Question about Keurig Elite B40 Coffee Maker
Hello... I am having trouble with this Keurig coffee maker... The maker does not produce full cup when requesting. It comes only 1/4 cup. Can you explain on how to correct the system?
Recommend running several cups of water through without the K-cup, and then performing a descaling of the machine. If that doesn't work, call customer service.
Posted on Jan 02, 2011
My Keurig is only making 1/2 cup of coffee on the large setting. Then about 1 minute later, the other 1/2 comes out. Why is this happening, please?
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 07, 2011 | Keurig B70 Coffee Maker
Prime light on three brew lights on pressing cup produces no coffee
heatman101
Jul 31, 2011 | Keurig B60 Coffee Maker
When pressing on the setting for medium cup of coffee, only 1/2 cup comes out
heatman101
Jul 29, 2011 | Keurig B60 Coffee Maker
Does not produce full cup of coffee, only fills cup about 1/4 when full setting selected
heatman101
Jul 10, 2011 | Keurig B60 Coffee Maker
Keurig coffee maker isnt working--water brews turns red but does not come out--1/3 cup
heatman101
May 21, 2011 | Keurig B30 Mini Coffee Maker
My Keurig Platinuim will say brewing but only 1 teaspoon of water comes out in the cup, this is with no K-cup installed.
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Jan 27, 2011 | Keurig B60 Coffee Maker
Hello There! We have several Keurig coffee makers and we have a problem as follows: The rubber seal inside at the top underside around the puncture pin comes off quite often and will not stay glued...
I have a B70 that will not brew a full cup of coffee. Sometimes it shuts down brewing with only a 1/4 cup brewed. It usually will put out a full cup of water the first or second time and then very little. I have run vinigar through it but it did't help.
Dec 15, 2010 | Keurig B50 Coffee Maker
Keurig Special Edition B60
I assume your coffe maker used to produce more coffee for each use. Roughly 6 ounces per large cup, and now is only making 3 oz. cups.
If your coffee maker is sputtering and not able to "suck" enough water to fill your cups of coffee it is most likely due to cavitation caused in the little pump due to a stoppage, which is most likely lime or scale buildup somewhere in the pump line.
To fix it, don't take your coffee maker apart. Get a bottle of distilled white vinegar, and pour it straight into the empty water resevoir. Press brew with no coffee pod so you are just running the vinegar through the system. Pour the vinegar out of the cup and back into the resevoir. Add some ice to cool it off. Repeat about 10 times. This should clear out the toughest lime scale clog.
After you notice the cups are filling full of water, Replace the vinegar with fresh water. Run about 5 or 6 cups of fresh water through the system to get rid of the vinegar.
Make coffee/tea/whatever.
Jade
Oct 06, 2007 | Keurig Special Edition B60 Coffee Maker
Keurig Elite B40 Coffee Maker Logo
230 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
