Question about Kitchen Appliances - Others
I have a micromark mm52117 and the water tap/faucet has broken and i need a spare one so can fit it,
2 Suggested Answers
  • 57 Answers
SOURCE: I am replacing the kitchen faucet in an rv. The
Have you checked with Lowes or Home Depot ? They should have an adapter that you can use.
Posted on Apr 17, 2010
The handle on the Ideal Standard single faucet in our kitchen fell out.
All sorts of things come to mind. Get on your computer and track the company and see if they offer replacement parts or an upgrade. Looks like you'll need to drill the hole and retap the threads. OR go down to a Michael's if you have one or any place that would sell wooden dowels. Find one that is a tad larger and whittle it to fit the hole. Use teak or something strong. It won't look stock but if you do it nicely you can stain the wood and make it look good, spray some clear on it to make it water-proof. You can also try running a tap through the threads to see if the threads can be repaired. Long shot but if you are on GREAT terms with the Powers, a small miracle would be nice ... but it CAN HAPPEN> I have run taps through some beaten threads and they have come back to life. The last option would be to have a machine shop make another steel dowel but thread it for the next size up and drill and tap the hole to match.
Dec 12, 2014 | Plumbing
Leaking washing machine faucet adapter
fit the rubber washer into the adaptor that seals off on the tap face
can be obtained from any garden tap fitting
Jan 24, 2018 | Washing Machines
My new Ladylux appears to have an aerator, but it's doesn't work worth a hoot! All other brands of taps have properly functioning aerators that keep the water from splashing , but this one splashes...
if its new you should,nt have had to have spare parts fitted,sounds like the tap is faulty,take it back and have it replaced.if you change it and theres still a problem it looks like you might have to change the model
Nov 08, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
I just installed a new Monsoon mixer tap with a single lever that lifts backwards for water pressure and swivels from side to side for temperature control. While the hot water side of the tap works 100%...
Start with the pipe that extends out from the wall where you hooked up your cold water connection.
Get your self a large container and many rags or towels.
Gently loosen the connection to see if there is any water coming out of the wall pipe.
If not, there is your problem.
If so, you have something plugged up or wrong with the hose or the faucet.
Remember, normally a person will turn off the water at both valves under the sink when the replace a faucet.
Those valves are where most of your connection hoses go.
A valve can be broken or stripped, so that it will not turn on after you have turned it off.
God bless your efforts.
May 26, 2017 | Home
Does anyone know where I can purchase spare parts for a Micromark storage heater? I need the control knobs to replace the missing ones.
DEAR SIR
please search it near of your micromark area dealar you can buy it from there , and for know the micromark dealer location try to find it via internet then you can know it,s location .
hope answer the question
thank you
please vote !
Sep 15, 2010 | Heating & Cooling
The entire faucet is lifting off and spraying water at the joint when the lever is activated and water is being used,do I need to call a plumber to repair this. It seems that the faucet cannot be screwed...
No you do not need a plumber,
below under the sink, there are two valves, One for Hot ,One for Cold.
Turn them to the right.make sure they are turn all the way with a little pressure at the end. Now the kitchen has no water.
With a wrench ot pliers remove the water hoses, There may be a little water left in the hose so don't panic.
Now this may be a little harder.
Put yourself all the way under the sink,with you on your back.
Do you see the taps. There may be a fitting with screws. remove screws and fitting. You should be able to remove the whole Tap.
With you new tap... Follow their instruction.
When you are putting the hoses back on.. make sure they are slightly snug.
We don't want it to leak again.
Turn you water back on and slowly turn on your taps.
Aug 05, 2010 | Rohl A3608LMAPC Single Lever Country...
Hot water not coming out like there is a blockage hot water dispener on the same line works great
Kitchen faucets have a cartage inside that can get clogged from sediment and minerals in the water. clean out or replace cartage.
Mar 28, 2010 | American Standard Kitchen Faucet 6310 020...
I just replaced the cartridge, spacer, check valves and oring that sits on top of manifold and water still leaks within body of faucet. any suggestions?
SOUNDS LIKE A LOOSE FITTING , INSPECT UNDER THE TAPS FOR ANY LOOSE FITTINGS AND TIGHTING THEM UP WITH A AJUSTABLE SPANNER UNTILL WATER STOPS LEAKING.
Nov 11, 2009 | American Standard Kitchen Faucet 6310 020...
Shower mixer taps
look for a scald safety screw adjustment. Remove the handle, and it is underneath. this is for safety of young children, and is factory set.
Dec 23, 2008 | Price Pfister Ashfield Single Control...
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
