Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
When brewing small amount of strong coffee of a few oz come out only. I cleaned all movable parts and still doesn't work
  • 452 Answers
Grinder problem needs stripping ,,,,bsc appliances 07779933829 postal service too
Posted on Feb 26, 2011
I get lots of watered down coffee. It brews 3/4 cup but it is so watered down. We have descaled etc. I want a thick expresso like taste. This is on a large cup setting Help?>
HI
When you run a lot of water through just a little coffee it gets water down. Try making 2 meduim cups instead. When they make espresso its 1 tablespoon to 1 oz of water. Your running 6 oz of water through the same amount of coffee, and its going to be weak. Program you buttons for 2 shots to fill your cup and it will be pretty strong.
Jan 25, 2011 | Gaggia Syncrony Espresso Machine
How many ounces or cups of ground coffee is standard for a Bunn dual dbc to make a 1/2 gallon of brewed coffee?
For a half gallon of brewed coffee you should start with a "volume" measure of 10 oz. The reason I recommend a volume measure is because the weight could be completely different using light roast or dark roast coffees. Brewing by volume you can have consistency throughout. The main object is to have the same surface area of grounds for your brewing. The 10 oz. volume should equal between 3.75 and 4.25 ounces by weight. Adjust by taste to your palette but don't sway too low in amount of grounds, otherwise you will stand to "over-extract" and your coffee will taste bitter and will have no body or mouth-feel.
Oct 12, 2010 | Bunn Dual SH DBC
I am interested in purchasing this 6 cup brew station, but all pics I see use travel mugs. Can it be used with regular 10 -12 oz ceramic mugs for home use? How about 6 oz cups that match Corelle...
How does the coffee get into the cup? If it brews directly into the cup then the amount can be controlled by how much water you put into the maker. If it is a 6 cup then it must hold the coffee in a reservoir. Do you have to push and hold a button to dispense the coffee or do you push and wait for it to fill your cup? If it is the latter then it will need to know how large or small the cup size is. Is there a setting for that? If it is a push and hold method then you control the coffee flow so size is up to you. As far as it being a travel mug or ceramic mug as long as the mug will fit in the maker and sit securely under the nozzle then it shouldn't matter what kind of mug it is.
Feb 20, 2010 | Hamilton Beach 48274 BrewStation 6-Cup...
Coffee is too weak
I just spoke to someone at customer service. My coffee has been weak and kind of thin. We had the Superautomatica by Saceo for years and I remembered the coffee being richer.
Anyway! The person suggested that I adjust the grind but slowly. So set it to the coarsest setting, brew 2-3 cups. Then put it to the 2nd-coarsest setting, brew 2-3 cups. To the third, brew 2-3 cups. To the forth, brew 2-3 cups. Etc. Until you're at the finest grind setting. Again, brew 2-3 cups. An awfully sensitive machine. It seems to have worked although the last few seconds of brewing continue to be a kind of milky colour (as opposed to a deep black coffee colour). You can, though, press the "cup" button to stop the brew. So once, it starts running milky, you can stop the cycle.
I hope this helps. I know I've been struggling and cursing the machine for a while :)
Dec 30, 2009 | Saeco Odea Giro Plus Coffee Maker
I Have a Cuisinart Automatic Grind & Brew Thermal that when you start brews a small amount of coffee and then shuts off. I shut off grind and start. After I do that it brews a full pot. We have cleaned...
I do love our Cuisinart pot...but find they only last 2-3 years...so my suggestions is: if the pot is still in warranty, call Cuisinart for a new one...they are great about it. If you don't know if it is still in warranty, call them, give them the number and they will tell you.
jlo
May 30, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I HAVE A BUNN COFFEE MACHINE THAT IS SUPPOSED TO BREW 69 OZ OF COFFEE AUTOMATICALLY BUT IT IS BREWING MORE HOW DO I REDUCE THE AMOUNT OF WATER ITS BREWING. IT IS AN S SERIES
Inside of the front cover is a brew timer dial turn this counter-clockwise a little bit, then try brewing another pot. re-adjust as needed. Just watch where you put your hands in there.
Oct 24, 2008 | Bunn NHB Coffee Maker
I have a cuisinart model dgb-600bc coffee grind & brew, didn't have a manual with it when purchased, plugged in it & hit the on button, lights up when pushing in on it, but let it go & it stops, but doesn't brew nothing. HELP -
Aug 26, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Delivers only small amount of coffee per brewed cup
this is not a scale issue, mine arrived from the factory producing only 6oz of water. way to strong for most. called the factory, scale, scale blah blah blah, vinegar untill we were blue. bored one day took the unit apart. on the right hand side there is some clear tubing which housed a one way valve, took apart and the valve was partally clogged. removed cleaned and reinstalled, this valve works best when not fully" seated" where it belongs so reinstall gently into the hose and leave it alone. I know what your thinking scale, scale scale. wrong. still only made 6 oz cups. there is a timer device on the back wall of the front panel on the right side as you face the unit. it is adhered to the wall with two sided tape. pry it off and on the back low and behold is a timer screw that changes the length of pump run time. turn clockwise with a sharp knife or eyeglass screwdriver and retest. 9oz of water. shame on keurig for not being more responsive to its customers.
Jul 23, 2006 | Keurig B100 Coffee Maker
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
131 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
