Question about HP L1906 19" LCD Monitor
HP L1906 screen flickers and then goes blank. Switch off then on and it comes back on briefly
  • 11,361 Answers
Look for bad caps and solder joints.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 31, 2010
Hi i have a problem in my hp lcd screen.Its HP L1906 (19'') ,the problem is that the Main menu pops up without pressing the menu button .And a black phrase in a small white box in the middle comes...
Press the menu button and navigate until find "factory reset" and select ansav/exit.
If you need more help post back!
Thumbs and testimonial are welcome!
Jul 08, 2011 | HP L1906 19" LCD Monitor
1) when i switch on my hp L1906 19" LCD monitor display comes for 2 sec. or 3 second then it goes blank. then i have to switch off and again switch on but problem remain like that... 2) in my second...
this question is posted here 100 times, search much.
the CCFL tubes are burned out
as all do ,every 20,000 hours, 5 years old if run 10yrs a day.
all do,
until 2010 when LED BACKLAMPS HIT THE STREETS
POST 101.
Also the internal power saver must be turned off.
menu button, turn it off. on OSD
Jan 26, 2018 | HP L1906 19" LCD Monitor
Turn the monitor on screen displays for 2 seconds then goes blank ... no further display until powered off then on again ... is this a fixable problem or fatal ?
Look for blown caps with domed top in the power supply/inverter board: There are two versions
http://lcdalternatives.auctivacommerce.com/Search.aspx?k=HP+L1906
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 26, 2011 | HP L1906 19" LCD Monitor
Se198wfpf lcd does not stay on screen briefly
It could be the high-voltage inverter board, I case of a faulty backlight (one of the tube flickers) the board would protect itself by powering off. Try changing one of the CCFL tube.
Oct 29, 2009 | Dell Computers & Internet
HP L1906 lcd monitors won't display anything
Yes you got badcaps!!! www.badcaps.net examples of what they are and what they can do and this is one of them. U/You can change out these caps and see if it fires back up again.
Even bulging caps are still issues I just fixed a emac with bulging caps as the emac would freeze not when i put in the new caps the ****** is doing great!!!! I would suggest you do the same.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 26, 2009 | HP L1906 19" LCD Monitor
HP L1906 Flat Screen Monitor Power Light Flashing
http://www.fixya.com/support/t558081-monitor_will_not_power
Jun 01, 2009 | HP L1906 19" LCD Monitor
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
X20G-Naga III screen goes blank after 1-2 secs
FIXED!
Device : Spectra X20WG-Naga
Problem : monitor comes on then flickers then goes off
solution: Replace Capacitor C101 (150uf, 35V) and Fets U101 and U102 (4511GM)
Comments: This is a common problem with this monitor.
I’m happy to help further over the phone at https://www.6ya.com/expert/paul_0af9b1d5c0eb4fc3
Oct 02, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
Dell Latitude cpx
Symptoms of a Bad Video Driver
Monitor Resolution issues:
screen flickers, screen is cloudy, screen shows horizontal lines, screen goes black, goes blank, goes into sleep mode, goes into power mode, size magnifies or reduces, video is jittery, fonts change, screensaver will not appear, cannot extend display on dual monitors.
Download it from here
VIDEO DRIVER FOR LATITUDE
May 28, 2008 | Dell Latitude CPX Notebook
HP L1906 19" LCD Monitor Logo
210 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
