The tv can turn on pressing the power button, and the screen has a white flash, the speakers are working, but i can't see anything but black.....I think it might be the brightness, but im not sure.....
    Genius:
  • Televison & ... Master
  • 1,689 Answers
This can be from the power supply, high voltage section, or the CRT bias circuits. There are many things that can cause your description. The set would have to be serviced by an experienced TV tech.
Jerry G.
Posted on Jul 07, 2008
My flat screen Sylvania TV is flashing different colors what's wrong
Better late than never. The problem is that your TV is in the service mode. There are many ways this can happen. But, lets just get down to fixin this! With the original remote and the TV on. If the TV will not shut off, do this. Press the left cursor button on the remote, followed with pressing the right cursor. Power off the TV with remote, or press off button on TV.
Secondly, your TV will power on and off. But you have flashing colors. Do this. With the original remote and TV on. Press the up cursor button, on the remote, followed with pressing the down cursor. Power off TV with remote, or press off power of TV. Thanks for asking me, Matt of Martins TV Repair.
Jan 20, 2016 | Sylvania Televison & Video
My brand new flat screen haier tv 39'' is flashing white then red green then blue and black screens how do i fix
Try to disconnect the set and a box if being used from power for a while and then power both back as either could cause this problem.
Dec 15, 2012 | Haier Televison & Video
I fell asleep on my Emerson LC320EMX 32 hdtv remote; when I awoke, the tv was flashing ONLY colors (red, black,blue,white)...Now, How do I get it out of that mode....I was told its stuck in set-mode ?
I had this problem with the LC320EMX, after extensive searching on the internet, I found a solution. The TV has entered some kind of test pattern, to escape from the flashing color test pattern do the following:
While the screen is changing from red,green,Blue,White, & Black, and is Unresposive, Take your factory remote, Press the up arrow, then the down arrow, then (ON THE TV) press the power button. Turn the set back on and it should be functioning properly. (BTW: the set gets into this test pattern if you press too many buttons on the remote, or if you use a universal remote with the wrong code)
May 31, 2012 | Emerson LC320EM8 32 in. LCD TV
I am trying to program my "Direct TV" remote to my Samsung LCD TV Series 5 and can not find the 5 digit code needed to do so.
If you have a DIRECTV white remote, press "menu" then "settings," "setup," "remote", and follow the on-screen instructions.
If using a gray or black remote,
  • Make sure your TV is turned on.
  • Slide the mode switch at top of remote to "TV".
  • Press and hold the MUTE button. This is located above the number 1 button.
  • While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  • Then enter 9911, the green light on remote should flash twice.
  • Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  • When the TV powers off, press and release the SELECT button.
  • Sep 07, 2011 | Televison & Video
    I have a sharp LC-42CT2E TV which will not turn on. I have turned the tv off with the switch on the tv and at the socket. When the power is connected the led white light at the front of the tv comes on for...
    I have the same model with the same problem.After searching for solution to this problem for months I finally found the fault. One of the speakers was
    faulty, you will not believe it but change the speakers and the problem will be fixed. The speaker cable is red/black white/black.
    Apr 16, 2011 | Sharp Televison & Video
    White screen on TV.
    My TV does this too. i know how to remove the white screen but the top will still have power only vo4.52.00 to get rid of the white screen press 'return' on your TV remote (not direct tv remote) then change the input pack to whatever it is it needs to be on to watch your (whatever)
    Apr 24, 2010 | LG 32LH30 32 in. LCD HDTV
    TV or control doesn't work need help know
    ok my tv is doing the same thing and i need help if you found a solution please email me at pieces41096@aol.com
    Jul 06, 2009 | DISH Network 322 DTV Receiver
    Tv2 light does not come on
    hi hammonhph! I will be more than glad to assist you in this concern. Lets program the remote for tv2, lets make sure that the battery's are brand new, please go to the front panel of the receiver, make sure that u have the remote2 with, turn on the the tv1, you got picture, on the front panel of the receiver, you got 1 green and the blue light is off.. push the power button on the front panel of the receiver once to turn off the green light, once its off the tv will show a black, blue or snowy screen, push the up button on the fron panel of the receiver until it shows the system information screen, look for the primary and secondary remote address, primary and secondary remote address should show a number on the white box ex.. 1 and 1 on the green box, secondary is ex 2 on the white box and 2 on the blue box, how to reporgram the remote to the receiver.. press and hold the sat button and wait until all lights lit up, once it all lit up, release it and press any number from (1 to 15) but for this ex is press 9, then press the pound button (#) that is under number 9, once you press the pound button the sat button will flash 3 times and then press the record button once, record button is under the cancel button or view tv button, once you are done check the secondary remote address, it should be 9 on the white box and 2 on the blue box, save the settings by using the remote 1, selct done on the screen and it will go back again to black, blue or snowy screen, press the sat button once on the remote 2 and the big red power button, the blue light should turn on, just in case the blue light dont turn on, press the power button on the front panel of the receiver for 10sec to reset the receiver, it will acquire the sat signal and go to a progress, and it will download the programming guide, check if blue light is not on, press the big red power button on the remote2 to turn on the blue light and it should work. if just incase the blue light dont turn on, the remote is bad and you need to call 1-800-333-3474 for the replacement of the remote..please feel free to get in touch if you have any query..
    One of our TV's was being accessed by someone in the neiborhood. I found in the manual how to change the remote code. After doing this the TV is locked on one channel. I did reboot. The remote is working...
    Hi! I will be more than glad to assist you in this concern. Lets Isolate the problem, press 1st the sat button once on the remote that is giving you a problem. the sat button should light up and check if you could pull up the guide or can change the channels. if there is still no response, bring with you the remote conrtol that is giving you a problem on tv1, turn on the tv and it should show a picture, go to the fron tpanel of the receiver and press the power button once to turn off the green light, once its off, the tv will go into a black or snowy screen, press the up button on the front panel of the receiver until it shows the system information. look for the primary and secondary remote address, ex, primary remote address is 1 on the white box and 1 on the green box, secondary remote address is 2 on the white box and 2 on the blue box, how to reprogram the remote, press and hold the sat button on the remote that is giving you a problem and wait until all lights lit up, once it lit up release it and press any number from 1 to 15, but lets choose 9, then press the pound button (#) that is under number 9, once you press pound button, the sat button should flash 3 times, then after it flash, press the record button, that is under the cancel or view tv button., you will notice that the secondary remote address was change from 2 to 9. to save the setting, get the remote1, select done on the screen and it will show a black or snowy screen. to check the remote 2 if it works, press the sat button once and the the big red power butto, the blue light should turn on if there is no blue light but there is, the blue light will turn off, then before you go to the tv2 location make sure that blue light is on and then check on the tv2 location if you could change the channels now. just incase that the problem is still there, check the remote antena on the back of the receiver, make sure that its on the upright position to broadcast the uhf signal properly.. that should fix the problem. if just incase the problem still exist, call 1800-333-3474 ask for a replacement of the remote..pls feel free to get in touch..if you have any query
    Jul 04, 2009 | DISH Network 322 DTV Receiver
    Canon A630 screen black
    Turns out my husband must have pressed a button by accident. The bottom left button says "disp" for display. Pressing that fixed the screen!
    Jun 24, 2009 | Canon PowerShot A630 Digital Camera
    Open Questions:
    Televison & Video Logo
    29 people viewed this question
    Top Televison & Video Experts
