MI.
Oct 19, 2011 | Dryers
Not heating/timer knob not turning . the dryer works but is not heating and i noticed that the knob is not turning therefore it does not shut off just keeps running.
HI. The timer device is responsible for initiating the heating cycle. If the dial plate is unable to advance, the heating circuit will not operate correctly, thus, preventing proper heating. Another indication of timer mechanism failure will be an un going cycle. You have stated that the unit Will continue to run, without stopping. This is caused by the defective timer device.
In most cases, the actual timer motor will Fail. This motor is , essentially, responsible for the forward motion of the dial plate.
I recommend to replace this damaged timer device, asap.
Jan 19, 2010 | Whirlpool Dryers
Dono heat and timer dont turn
HI. Due to the fact that the timer is not advancing, this will lead me to believe that the timer is the culprit here. The timer is equipped with a motor. this motor, when energized, will advance the timer dial, thus, activating the unit, and progressing the cycle. If the motor is damaged, as in your case, the unit will not heat, or run correctly. Simply replacing the timer control module will correct this problem.
Replace this damaged timer mechanism asap.
Dec 04, 2009 | Estate TEDX640JQ Electric Dryer
Kenmore Elec Dryer timer & Heat Element Failed
if you set timer on time dry it will count down but if you have it set on more or less it will not advance without heat,change out the heater and you will be fine
Nov 04, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer will not turn off aafter it's 40 minute cycle.it will start over with 1 hour 22 minute cycle
You should check your thermostats, they can cause this problem.
Look for the air tube that goes from the blower to the drum, this is where the thermostats are normally located and the heating coil is normally located there also.
Hope this helps
Sep 30, 2009 | Maytag Dryers
I have a 5 year old Whirlpool Electric Dryer, Model #LER7648KT2. The Dryer won't start. I have checked the door switch, start button switch and visible thermo switches or thermostats with an ohm meter...
There are usually 2 thermal fuses in dryer circuits. One is on the heater housing and will blow in an overtemp condition around 310-350F.
The other is on the blower or exhaust housing and will blow around 200F
Make absolutely sure the 2nd one is continuous and not intermittently functional. This will definitely stop the motor from functioning
Below is a diagram for an older model (LER4634). Your dryer has some additional terminals probably because it has additional drying cycle options.
The diagram may be more readable when copied and pasted into a plain text editor such as Notepad or another editor with non-proportional fonts
Switch Terminals
|TM |TM |BK |BK |BK |
|WB |OR |BU |BU |R |
|-- |-- |V |-- |-- |
|O |X |O |X |X |Auto - High Heat
|O |X |X |X |X |Auto - Low Heat
|<> |<> |~ |X |O |Cool Down / Fluff
|O |X |O |O |O |End of Cycle
|X |O |O |X |X |Timed - High Heat
|X |O |X |X |X |Timed - Low Heat
Legend:
O = Open (Infinite Resistance)
X = Closed (Continuous)
<> = Either (But not Both)
~ = Doesn't Matter
NA = Not Applicable
Switch Terminals:
TM - Timer Motor (Different Models may use different colors)
WB - Black/White
OR - Orange
BK - Black
BU - Blue
V - Violet/Purple
R - Red
Example: For the Auto - High Heat Dry cycle, the following terminals are continuous:
Terminals
<TM - OR>
<BK - BU>
<BK - R>
(of course since BK-BU is continuous and BK-R is continuous, then BU-R is also continuous.
This should allow you to test at least some of the cycles your timer switch has
I have a general schematic in PDF for whirlpool for gas and electric, but did not see an option to add an attachment to this message.
Hope this helps or point you in the right direction.
Apr 21, 2009 | Dryers
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Heats up and then no heat again
You need a coil kit for the gas valve they will waeken over time and not open when they are energized
Jun 18, 2008 | Amana ALG331RAW Gas Dryer
No heat after first cycle
This condition is normally caused by a faulty cycling thermostat. Movement of the timer in the auto-dry mode is controlled by the cycling thermostat. Movement of the the timer in the time-dry mode is not controlled by the cycling thermostat, but by the timer motor.
Below is a link directing you to an enlarged image of the thermostat. You will also find other pages within the website with exploded view diagrams and disassembly procedures, prices and shipping information.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=601359&PPStack=1
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
