Question about Whirlpool Washing Machines
My washer is not draining. gets a code of F-21
    President:
  • 1,430 Answers
This usually indicates a clogged drain filter or pump. Here is a link that should help
F21 Fault Code Repair
Posted on Dec 30, 2010
My washer whirlpool duet steam has a code of F 21 what does that mean
The Whirlpool washer error code F21 means the washing machine has a "water draining issue", meaning the drain pump itself, or the drain hose is clogged and the washer is having problems draining the water out
Mar 30, 2018 | Whirlpool Washing Machines
My washer has the code F 21 can you tell me what the problem might be??
I'd check owner's manual, or Mfg web site for your model.
Feb 10, 2018 | Washing Machines
F-21 code several times. We clean the pump. Start again the rinse/drain and spin cicle, and now present sd code and later f-21 code. What we need to do.
I have the manual for this machine. Under "Code 21" it says the following:
"F21" (Drain Problem) Select STOP twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Is the drain hose kinked? Is the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96" (2.4 m) above the floor? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service.
For "SUDS" code, the following:
"SUD" (Suds Routine) When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SUD" is displayed during rinsing to inform you that Suds Routine was activated. Use only HE (High Efficiency) detergents.
Here is some more information that may help you as well:
"F" Codes other than F20, F21 and F22 Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains, call for service.
I hope this is of some help to you, Please rate and comment, Thank You
Joe
Sep 04, 2011 | Kenmore HE2 Plus Front Load Washer
If there is anyway i could get a free answer omg it would be appreciated! what does the error code on a whirlpool ht f 21 mean? please help.
F21 LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the "Sd" error will be displayed, then
4 minutes later the "F/21" error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Mar 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a kenmore HE-21 front load washer. I am getting an error code F 21?
It usually indicates a clogged drain filter or pump. Here is a link that should help F21 Fault Code Repair
Dec 28, 2010 | Kenmore HE2 Plus Front Load Washer
I cleaned the pump filter after getting sud error. now i get F 21 code.
Press the pause cancel button 2 times this should clear it. If it does not and the filter and drain hose are clear you will need to replace the pump.
LONG DRAIN
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
LONG DRAIN
NOTES:
1. Check the drain hose and make sure it is not plugged or kinked.
3. Check the electrical connections at the pump and make sure the pump is running.
LONG DRAIN
NOTES:
Nov 03, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
F-21 error means What?
F-21=LONG DRAIN If the drain time exceeds 8 minutes the water valves shut down. After 4 mins the Sd(slow drain) error will be displayed, 4 mins later the F/21 error code will be displayed.
Press PAUSE/CANCEL 2 times to clear display
Probable cause/Proceedure
Drain hose plugged/kinked
unplug washer/disconnect power
check electrical connections to pump
and make sure pump runs
check drain pump filter for strings,sand etc
plug in washer If this dont work
replace pump.
Dec 31, 2009 | Kenmore HE2 Plus Front Load Washer
Error code F 21? washer stops
Hi
The error code F21 means LONG DRAIN
NOTES: After 4 minutes the “Sd” error will be displayed, and then 4 minutes later the “F/21” error code will be displayed. Press PAUSE/CANCEL two times to clear the display.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal De
