Question about Whirlpool Dryers
We have an Estate Whirlpool clothes dryer/Model #MY60-G which was purchased (I think sometime in 2002?). It spins, but after it is on for a little while the heat stops and the clothes never dry. We were told it is probably a relay switch and would like to know how to go about purchasing on to fix the dryer. Thank you for your cooperation, Carol Mosko
    Genius:
  • 1,028 Answers
Gas dryer ? replace the 2 coils on gas burner the 2 black round dohickys..electric possible bad operating thermostat remove back round object on blower housing
Posted on Jul 08, 2008
I have a whirlpool gas dryer model#LG5801XKGO.
Whirlpools are great. There is a flame sensor near the igniter, it gets dusty and can't sense the flame. Carefully wipe it off, without bumping the igniter, it's super delicate. Sometimes the sensor can be removed for cleaning, just held in place by a little screw.
Nov 26, 2013 | Whirlpool Dryers
Estate by Whirlpool washing machine Model:etw4400sq0 not spinning.
In my experience, a failed coupling is a likely cause
Dec 26, 2012 | Estate Washing Machines
Whirlpool estate electric dryer model teds680eq1 starts spins heats up then quits 15 minutes later
The operating thermostat has probably failed. When the dryer haets up, it gets too hot and the high limit thermostat turns the machine off. After it cools down, it will start, again.
Apr 15, 2010 | Whirlpool Dryers
Clothes Not Drying well
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Jul 31, 2009 | Whirlpool Dryers
Washing machine spin problem!!!!!
whirlpool estate washer is dun the clothes are ring Wet
Jan 13, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Spin cycle not removing enough water from clothes
your manual states that it can be caused by cold rinses and or spin cycle not getting completed. please try to rinse in hot or warm and see if that does not solve your problem
Dec 20, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
My washer doesn't spin
if it will pump out in spin cycle then the motor coupler is most likely bad / larryyb
Dec 07, 2008 | Washing Machines
Clothes dryer not heating
Is this an ELECTRIC dryer? Or, a GAS dryer?
If this is an ELECTRIC dryer, the following link explains the most common causes of a "No Heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If this is a GAS dryer, the common source of a "No Heat" problem is a failed igniter, or gas valve safety coils.
I hope this helps you. If you require addtional assistance, please post back with your make and model so I can make a more accurate diagnosis and/or identify any parts you may need.
Aug 27, 2008 | Dryers
Washer won't spin dry clothes
What model is in reference here? Please post back with model number.
Jul 02, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Dryers Logo
60 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
