Question about Refrigerators
My until stopping sorking meaning no fan running at all 0. I vaccumed the dust off the coils and now the fan runs but the unit is not cooling. The compressor as as a relay that clicks on then clicks off can i fix that myself
    Sergeant:
    Champion:
  • 250 Answers
Usually NO it means the compressor has frozen Not sure if tis worth a new compressor+ labor that will have to be your decision
Posted on Dec 30, 2010
Bryant 4 ton outdoor unit coils got hot fan works Is it repairable. Thx
That's means the coils is dirty .just shut unit off and washed coil with water until clean
Jun 28, 2017 | Bryant Heating & Cooling
Ffa52 hotpoint diamond freezer running too warm
change condenser fan clean condenser coil dust at bottom of ref stopping cooling processes.Just like if you put cardboard in front of your car it will over heat or if fan is not blowing air on condenser coil
will not cool it fan and coil at bottom of ref. remove back you will see the dust pet hair a big problem with ref.
Mar 04, 2015 | Hotpoint Refrigerators
The rubber on the fridge & freezer doors are hot
pull out the machine,remove the front bottom kick plate and then go to the back and remove the back bottom panel,check to see if the condenser fan blade is spinning and check the condenser coil to see if it's loaded with lint and dust.the fridge is running to hot,the way it cools down is the condenser fan blows air around to keep the machine cool and heat escapes through the condenser coil,if it's blocked with dust the heat is held in the coil,a shop vac works great for the coil,vac up as much dust as you can and then set the vac up on blow and blow the dust out of the coil,the coil will either be in the back or on the very bottom of the machine,if the fan isn't running try spinning the blade,it might run or something could be stuck in it,i've found from a piece of paper to a mouse stuck in the blade,if it is the blade you can leave the back panel off and stick a house fan back there to cool down the machine until you get a new motor,if the motor does run after you spin it i would still change it out as soon as possible,if it stops again you could damage the compressor and then it's new fridge time.you should clean the coil at least once a year.hope this helps and next time you need help send the brand name and the model number off of the machine that you need help with
Nov 12, 2011 | Refrigerators
My A/C freezing its coils, while the fans keep running. The AC unit (outside) keep running and never stop caused the coils freezing. It doesn't matter when I turn off or set it to Cool position, the...
Sounds like the contactor in the condensing unit is stuck. That is why it will not turn off when the thermostat is satisfied. If the inside air handler is not blowing and the outside condensing unit is running, then this will cause the inside coils to freeze up rather quickly.
The contactor is located in the outside condensing uni in the electrical compartment.
If it is sticking it will need to be replaced.
Sep 07, 2011 | Heating & Cooling
Poor cooling on frezer and almost no cooling on refrigirator
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator and freezer worked fine until after a power outage. Now the unit will not cool at all, and the fan runs constantly. What should I look for?
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously(non stop fan action) or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Now, Once the coils are cleaned, simply re- introduce power to the unit, and observe for a couple of hours. If the fan continues to run, and there is no cooling affect, this will indicate that the main control aboard(PCB), is damaged. It must be replaced in this case.
Dec 27, 2009 | Kenmore 64802 Top Freezer Refrigerator
Fridge sounds like it is running but it wont cool cleaned the dust out of the back and cleaned the filters
Make sure the compressor fan is running. It is probably underneath the unit close to the back.
Have you cleaned the coils? Do they feel extremely hot to the touch?
If the compressor fan stops running, the coils will be very hot because the heat the refrigerant contains is not being released into the air.
Oct 10, 2009 | Refrigerators
Center of side by side very hot center between doors very hot whirlpool 25 cu. ft
If by the center bar, you mean the divider between the freezer and fridge sections, then the heat you're feeling is the built-in condensation heaters designed to keep moisture from forming on the exterior of the unit. These heaters also help to keep moisture from freezing on the inside of the door edges and in between the sides of the unit as well.
It's a normal function of modern, frost-free refridgerators, Some brands/models have an "energy saver" switch inside the fridge section that you can use to turn off the extra edge heaters, if you aren't experiencing excessive condensation forming on the outside of the unit.
Not all the heaters can be turned off even with fridges that have an energy saver switch, as the manufacturers engineer/determine where and how many edge heaters are needed to get the best performance out of their products.
With an energy saver switch, you turn it "ON" to actually turn off the surface heaters, and turn it "OFF" to have the heaters run constantly. Thus having it "ON" saves the energy that would be used to keep the heaters very warm. Some manufacturers have added electronic sensors to regulate these heaters, but not all makers have done this.
You should also clean the coils to help the fridge run better. As far as getting to the coils to clean them, if you have a long narrow crevice tool with your vaccum, you can try to use that to get underneath the unit to carefully get the dust out. I found that if you move the unit out where you can get to all sides, makes it easier to remove any dust on the back and underside of the fridge. Don't foget that you might have to remove the lower, back access panel to get at the compressor/coil assembly.
Just unplug the fridge first to keep from ruining your spouse's vaccum tool in the cooling fan blade, like I did once and never he-ad the end of it! (Not to mention the noise it makes - brought her running to see what I was doing!)
If that isn't possible, you can always use the blower end of a vaccum to blow out the coils, but it's a messy proposition at best. I've used a swiffer taped with some duct tape onto a long, thin dowel to get quite a bit of the dust the vac couldn't $uck out - I prefer that to blowing dust out as it's less messy.
Provided your fridge and freezer are cooling properly, you shouldn't have any issues with the warm center compartment divider causing you any problems.
Hope you find this Very Helpful and best regards!
Sep 17, 2009 | Whirlpool Refrigerators
DOOR JAM BETWEEN FREEZER AND FRIDGE IS GETTING HOT
This usually means that your condenser fan has stopped. That's the fan outisde (under or in back of) the fridge. It should be running whenever the compressor runs. Heavy accumulation of dust or anything that obstructs airflow could also cause it. But the most likely culprit is the fan.
Nov 05, 2008 | Frigidaire Refrigerators
Drain pan fills daily
does drain pan have copper lines it
Feb 12, 2008 | Viking VCSB483 Side by Side Refrigerator
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
