Question about Goodman Heating & Cooling
Need to change from Celcus to Ferinhate on the remote
What is the code for the BT YouView remote to a Celcus flat screen TV?
The codes are here. Doesn't matter if it is Virgin or BT, the code is to the television not to the remote.
http://celcustv.co.uk/faq
Jun 17, 2016 | Celcus Televison & Video
Celcus tv remote code
Check these codes: 241 115 275
Aug 05, 2012 | RCA Televison & Video
Celcus bt vision code?
The remote comes standard with the code 0000. with my celcus TV this controls the volume and mute but not the on and off. Better than nothing...
Apr 16, 2012 | Televison & Video
What is the 'One4All' remote code for Celcus TVs?
Try these codes. If it do not help you, Try code search method.
0147 0135 0250 0257 0310 0394
Code Search Method
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Apr 05, 2012 | Harley Davidson XL 1200 C Sportster Custom...
I need a pin code for my sky remote for the CELCUS tv
try 9999 it wiorks for most CELCUS tv's especially remote no.8
Jan 23, 2012 | Televison & Video
I lost user manual for Celcus 32
I'm looking for manual for the remote control that comes with the celcus 32882 32 inch purchased second hand can anyone help please
Jan 07, 2012 | Televison & Video
Heating & Cooling Logo
20 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
