Question about M&S Systems FX-3000 Bagged Central System Vacuum
Need pcb for fx3000 - M&S Systems FX-3000 Bagged Central System Vacuum
No power, electrical wirring is intact from power plug to switch to pcb
normally with a henry the cable breaks from where it joins the hoover just take apart from hoover end cut about a foot of cable off and then rewire
Feb 09, 2014 | Henry Numatic "" Canister Vacuum
I replaced the handle on my Hoover UH30010 Platinum Bagged upright and now the check bag light is on and vac will nut run.. Is there a reset button? How do I fix this?
Hey. I believe you will need to replace the main PCB board too. My new handle was sent with a new PCB board. However, I tried just replacing the handle first and it acted the same way you describe. Once I changed the PCB board it worked fine. Hope this helps.
May 25, 2012 | Hoover Ultra U6430-900 WindTunnel Bagged...
Vacuum won't shut off. Switch appears good. Won't shut off with hose removed.
The "vacuum won't shut off" problem is caused by a faulty triac (electronic component) on the P.C.B. assembly. You have two choices, depending on your handiness:
  1. Easiest: Replace the PCB: P.N.=KC86WBZRZ000
  2. More difficult: Replace the triac: P.N.=BTA16-600CW (ST Microelectronics): http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00002265.pdf
The PCB costs about $25.00 from Sears, whereas the triac costs about $1.50. Sears will not sell the triac - you'll have to find an electronics parts supplier.
Feb 17, 2011 | Kenmore 25614 / 25615 Progressive Bagged...
How to disassemble electrolux ZAM 6280?i had already removed screws and don't know to disassemble it. i need to check fuse or if it needs resetting.i'm using it and it suddenly stopped completely.no power...
Hi There.. I had the exact same problem with my ZAM6280 model. The PCB part (location C8) had blown. Do you know the details for that part, so I can replace it? Otherwise, you didn't happen to come across any schematics for the PCB Module??
Jan 11, 2011 | Vacuums
Hi guys, I have a bissell 9400 2x proheat with a fault. When you turn on the machine it trips the RCD in my house and makes a poping noise, i am a little technical so i had a look inside. The pcb under the...
I've seen the same problem in one of these we had in for repair. The pcb in the handle is involved with controlling the roller motor. The problem is with the motor. In my view, this machine is a triumph of design over practicality... The motor is located right at the bottom of the base - making it very vulnerable to getting wet, and as difficult as possible to get to. What happens is that the motor gets wet, rusts and seizes up, and that causes the pcb to burn out (or possibly it's so wet that there's a short circuit).
So, what do you need? You need a pcb, a brush roll motor, the patience of a saint, a very good memory for what goes where when you reassemble... and a long hard think about whether you'd recommend one of these to a friend!
Feb 27, 2010 | Vacuums
Vacuum faulty power PCB, Need service manual/schematic
No schematic found. The Q1 transistor is a 2N3904, D3 was replaced with a 1N4000 series.
Root cause still Unknown, but Q1 is an exact match and D3 is an acceptible replacement.
Hoovers solution is to replace the whole PCB no matter whats wrong with it, what a waste or good technology!
Mar 30, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Burnt out resistor
I'm in the same fix. I learnt that a new pcb is £68 so had the pcb repaired but after the machine has warmed up it now cuts in and out. Like you, I haven't been able to locate a wiring diagram so am trying a last minute lash-up before binning the machine:
A friend suggested that since we all seem to only operate the cleaner on full power I should connect the on/off switch direct to the motor bypassing the rheostat and the pcb as in old fashioned machines.
Aug 31, 2008 | Miele S251i Plus Bagged Canister Vacuum
VACUUM WON'T SHUT OFF
Need a model number to be sure, but alot of the Sears cannisters have a relay and it is found mounted in the motor comparment, it may be sticking in the on position.
Nov 26, 2007 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore model 116 25615506
You can sometimes find the PCB from a 3rd-party supplier. For example, this one on EBay: Mel-Co KC86WBZRZ000
Sep 24, 2006 | Kenmore 25614 / 25615 Progressive Bagged...
M&S Systems FX-3000 Bagged Central System Vacuum Logo
24 people viewed this question
Top M&S Systems Vacuums Experts
JoeVacs
Are you a M&S Systems Vacuum Expert? Answer questions, earn points and help others
