Question about Toshiba Computers & Internet
My laptop toshiba tecra A 3x bip on start up. Full scan disk not work and give me wrong information like.. "a key was pressed". Probably there are a damage key. How can I check wrong keys ?? Thanks in advance Luis
  • Toshiba Master
  • 4,338 Answers
Look between each key, see if there is a foreign object stuck in the keys.
Look from the side of the laptop, check if all the keys are raised evenly acroos the rows.
Open Wordpad, if you can get into windows, then hit each key several times. you should be able to figure out which is the culprit.
The only other thing would b to take the keybd out and reseat the cable.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.Ten un pr?spero a?o nuevo !
Gracias, Jose
Posted on Dec 30, 2010
Testimonial: "Thanks Jose for you valuable support to my toshiba A3x Feliz 2011 cheio de sucessos Luis"
  • llucas951 Dec 30, 2010
    Hi Jose
    Thanks for your support about my toshiba A3x
    Regards
    Luis
I have a Toshiba Laptop and the keys are not working properly. When I press shift 2, the symbol " is shown and I can only get @ by pressing alt button along with ctrl and 2. please help. same goes...
your laptop needs service by a qualified tech
1. it seems that you have possibly a keypad controller or a loose keypad cable which will require disassembling the laptop.
Please give detailed information as to your issue to better assist you in your resolution of the problem you are having.The more information given will help determine the resolution and guide you to the proper fix for your issue.
Thank you.
Jun 14, 2011 | Toshiba Tecra A9-S9012X Notebook
My Toshiba Tecra 9100 gives me an error message of PXE-E61: Media test failer, check cable. Then it says PXE-MOF: Exiting Intel PXE.ROM. It's asking for a system disk, but this was given to me and I don't...
The error message is caused by a failed hard disk. Replace that then borrow a Windows install disk from a friend and install with it and the key on the sticker.
Mar 17, 2011 | Toshiba Tecra 9100 Laptops
HELP ME
UNMOUNTABLE_BOOT_VOLUME = the BIOS tries to load Windows and can't find it. Either the hard disk has died and must be replaced or Windows was completely corrupted by malware. In either case you must do a full reinstall and load a better antivirus,  and if it happens again you will know that the disk is dead, replace it.
Jul 27, 2010 | Toshiba Tecra A1 Notebook
Format the laptop
Several Problems.
First, sounds like you need to reinstall your operating system. Place your original system disk in. F8 to be sure that it starts from the CD. Be sure to "Press any key to start from CD". At that point you can either repair or reinstall your operating system. Repair will be not destructive to your data files. Reinstall will reformat your drive before reinstalling.
Your keys not working could be a number of things. A broken key requires keyboard repair or placement while dirt or grit can give the same symptoms. Try cleaning with the computer off...Blowing air around the problem keys. Be sure to use clean air, the canned stuff. Try not to blow the dirt under another key.
good luck
Feb 22, 2010 | Toshiba Tecra M1 Notebook
Lcd and hard ware
The problem seems to be in the BIOS please upgrade it by calling any tech because it is a very risky process if something goes wrong then laptop can be dead.
Feb 11, 2010 | Toshiba Tecra A3 Notebook
Hi sir I have to problems for my Toshiba Tecra AC laptop 1. The LCD screen some times it starts and when u shutdown and start the laptop its not working 2. I installed a new hard disc and try to load...
Need to reinstall my machine but don't have product key for laptop toshiba tecra A5
The product key should be on the bottom of your laptop.
For most Toshiba laptops tapping on the "zero" (0) at the toshiba splash screen on start up will start the "factory restore" process.
This process will not work if you have replaced or reformatted your hard drive.
Jan 20, 2010 | Toshiba Tecra A5 Notebook
I had a Thoshiba Tecra A3 Laptop nwhich is not loading OS
When you hear about the long beep it is a RAM problem which is not totally inserted. You need to check the RAM remove and reinsert it again and try to power on.
Dec 13, 2009 | Toshiba Tecra A3 Notebook
Toshiba qosmio E-10 noises keyboard and start up
Sound like you have a stuck key and the bip noise is the keyboard buffer pverloading.
If you can't unstick this key, you need a new keyboard.
Apr 13, 2009 | Toshiba QOSMIO E15-AV101 Notebook
Computers & Internet Logo
124 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
