Question about Dryers
No heat from dryer
Heating element has been checked and is okay. Power is going to all the relays and switches. fuse is good. still element will not heat up.
    Scholar:
  • 148 Answers
Is it 220 volt dryer,if so check the plug at the wall and make sure you have 220,the plug runs off 2 circuit breakers at your electric panel,1 breaker may be no good so your only getting 110 volts to the dryer which will run the dryer but not the heating element
Posted on Jul 08, 2008
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: my dryer is an estate whirlpool dryer does not
I'm assuming from the symptoms you posted, that the dryer does run, correct? If so, the fuse box may have checked out, but have you also checked for the correct voltage at the wall receptacle? A dryer will still run, but will not heat, if its missing a portion of the input voltage. The reason is that the drive motor only uses 120VAC to run, while the heating circuits need the full 240VAC service. If you are missing one leg of the input voltage, the dryer will exhibit the symptoms you describe. In addition, depending on when your home was built, some houses use two separate breakers that feed the 240VAC source the dryer needs to run. Have you checked to make sure there isn't more than one breaker that feeds the dryer? If you have checked for the correct voltage, have you also checked the continuity of the power cord to the terminal block? A broken power cord can give the same symptoms.
If the model number is correct, this is a very simple dryer to work on. There are no other switches or relays, other than the door switch and the built in centrifugal switch inside the drive motor. If the door switch were bad the dryer would not run at all. If the centrifugal switch in the motor were bad, the dryer may or may not run (depending on how it is faulted), which may give you the symptoms you describe.
When you checked the components, how did you determine they were good? If you need assistance (just to clarify your measurments), the following two links can give you some tips on how to troubleshoot this problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
http://www.fixya.com/support/r3574266-thorough_dryer_advice
I hope I'm not insulting your itelligence. I ask these simple questions, because they are things that can easily be overlooked. If you need further assistance, please post back and elaborate a bit more on your symptoms, so i can provide you with a more definitive answer. I hope this information was helpful to you.
Posted on Jun 30, 2010
The air is cold and dryer is turning
If it's electric, could be timer or heat level selector switch, a relay to heating element, the heating element itself bad or the overheat thermostatic switch has failed. How old is the dryer? A lightly used replacement may be less than the repair technition and parts.
Feb 13, 2015 | Dryers
I have a Sears dryer, model # 110.87562601.
#1 reason of dryers going bad is woman's bra's....the medal sewed in the cloth itself for support comes out and goes into the small holes and hits the heating element on both sides and shorts it out...Change the heating element....It's in back of dryer.
Oct 06, 2017 | Kenmore Dryers
My GEQ9800 dryer will not start. Start relay switch is good, timer is good, thermal fuse is good, door switch is good, input power is good. Nothing happens when you hit the start switch.
Is it plugged in. Seriously,
what about the heating element, have you tested it?
here is a link to replace it if it's bad
http://www.ehow.com/how_2240320_change-heating-element-dryer.html
Sep 30, 2011 | Whirlpool Dryers
MLE24PRAW We replaced the heater relays multiple times on this dryer and the dryer works well, but there is still no heat coming from the element itself, but everything has continuity across it. The...
You must check for 220 volts at the element while the dryer is running. If all the thermostats and relays are good as you describe the the centrifugal switch on the dryer motor is bad or the timer lead to the switch is bad.
Aug 24, 2011 | Maytag MLE24PRAyW Dryer
Electric dryer spins no heat, replaced heater element and high limit thermostat, tested thermal fuse and it does have 0 ohms, thermistor reads ~50 ohms.
in addation to checking the high limit t-stat have you checked the thermal cut off (the small t-stat) on the heater housing where the element fits into, the high limit t-stat and the thermal cut off BOTH shoud have 0 ohms (the thermal fuse is in the blower housing) the cut off is on the heater box, if you have checked those to be good, check that the heat relay on the control board is closing and sending power to the element, if not replace the control, if all above are good then the motor switch is bad and not sending power to the element(thats a built in safety feature so the dry would never heat when the motor isnt running)the element of course heats only when 240 volts ac is to the element ,120vac from the relay on control through the high limit t-stat then through the thermal cut off finally to the element and 120vac from the motor switch for a comined 240 vac
Jul 20, 2011 | Kenmore Dryers
My dryer is turning but the clothes are not drying. There is no heat in the dryer.
Check the dryer heating elements that they are intact. You will have to open the back. Chek for fuses in the dryer. Good luck
Jul 02, 2011 | Dryers
My Kenmore 400series 6942 electric dryer works, but doesn't get hot. Pulled the heating element had it tested. It shows good. Had three other relay/fuses tested. They show good. It has to be easy enough...
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpg if there is no heat then one of the thermal fuses is bad you will need to check the continuity on them and replace the one that does not have any continuity
Jan 20, 2011 | Kenmore 400 6942 Dryer
Kenmore dryer runs but no heat. I have ohm checked the heating element, all thermostats and the thermal fuse. All ohm okay. I also checked voltage throughout the circuits from the main block to each...
Did you read ~220 volts AC across the two slanted blades of the power socket? The motor and controls usually run on 115 volts. When the timer is set to dry, press start, and look for ~220 volts at the heater element connections. (Don't let the heater reach full heat if it starts working!) You may have to short the door switch connections to get the unit to run. If you don't read 220 volts at the plug, check the output from each breaker of the dryer pair (should read 115 volts to neutral). Hope this helps!
Oct 09, 2010 | Dryers
No heat in dryer model # 96591420
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 31, 2009 | Kenmore Dryers
My kenmore electric dryer is not heating I checked the heating coil and it seems ok could it be one of the thermostats?
Kenmore style dryer - no heat problems:
Electric dryers - See the "how to take apart" section first if needed. Always check the power supply first...if one house fuse blows or 1/2 of the breaker trips, it is possible for the dryer to run with no heat. If you have a volt meter, you should read 240 volts between the red and black wires, 120 volts between the white and black and 120 volts between white and red, check for this at the main power connection. If you have 240 volts to the dryer, remove rear access panel, turn dryer on and test for 240 volts to the *heating element wire connections (#4). If you have 240 volts there and no heat = bad element, the element must be broken physically to be bad. If you have no power at the heating element, remove power, remove wires to the heating element and isolate them so that they can't touch anything. Reinstall power and check each wire for power from the wire to the dryer cabinet, one wire will probably show 120 volts and the other will show zero. Make note of the color or # of the wire that has no power, remove power to the dryer and check the wiring diagram that comes with the dryer to find out where that color or # wire goes to. EG: - wires might be yellow and red, if the yellow wire (example only) was the one that had no power, look at the wiring diagram to find out where that goes to and check only those parts, no need to check the other colored wire parts as they are working. Things to check are, *thermostats, timer contacts, selector switch, motor switch heat contacts ( 1&2 on the motor switch ) and *thermal fuse. If the wires to the heating element are the same color, just remove power after test and slowly follow that wire that has no power with your hand to see what parts it goes to. If live volt testing scares you, try the ohm checkinstead.
*#1-Thermal fuse that controls heat. If the dryer overheats, this fuse will blow. One shot fuse. Does not reset.
#2-Canister for the heater element.
#3-Hi limit thermostat. This thermostat is a safety thermostat in case the dryer severely overheats. When this safety thermostat is defective, it should raise a red flag for air flow problems.
#4-This is the terminals of the heater element that is inside the canister.
#5-Thermal fuse that controls motor run.
#6-Control thermostat. This is the thermostat that controls the cycling of the heater in high heat mode.
#7-Heater for low heat. When you select low heat, 110V is sent to this heater that the control thermostat sits in. The heater helps cycle the control thermostat faster, therefore you get less heat than the high heat mode.Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Jul 11, 2009 | Kenmore 62602 Electric Dryer
Dryers Logo
87 people viewed this question
Top Dryers Experts
