Question about Electrical Supplies
Some of the lights went out in my home. when i checked the circuit beaker all switches was in the on position so i messed around with them lights came on but other went off
    Sergeant:
  • 223 Answers
Go through them, turn them all off and then back on. Breakers, once tripped, have to be put in the 'off' position before they can be reset.
lp
Posted on Dec 30, 2010
I have a 2006 mitsubishi galant es. I was recently in a rear end collision. The following day my brake lights went out. A couple hours later while reversing out of a parking spot, I went to put my car in...
here is what the code means.
http://engine-codes.com/p0705_mitsubishi.html
P0705 Mitsubishi Description The park/neutral position (PNP) switch includes a transmission range switch. The transmission range switch detects the selector lever position when the shift lever is in the N or P shift position and sends a signal to the Transmission Control Module (TCM).
When is the code detected? The transmission range switch detects the selector lever position and sends a signal to the TCM.
Jun 27, 2014 | Cars & Trucks
Home air condition thermostat is blank. My home's central air condition stopped working. So the first thing I did was check the thermostat and it was blank. I then went down to the basement and got the...
Put new batteries in the thermostat. Make sure that the switch that power the furnace is in the "on" position. Sometimes people mistake that switch for a light switch and turn it off.
May 23, 2014 | Heating & Cooling
Check engine light gas cap
either a leak in vaccume system or a shorted wire to tail lights or trailor lights can cause this
Sep 26, 2013 | 2009 Jeep Patriot
I have a 2006 lancer es. My dash lights and tail lights went out. My dash lights dimmeed one day and the next da y it completly went out. Everytime I add a 7.5 fuse it blows as soon as I start my car. Any...
check your ciggerette lighter and power point and make sure they are clean. pull the lighter right out and try again. also a 7.5 amp fuse seems very small to run your dash and tail lights. should be a 20 amp fuse.
Mar 06, 2013 | Cars & Trucks
Cadillac lights won't turn on
No relay that I know of.
On 1970s models the headlight switch had a circuit beaker built into the switch for the headlight circuit.
If you have power to the headlight switch and nothing coming out of the terminal for the headlights the circuit breaker may have died.
You would need to replace the switch.
Aug 18, 2012 | 1975 Cadillac DeVille
Changed oil in bike, started right up to move it where i then changed the oil, went to turn the key to the on position, NOTHING, none of the gages come on, fuel pump doesnt prime either.
Hi Richard, and the usual suspects are:
1. Ignition switch not in the "ON" position.
2. Engine run switch in the "OFF" position.
3. Discharged battery, loose, corroded or broken battery cables, especially the "NEGATIVE" cable at both ends (solenoid chatters).
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
7. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
Good luck and have nice a day.
Jul 04, 2012 | Motorcycles
No power is getting to the heater
Check the circuit breaker(s) that feed this AC unit. It may have tripped a beaker in your home's Circuit Breaker Panel.
May 11, 2011 | Heating & Cooling
I ahve a 2002 BMW F650GS - a couple of months ago it cut out for no reason. Then a few weeks later when I used the heated handgrips it 'died' again. I turned it off compeltely then restarted and it went...
Hi, Barbaraten13 and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
7. Faulty starter button.
8. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
Thread 2001 F650GS won start please help
F650 Community
2001 2005 BMW F650CS Service Manual Moto Data Project
BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
Free Rider Manual Download BMW F650GS Twin
May 04, 2011 | 2001 BMW F 650 GS
I took my 1996 nissian maxima into the dealer ship today to get my check engine light checked out. They didnt fix my engine light and plus when i went to go pick up my car my shifter was stuck in park...
Most automatic cars require that the foot brake be applied before the gear selector is allowed to be shifted from the Park position as the unlock signal is taken from the lamp side of the brake light circuit.
It appears that you have an intermittent fault in the brake light switch and replacing it should solve the problem. The switch is located on a bracket under the dash near the top of the brake pedal arm. You could put a bridging wire across the terminals to confirm if the switch is out and the rest of the wiring is OK. If the shift enable and lights then work, replace the switch.
Replacement is as follows:
To remove switch, disconnect wiring, loosen locknut and unscrew switch. Replacement is reverse procedure. To adjust, screw in switch until operating button is fully depressed by pedal arm, tighten locknut and reconnect wires. Check for correct operation of lights. You may have to unscrew switch slightly to get best operation.
Dec 31, 2010 | Nissan Maxima Cars & Trucks
Have a 2006 Heritage Softail - Was running when speedometer & odometer quit working and key light came on - not engine light. Stopped at gas station - when down shifted to stop things started working...
Hi Johnrobindan, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections check negative cable at both ends. (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For a prime suspect please visit website below and good Luck.
Harley Diagnostic Codes 04 to Present
Aug 24, 2010 | Harley Davidson FLSTCI Heritage Classic...
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
