Question about HP DeskJet 712c InkJet Printer
The ink cartridge will not return - HP DeskJet 712c InkJet Printer
Printing too much ink
Return Cartridge. To much ink indicates a bad seal on the cartridge. Or you have a defective circuit board on the printer. I beleive it is a bad cartridge. Captain Jack
Apr 15, 2014 | HEWLETT-PACKARD F4435 InkJet Printer
Lexmark x7170 changed ink cartridge. test sheet comes up great, print something and it says ink low. i tried to shut off 5x's to maybe reset/ reinstalled ink cartridges same message. cleaned heads
The Lexmark x7170 should let you continue printing with the ink cartridge regardless of the estimated ink with most cartridges. The only exception to this is if the cartridges are part of Lexmark's returns programme. I would advise removing the cartridge and checking for small text stating "Return Programme Cartridge" on the label. If this is present sadly there is no way of continuing, apart from buying a new cartridge.
With regards to the low ink estimate, am I right in assuming you are using a refilled or remanufactured ink cartridge? If so this is unavoidable but should not prevent you from printing until the ink physically runs out.
Nov 29, 2012 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Hp 3210 is leaking ink
Remove the black ink cartridge and put a piece of tape on it to prevent it from leaking all over your clothes. Find the receipt for the cartridge and return it to where you purchased it from. More then likely your going to have to clean out your entire printer to get rid of the ink that has leaked into it. You have a faulty ink cartridge. Hopefully you purchased a name brand cartridge and can return it. If you need assistance with instructions on how to clean out your printer, please advise.
Apr 30, 2012 | HP Photosmart 3210 All-In-One InkJet...
Bought compatible cartridges for lexmark S405 all in one. Won't authenticate them. locked out of printing. Any ideas
For the most optimal output experience with your AIO, Lexmark recommends that customers update their firmware. The firmware helps ensure that customers receive the highest yields of ink available from the cartridges, which offers the greatest value and means fewer necessary cartridge replacements.
If you choose to upgrade firmware, note that unauthorized use of third-party 'cloned' cartridges will no longer be possible.
When purchasing ink cartridges, Lexmark customers have two options:
Regular ink cartridges without license terms (100A/100XLA) that you may a) return to Lexmark free of charge (for recycling by Lexmark), b) refill, recycle or remanufacture themselves, or c) provide to third parties for refilling, recycling, or remanufacturing. Any Regular ink cartridge can be refilled by a customer or a third party and will continue to work in their Lexmark printer.
Return Program ink cartridges that provide customers with an up-front discount in exchange for their agreement to use the ink cartridge once and return it only to Lexmark for remanufacturing and recycling.
Aug 31, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Replaced black ink cartridge (not lexmark brand) printer will not recognise it even though supposed to be compatible?
Regular ink cartridges without license terms that they may a) return to Lexmark free of charge (for recycling by Lexmark), b) refill, recycle or remanufacture themselves, or c) provide to third parties for refilling, recycling, or remanufacturing. Any Regular ink cartridge can be refilled by a customer or a third party and will continue to work in their Lexmark printer.
Jul 11, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Epson stylus sx200 refuses to acknowledge black ink bought direct from epson
I believe the DX series and the SX use the same system
# Determine which ink cartridges are not recognised.
# With the ink cartridge holder in the ink cartridge replacement position, lift up the ink cartridge holder lid and take the cartridge or cartridges out.
# Check that the cartridge is a genuine Epson ink cartridge - look for the EPSON branding and T0xxx codes on the cartridge labels.
# Check that the cartridges are correct for your Epson product.
# Wipe the green Intellidge Chip on the cartridge that is not recognised.
# Check the chip contacts within the ink cartridge holder for any debris or dried ink and wipe with a lint-free cloth if necessary.
# Check that the plastic at the bottom of the cartridge has been pierced.
# Check that the cartridges are in the correct slots.
# Reinstall the cartridges into the ink cartridge holder in the correct order.
# Push the ink cartridge down firmly. It should click into place.
# Repeat this for any ink cartridges that were removed.
# Push the ink cartridge holder lid down. It should clip into place and be secure.
# Press the Stop button, this will return the ink cartridge holder to the right hand side of the unit.
# If the error light flashes after the print head returns to the home position, the ink cartridge may not be installed properly.
# If the red light is no longer displayed, but Status Monitor still reports a Non-Genuine Ink warning.
# If the red light is still on the printer, and Status Monitor indicates that an ink cartridge is not recognised, follow the steps below.
# If the problem remains, there may be a fault with the ink cartridge.
Dec 30, 2010 | Epson Office Equipment & Supplies
Printer doesn't revognize new ink cartridge
Are you using Dell Series 5 ink cartridges? Dell Series 5 ink cartridges have a cartridge that cannot be reset.
Article on refilling Dell ink cartridges
It's possible to get a bad Dell Series 5 ink cartridge. Return to place of purchase for a replacement.
Rick
May 24, 2010 | Dell 924 All-in-One InkJet Printer
I need black ink for my lexmarkc540n printer
This is the worst printer! i advise everyone not to buy!! changing ink every week!!!!! total garbage!!!!!!
Nov 08, 2009 | Lexmark C540N PROD SPECS TBD Printer
Epson rx680
one ink cartridge is out of ink but...
when we try to replace one of the color ink cartridges we get this error message:
ink cartridges cannot be recognized. make sure ink cartridges are installed correctly - how do I get the printer to recognize my full ink cartridge?
Sep 18, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Canon iP1800 not recognising cartridges
5 flashes says the printhead is not installed properly, you may need a new printhead,
Jul 27, 2009 | Universal Office Ink Tank Cartridge for...
HP DeskJet 712c InkJet Printer Logo
32 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
