I have just replaced the lamp on my 61" RCA DLP HD61lpw42 and the picture is so dark you haver to turn off the lights in the room to see the picture - do I need a new color wheel or balast?
  • brichards630 Dec 30, 2010
    The lamp can be seen through the back panel and it is very bright?
  • 11,800 Answers
I assume that the bulb was correctly installed, no dust was allowed in the optical engine and the lamp power setting has ben set to maximum - in Menu > Preference > Lamp Power set to Brighter Image.
The color wheel has nothing to do with that - unless of course the plastic coloured filters have been so burned by the heat of the bulb that they no longer allow the light to pass thru them. But i think you would have smelled that.
No, this is a ballast problem - it no longer generates the correct voltage so the tube is below its normal functioning point so it delivers a lot less light. You will have to replace it.
Posted on Dec 30, 2010
  • Azrael SRL Dec 30, 2010
    Yes, this is it, but it should be accessible from the front, behind a cover flap.
The picture is not bright in a light-filled room. Will a change of DLP lamp help? Are there different lamps that will improve picture quality?
Yes.Depend how old is ur DLP tv,the Projection Lamp only a light source,mostly depended on the Light projection Engine itself.Get the original RCA DLP lamp or same lamp model now inside the tv,will help and work best for ur tv.Just don't get generic DLP tvs lamp,it cheaper poorer quality.
Dec 17, 2010 | RCA HD61LPW167 61" HDTV
Picture occasionally goes out, still have sound when this occurs and then the picture will come back on after a while. When the picture is out the lamp is off. Hd61lpw42 RCA DLP TV
Souns like the Lamp is going out ,If you have never replaced Lamp then that is what your Problem is Mats has them for $99.00 1-800-628-1118
Nov 06, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW42. No picture/sound.
Ur high voltage FBT,is dead the block of plastic with a red wire with a cap hook to the CRT(tv tube).Might also have to replace the whole power board?Because just couple parts it hard to determins,what else also ready to burn next!
Sep 12, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
61" RCA Home Theater
If your TV is DLP replace LAMP.
Aug 06, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Replace lamp on 50' rca dlp and still no working.
Before replacing the Ballast I would look at the power-supply and see if you notice any of the electrolytic capacitors tops being bubbled. It is not uncommon for the capacitors to go bad as the lamp draws more current as it ages and fails. If you do see capacity's bubbled, Replace them or have them replaced and the set will probably work fine afterwards.
Hope this helps,
Skyassoc
Jun 28, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Turning on but no picture at all
I would check to see if the lamp is actually comming on before anything else. The color wheel won't cause a loss of picture. Here is a link to purchase a suitable replacement lamp for the TV. It is 300 dollars less than the RCA version. http://www.partstore.com/Part/Thomson/RCA/HD61LPW42/Lighting+Technologies+International/LTI/260962RL/New.aspx
May 09, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Intermittent picture
Most likely your lamp needs to be replaced as that will cause the intr. picture issue. The color wheel will also have to be replaced. The color wheel is only available with the light engine which is part# 263223 and the lamp part #260962
Mar 05, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
