I have an HP Deskjet 9650 and the Encoder disk fell off the end of the rail. How do I get the correct placement on the rail?
  • 1 more comment
  • kmtgraphics Dec 30, 2010
    This is not the encoder strip, this is the encoder DISK. It sits on the far left outer end of the feed shaft. It resembles a round disc with numbers and a solid area as well. Similar to a timing wheel. It only has 2 way tape holding it to the assembly. It fell off when I was cleaning the unit out. There are no other markings to go by.
  • kmtgraphics Dec 31, 2010
    I have an HP Deskjet 9650, the Encoder "Disk" not the strip has fallen off and I need to know how to put it back in the correct position. The disk is located on the far outside left of the feed roller. It is held on by 2 way tape. The disk has numbers and a dark area similar to a timing disk.
    How do I align it, there is nothing available? No notch, no markings just a sprocket and the disk.
  • 19,396 Answers
Hi.
The encoder disk is the one connected to the motor, and called Paper Motor Encoder Disk. The part mounts on the left end of the pivot and feedroller assembly shaft. The encoder disk rotation determines timing with motor. The disk does not have timing mark alignment procedure specified in service document.
The problem of refitting the disk can be sorted by purchasing and reinstalling the whole disk and shaft assembly. Here the part: C8137-DRIVE_ASSY.
Regards.
Ginko.
Posted on Jan 02, 2011
  • 942 Answers
Try to re-align the enocder disk by putting it slowly at the top of the rail so that the disk will be in proper position. Make sure your printer is off before doing this step..
Posted on Dec 31, 2010
    President:
  • 3,278 Answers
Hello.
The encoder strip has a slot on either end that hooks on either side, just behind the carriage.
I would suggest to first carefully clean the encoder strip with a Q-tip.
Hope this resolves your problem.
Posted on Dec 30, 2010
  • NinaE Dec 30, 2010
    Oh, sorry. I'm really not certain what to advise you.
Replace the Encoder Disk Assembly.
this message may have lit up as end of life counter or because the formatter is unable to correctly locate its position or rotationof the media roller.
this is an engineer call out for the repair I would NOT suggest that a customer is able to correctly fit this part as its deep within the plotter and many calibrations will need to be completed before the plotter is once again ready to print. I would suggest Belmonte Business machines on 0161 480 5556 who can offer nationwide service to all HP Plotters
Jan 30, 2014 | HP DesignJet 500ps (42 in.) InkJet Printer
Hi I've got an HP Deskjet F380 which is now permanently showing an 'E' light and low ink light. It was working fine with occasional glitches with print queues but is now permanently 'in error'...
Clean the electrical contacts on the carriage as well as the cartidge using a soft lint free cloth wetted with iso-propyal alcohol. Clean also the "steel rod" on which the carriage moves.
Wipe clean the encoder strip (a flexible coded PVC strip running through the PCB behind the carriage and hooked at the ends) with a DRY soft cloth (DO NOT USE ANY LIQUID TO CLEAN THE ENCODER STRIP TO PREVENT ERASING OF THE CODE). If still dirty Replace.
Your printer should hopefully start working.
Feb 16, 2011 | HP DeskJet F380 All-In-One Printer
The top of the cradle that holds the black ink cartridge down in place is broken, how do I replace.
Since this is a Deskjet 9650 which mean it is already an obsolete printer. HP might not be manufacturing the parts anymore. Or if they did, it's so much better if you call HP and just Upgrade your printer. HP Printer Tech Support would be more than happy in giving you discounts, you can actually get a brand new printer half the price that you will see on the website plus you can also get an extra year of warranty just by adding $1.00 to the total price of the printer.
Feb 07, 2011 | HP DeskJet 9650 InkJet Printer
Shows the error msg that the catridgets are installed incorrectl
try to remove the catridges and put it back again. if cannot try to open the printer casing and check out the waste ink placement. sometime there will be an ink that block the catridges placement..
Jun 04, 2009 | HP Deskjet D2360 InkJet Printer
In response to your suggestion
Hey,
we can start a remote support session and I can try fixing the problem for you.
start the session by opening this link
http://www.fastsupport.com/751310195
Jan 11, 2009 | HP DeskJet 9650 InkJet Printer
HP 1000C inkjet
plastic ribbon is "encoder strip"
encoder strip fitted in carriage block unit
Feb 05, 2008 | HP DeskJet 1000cxi InkJet Printer
Hp deskjet prints symbols/wingdings instead of text
sounds like a driver problem.
1. reboot your "Computer"
2. re-install driver
3. test print.
hope this helps
thanks for rating
Jan 14, 2008 | Office Equipment & Supplies
136 people viewed this question
k24674
