Question about Dryers
Where is the termostat located on the samsung dryer DV218ES?
  • 32 Answers
The thermostat should be located inside the rear cover. Undo the screws and open the cover. In dryers when the thermostat doesn't work it normally needs to be reset by pressing a small button on the thermostat housing.
Posted on Dec 30, 2010
Termostat
What's your model number?
Apr 11, 2014 | Whirlpool Dryers
Location of the termostat on a 2001 catera
its under the top part of that intake right behind the timing case. for some reason they felt the need to hide it
Apr 18, 2013 | 2001 Cadillac Catera
Where I's the ignitor located on my samsung dryer?
It is located inside the dryer cabinet.
Feb 06, 2012 | Samsung Dryers
How conect termostat
The thermostat is located where it leaves the upper hose going to the radiator and remove 2 screws in that box is located the thermostat
Jan 09, 2010 | 1993 Dodge Caravan
Kenmore dryer has will not heat up to dry
IT SOUNDS LIKE YOUR HEATING ELEMENTS HAVE BURNT OUT FIRST TURN OFF POWER THEN LOCATE THE SCREWS HOLDING THE BACK PANEL ON REMOVE THEM AND PANEL YOU SHOULD SEE THE ELEMENT REMOVE IT FROM THE PLUG I WOULD ALSO SUGGEST YOU REPLACE THE TERMOSTATS AS THE TEND GO THE SAME TIME OF ELEMENTS TAKE THEM TO A ELECTRICAL AND PLUMMERS SUPPLY STORE FOR REPLACEMENT REFIT TO YOUR MACHINE AND IT SHOULD WORK FINE , GOOD LUCK .
Nov 30, 2009 | Dryers
My kenmore dryer wont git hot
may be your to hot... lol..zzz. heat element,or termostat are defektive...
Oct 29, 2009 | Kenmore 63942 Dryer
Need to replace thermostat
USING A PAIR OF PLIERS RELEASE HOSE CLIP AND DISCONNECT THE HOSE FROM THE THERMOSTAT HOUSING LOOSEN AND REMOVE THE THERMOSTAT COVER BOLTS AND CAREFULLY THE TERMOSTAT COVER AND WITHDRAW THE TERMOSTAT FROM HOUSING REPLACE NEW TERMOSTAT ,RE FITTING IS THE REVERSE OF THE REMOVAL, BEARING IN MIND IN THE FOLLOWING POINTS ENSURE THAT THE THERMOSTAT IS CORRECTLY LOCATED IN THE HOUSING AND FIT A NEW SEALING RING .
Oct 24, 2009 | 1996 Volkswagen Passat
My maytag pyet344ayw dryer will turn on but no heat comes out
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Oct 24, 2009 | Dryers
Dryers Logo
129 people viewed this question
Top Dryers Experts
