Question about Lexmark X1270 All-In-One InkJet Printer
I have a broken ink cartridge holder on a lexmark x1270 all in one printer. The black ink cartridge will not stay in.
SOURCE: change ink cartridge
I just did it a few minutes ago and it's pretty simple. Just grab the thing right in the center, above the print tray (there's a little handle) and pull the top up. The ink carts will be right in there (towards you, on the right) just pull the one you need to replace out, directly towards you, and then pop the new one in. There are little notches on it so you can't put it in backwards/upside-down or anything, and there's no latch or anything physically holding the cartridges down
Posted on Dec 18, 2007
SOURCE: x5470 Lexmark printer
Just unplug the printer from the back and plug it back in. Problem solved. I did this on my mother's printer and it worked like a charm for this same error msg and issue.
Posted on Jul 07, 2008
SOURCE: Lexmark x 1270 & x1290 printer won't print black after using re-filled cartridges.
hmmm...paperman..that's unusual to say the least..
Posted on Aug 19, 2008
vegakitten20
  • 685 Answers
SOURCE: Lexmark x2650 printer not responding to new cartridge
yes you have to have both of them then everything should be fine.if you have the color cartridge that is empty put it in for now and see if it will work it will let u know that it is empty but at least you will be able to print in black
Posted on Jan 04, 2009
rwandrew
  • 115 Answers
SOURCE: Lexmark x4850 ink levels won't reset with new cartridge
Hi...
Silly question, but I have done this myself. Have you removed the tape from the bottom of the cartridge?
Posted on Jan 25, 2009
My lexmark X1270 Printer is only printing in colour ......wont print in black
It could be that your black cartridge needs cleaning or is not properly seated in the carrier. Open the printer cover and reseat the black cartridge. Close the printer cover. Open Lexmark Solution Center on your computer. Go to Maintenance tab and select Clean to fix horizontal lines. Your printer will then print a test page forcing ink through the nozzles and clean them.
May 31, 2011 | Lexmark X1270 All-In-One InkJet Printer
I want to know if my lexmark x1270 is an inkjet printer....
Yes. The Lexmark x1270 is a discontinued model classified as an inkjet printer. It is compatible with the #16 and #17 black ink cartridges and #26 and #27 color ink cartridge.
May 02, 2011 | Lexmark X1270 All-In-One InkJet Printer
I lost my manual for my lexmark x1270 all in one printer.Can you tell me in what order is the ink cartridges placed.Black first or color first?
Here's the link to download the Lexmark X1270 setup sheet: http://bit.ly/9PWpTr. Actually, it doesn't matter what goes in first as long as you have the right cartridges installed. Black cartridges for X1270 are #16 and #17, and color cartridges are #26 and #27.
Aug 30, 2010 | Lexmark X1270 All-In-One InkJet Printer
Black will not print properly
your cartridge is about 100 pages of ink. Try to buy #16 black and #26 color for best results and economy, since #16 have about 250 pages resource.
Mar 07, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x1270 poor printing
Try these steps after these if you face the same problem then you need to get the cart exchanged as it may be defective as Lexmark cart comes with 6 months warranty ...
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Jan 27, 2009 | Lexmark X1270 All-In-One InkJet Printer
I installed a new black ink cartridge and my printer will not print. It will scan and save documents and I can select printer from the print menu but it will not print. Print jobs just stay in the queue
Can you print out a test page? if not send the cartridge back to the supplier as it is the cartridge, I was told Lexmark cartridges are brittle and you have to be careful.
Tell me more about it? I have had a LOT of these problems.
Also try putting the cartridge onto a damp cloth and see if that can open it up and another way to open the ink in to pop it into a cup of boiling water, when that is done you should see the ink coming out.
Hope it works
(A fellow X1270 user)
Dec 22, 2008 | Lexmark X1270 All-In-One InkJet Printer
Hi. i have the lexmark x1270 and need to change the ink. how on earth do i go about this? i cant find where it goes?!
the x1270 has 2 seperate lids....one for access to the scanner the other for access to ink cartridges....its also hinged so should stay open while you are changing cartridges
Nov 26, 2008 | Lexmark X1270 All-In-One InkJet Printer
Help - Black not printing
Try cleaning the contact points of the cartridge itself and the unit that holds the cartridge with alchol. If still not printing try nossle cleaning from your printer properties.
Mar 27, 2008 | Lexmark X1270 All-In-One InkJet Printer
My Lexmarkx1270 will not print any black text etc
Is it a new cartridge? If the cartridge has been sitting a while it can get clogged. Try using a moist paper towel and gently wiping the cartridge where the ink comes out.
You could also try running the Lexmark Solutions Center program and use the clean nozzles option to force it to squirt out some black ink.
Nov 19, 2007 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
159 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
