Question about Micro Innovations IC014C Webcam
I installed and connected the micro IC014C to pc, "Windows XP home". I cannot get the mic to work, not sure where the second lead connects to, the green or red input jack on the back of the pc..???
2 Suggested Answers
  • 14 Answers
SOURCE: Can I install the Micro Innovations IC 100c with Windows XP
Yes use you disk or:
Put this in you browser. Click on download and follow instructions.
http://www.driverfiles.net/Cameras/Micro-Innovations/IC100C/download/page,sh,36525,298,17,.html
Posted on Jan 09, 2009
Is there a user manual for the IC014C webcam? If there is where can I get/find it?
check those links
http://www.microsoft.com/Windows/compatibility/windows-7/en-us/Details.aspx?type=Hardware&p=Micro%20Innovations%20IC014C%20VGA%20Webcam&v=Micro%20Innovations&uid=IC014C&l=en-US&pf=0&pi=5&c=Cameras%20%26%20Photo&sc=Webcams&os=32-bit
Mar 07, 2012 | Micro Innovations IC014C Webcam
The microphone on my ic014c webcam won't work!
if the microphone has a second cable with a jack plug ..than you have to use it in the pink inlet on the sound card ..and will work ..or in the mic in of the laptop ..
If there is no second cable (split cable ) with jack plug ..it means the mic is using the usb ..and in this case you have to get to the sound settings and select the usb for the mic ..Also select the usb for each instant messaging programs you use..to d that just open the program ...get to the tool options ..and select sound devices and under mic select the usb instead of regular windows default or sound driver ..
Dec 23, 2011 | Computers & Internet
Where do I find a driver for my micro innovation web cam mod.cm10401 that will run on windows 7?
If there was any webcam drivers that were loaded earlier please uninstall them . Now connect the webcam and see if the cam is detected. If not check using the nearest driver for XP available on this link, if not contact support center of the maker to clarify:
http://members.driverguide.com/driver_search.php?q=cm10401&si=229cc9d99a32632e8388cf050acdb011&st=1318674736&gqm0=cm10401
Oct 15, 2011 | Micro Innovations IC014C Webcam
Hp pcdc7600s but speaker mic not working
troubleshooting steps -
*try testing a differnet mic/headphones
*open the casing to check that they are connected to the board correctly
*make sure if you are using a windows home edition or any windows under xp that you may have to download the drivers manually.
*im using windows XP professional and no issues with sound.
Nov 03, 2010 | HP Compaq dc7600 Small Form Factor PC...
I bought an MSI webcam IC014C and not sure where to connect to. I know one connection is USB but what about the other.
It has a built in microphone so the other connection needs to go into your mic input jack/hole
Oct 30, 2010 | Computers & Internet
Is the IC014c Web Cam compatible with Windows 7?
yes can be, just follow this:
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Sep 28, 2010 | Micro Innovations IC014C Webcam
I have a mi webcam model IC014C does it have a built in mic?
Yes, the Micro Innovations IC014C 2MP Basic Webcam has a built-in microphone.
Jun 16, 2010 | Computers & Internet
Need driver for Micro Innovations CIF Single Chip IC014C web cam
HI,
http://www.mic-innovations.com/Support/Drivers.aspx
I take it you installed the Driver Pack.....try also installing the Software Installation Pack.
Here also is the link for the Installation Guide and Manual, always worth reading....
http://www.mic-innovations.com/Support/Documents.aspx
Apr 29, 2010 | Micro Innovations Travel Cam Pro Digital...
Hiiiiiiiiiiii i havu buy a compaq 785tu note book pc is ther any mic drivers for that? my voice is not heared by another person but there voice is heared by me is there any solution for that? i am using...
If you have your sound card drivers installed, it should work. The microphone settings are touchy...Download Skype, and use the call test feature while you are trying different settings for your mic in the control panel. That way you can hear what your setups are actually doing. I am experienced tech, and working with my mics has even given me headaches at times. Make sure you have the right jacks set as default, and check your settings on the control panel. YOu don't need extra drivers.
Jan 13, 2010 | Microsoft Windows XP Home Edition
Usb connection on sirius stiletto 2 to pc
I had a sync problem with the Stiletto 2 (SL2) and was able to resolve it by the following procedure:
Click "Start"
Click "Run" > Type "devmgmt.msc"
Click "+" next to "Other Devices"
Note: You should see a question mark and exclamation point next to "Stiletto 2"
Right click on "Stilleto 2" (to see menu); then, left Click "Update Driver."
Follow the steps in the windows hardware update wizard.
Apr 07, 2008 | Sirius Stiletto 2 Satellite Radio Receiver
Micro Innovations IC014C Webcam Logo
263 people viewed this question
Top Micro Innovations Computers & Internet Experts
micky dee
Alun Cox
Are you a Micro Innovations Computer and Internet Expert? Answer questions, earn points and help others
