Question about Vacuums
Instructions to use Logik Waffle maker please
Instructions for French toast stick maker
Do a search for it with your favorite search engine. You can download it or read it online.
Oct 20, 2013 | Deni4862 French Toast Stick Maker
I RECEIVED THIS FROM MY DAUGHTER SO HAVE NO INSTRUCTIONS BUT THE WATER ISN'T HOT ENOUGH FOR MY COFFEE
the element might of burned out. Is it a used coffee maker? Elements do burn out from time to time and you might have to just buy a new coffee maker.
Aug 16, 2011 | Vacuums
1 need the handle for wp bistro waffle maker BRWB0010
The only way to get parts for your WP waffle maker is to call (800) 275-8273. There you can order parts for your waffle maker.
Jul 30, 2011 | Vacuums
I found a salton tweety and sylvester waffle maker, but there are no instructions. The light just stays on all the time when plugged in. How do you know when the waffles are done?
Try letting it warm up for at least ten minutes. Then add waffle batter and leave closed for about five minutes and check the waffle. If it is way over done try three minutes other wise adjust your time in thirty second increments. You should have great waffles in three or less tries.
Good Luck,
Gil Shultz
Jul 19, 2011 | Vacuums
Why can't I find the instructions or manual for SALTON YOGURT MAKER thermostat controlled? Model #GW5 I would like to print it.
You should be able to use this manual for your Yogurt Maker:
http://www.scribd.com/doc/21228176/Salton-Yogurt-Maker-YM9-Manual
I could not find a GW5 Model made by Salton. Please check your model number again and I hope this helps.
May 23, 2011 | Vacuums
Need instructions for donut maker
Hmmm, good question, does the maker have a make and model number or name?
Mar 02, 2011 | Vacuums
I need a couple microtemp fuses 240 degrees C G4A00 for the wolfgang puck swivel waffle maker.
Radio Shack has a 228C and a 262C.
Google '240C thermal fuse' for online purchasing.
If you live near an urban area, try an appliance repair facility or electronics supply.
Feb 28, 2011 | Vacuums
I lost the directions for the proctor silex waffle maker
Try this site
http://www.proctorsilex.com/use-and-care.php
you will need to enter your model number and type of product. The use and care manual then can be downloaded. There are also recipes on the site as well.
Dec 29, 2010 | Vacuums
We have just opened a De Longhi Icona coffee maker. We followed the instructions to start it, but when we press the coffee button (after the OK light comes on), it makes a loud buzzing noise and no water...
may be you may forgot to fill it up with water...... otherwise i request you to please read the manual book which was given along with machine so that you may get the appropriate solution
Oct 22, 2010 | DeLonghi Vacuums
Vacuums Logo
142 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
