Question about Sony Ericsson P1i
Hi, My touch screen has gone dead. Is there any
Hi, My touch screen has gone dead. Is there any way to access internal things like update contacts from back up etc.. Please help
  • 32 Answers
Since the screen is dead I would suggest the easiest way to back up / access important content is through your PC/laptop. Install the necessary Sony Ericsson software on your computer and and connect it to your Sony Ericsson P1i and follow the back up instruction. Hope this helps. Please rate
Posted on Dec 30, 2010
What is the most likely reason a Samsung gear 2 neo touchscreen would be unresponsive to turn on and off
If your Samsung Gear 2 Neo refuses to turn on:
1. the first thing I would suspect is a dead battery
2. If it does not showing charging when connected to the charging cradle:
A. it could be either a bad charging cable, wall adapter, cradle, bad battery, or the internal charging connectors.. Do a process of elimination only with OEM Samsung cables and charging adapters.
Note: the Samsung Smartwatch charging cradle is not normally sold in stores, so if you lost it contact Samsung support to get another one [1+(844) 454-5925], or download the Samsung+ app from the Google Play App Store to access Samsung Support contact information
B. If the Smartwatch has been on the shelf for a long time (either in store or not used after a long time) the battery will deplete itself so low that it needs to be trickle charged for 10 hrs or less depending on how dead the battery is.. Rather than being put on it's regular charge adapter for a few. Try inserting the charging cable into a computer USB port instead of into the wall charger adapter (see attached video)
3. If the Smartwatch is on, but won't turn off:
A. it may be a software issue.. Like an app you installed is clashing with another, or maybe an update got corrupted by a bad bandwidth connection.. If this is the case reset the watch and start over.
B. It's possible you have too many things going on and all the RAM memory (the brain) not storage space, has been used up.. Which is a temporary crash, just like when you over load your brain with too much stuff at one time..
Samsung Galaxy Gear not working
Dec 20, 2015 | Samsung Cell Phones
My samsung s8003 touch screen is sensing all touches like they are being made to the far left of the screen. can access any functions as they all require a touch in other places on the screen, had the...
There is a major flaw in this product S8003. Touching the screen beings different menu and doing its own things, can't get to the menu i want to calibrate screen. I had screen replaced by them, worked fine for few months, now im out of warranty, same problem again and they want me to pay for the repair. Never to trust any of your products again.
Feb 27, 2011 | Samsung Jet S8000 Cell Phone
Phone went dead and now the touch screen wont work. i cant put my access pin in through the keyboard so it wont open. What do I do?
TOUCH SCREEN
the touch screen of the phone you are using is weak and it is not responding properly again.
in other to resolve the problem,you will need to replace the touch screen with a new one.
For touch screen replacement , Contact a technician.
Take care.
Jun 28, 2010 | Cell Phones
Microwave dead
one of 3 things, for sure the internal fuse is gone, then check for a: bad Hi-Voltage;diode, Hi-Voltage capacitor, or the magnetron tube is defective,none are too hard to change out,but the magnetron is fairly expensive to replace:
Sep 22, 2009 | Microwave Ovens
Touch screen display broken
HI! Here's what to do if your Logitech Harmony remote's LCD screen has gone blank.
1. Remove the battery, press and hold the 'OFF' button, and re-insert the battery. The screen will display 'Safe Mode!', or the 'Activities' button will be lit.
2. Connect your remote to the computer.
3. Launch the Harmony Remote Software, and log in.
4. Click "Downloads" at the top and click "Firmware".
5. The remote will go through the firmware update.
6. Select "Yes", and click NEXT to update the remote.
If the screen is still blank after you complete these steps, then it is a hardware issue and you should contact Logitech's wonderful support team, given that the remote is still under warranty. If you are not in warranty, Logitech does not provide repair services for Harmony products.
Hope that helps.
-D
Aug 26, 2009 | Logitech Harmony One Advanced Universal...
My ipod touch turns on and shows the apple sign and cuts right back off i pluged it up and it did the same thing and i went to i tunes and pluged it up and same thing happend
Hold the power button and home button for 10 seconds to ensure the device is off. Let go.
Hold the home button down, plug in the ipod to the computer, after the screen changes to the itunes plug screen, let go of the home button.
The ipod will now be in recovery mode, and you can attempt to perform a restore within itunes.
If the restore fails, and the ipod screen stays black, this means the battery is dead and must be replaced. If you replaced your battery and this still happens, then your logic board has gone bad.
Aug 19, 2009 | Apple iPod touch Second Gen (8 GB,...
Touch screen not working
The touch screen software must have gone corrupted. Contact dealer for detailed information.
Aug 14, 2009 | Cell Phones
Touchscreen does not work
Ok, remove the battery for 5 minute to reset the internal programming. once the 5 minutes are up, re insert the battery and power up. if the screen is still unresponsive, you will need to contact your manufacture for a repair ticket. the internal software that is used for collaborating the touch screen has failed.
May 22, 2009 | LG CU500 Cellular Phone
Olympus 810 just gone dead
if the camera was being updated and then unplugged from the computer, the internals may have been fried... olympus repair can give a free estimate on the camera repair if needed... olympusamerica.com/repair
Jan 19, 2009 | Olympus Stylus 810 Digital Camera
Sony Ericsson P1i Logo
77 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
