Question about Bosch HBN 131560B / 131520 hot-air Electric Single Oven
Took oven door off to clean and hinges have locked. cannot refit. how do I reset the hinge mechanism?
  • billtils Dec 30, 2010
    The video did the trick - thank you.
  • Bosch Master
  • 1,711 Answers
We have
here below a link with a video which is shows how to replace the door hinges
and it will help understand how to unlock the hinges. The video is very clear
that we believe any description in words is not needed.
http://www.youtube.com/watch?v=kESnnYR4VhM&playnext=1&list=PL716C400A1FAFA528&index=8
Posted on Dec 30, 2010
OvenDoor came partly off hinges. One side only.
Most oven doors are made to be removed and on most, the hinges have locking clips which hold the hinge so you can remove the door. Have a close look at the hinge which is still in the door and see if the hinge that came out is the same. You may have to get someone to hold the hinge in place while you refit the door.
Jan 28, 2018 | Ovens
How do i refit the main oven door lock, i need a step by step guide or something?
Oven Door Latch (part #9761013) - How To Replace ...
? 4:32
https://www.youtube.com/watch?v=rbMZ8NgiKm8
Oct 31, 2012 - Uploaded by AppliancePartsPros
Buy the new Oven Door Latch 9761013 ... How to replace yourcooker hinges. - Duration: 8:50. how-2-repair.com 84,238 views. 8:50.
How To ReInstall Your Oven Door - YouTube
? 2:12
https://www.youtube.com/watch?v=EBhJk85mc1Q
Dec 28, 2010 - Uploaded by HavillFiles
Did you remove your oven door and now you can't get it back on? The manufacturers forget to tell you about locking the latches first! ... Oven Door Hinge (part #W10347466)-How To Replace - Duration: 9:25. ... Hygena / Whirlpool / Electrolux / Phillips ovencooker door removal (others with same hinge) ...
How To Replace an Oven Door Lock Assembly ' Repair ...
www.searspartsdirect.com/repair.../how-to-replace-an-oven-door-lock-as...
Main Menu; Recently Viewed ... This step-by-step range repair guide shows how toreplace the oven door lock motor assembly for a self-cleaning oven. The door lockmotor assembly locks the latch to keep the oven door shut during the ...
Jan 08, 2016 | Ovens
Can you take the oven door out to make it easier to clean the oven,if yes then how
If you open the oven door, look at the hinges, are there 2 latches as part of the hinge? If so, operate these latches while supporting the door and the hinge/door assy should unhook from the oven frame. Refitting is the reverse but make sure the latches are properly located otherwise the door/hinge could fail.
Oct 09, 2014 | Ovens
Ignis AKL828 door hinges locked in shut position... door off oven!
Take a pair of pliers and pull the hinge out of the socket. This will take care of it. After doing this, then simply set te door back in place and shut.
Mar 06, 2013 | Ovens
My oven door glass was dirty, from the vents in the oven door..so we took off the oven door, took apart all the screws and cleaned the glass. First of all, don't know if we got the glass pieces in the...
the glass pieces should only fit back in one way, holes will only go one way , as far as the hinges, the need to be locked open in order to replace back into the unit, there is either a small hole in corner of hing that when pushed wll align with another hole in hing allowin for a thin blade screwdriver to be inserted adn hold in hte locked position,... the other way is a small locking mechanism is loacated on the top of hinge that when fully extended will lock hinge open for reattachment... you would need to REALLY PRESS that hinge to lock in place..
Oct 09, 2010 | KitchenAid 30 in. Architect II Series 4.3...
Replaced hinge on smeg double oven but now oven doesn't heat
I have the SMEG F170-5 and had this problem after cleaning and replacing the door. It wouldn't heat unless I banged it shut. This action made the internal switch trigger, so I had to remove the oven (4 screws, slide out) and remove the right side panel (4 screws). The switch is actuated by the right hinge strut and it must have become bent slightly. I bent it a bit towards the door so that it would just a little bit more likely to make the switch trigger with the door closed and it now works fine.
Jun 12, 2009 | Smeg S351X/5 Electric Single Oven
I need to remove oven door, cant figure out how
drop the door down as low as it will go look carefully at the hinges as they pass through into the oven chassis you will see a clip on each one that you lift up to lock the hinge you usually lift them up as far as they will go then this will lock the hinges as you close the door the hinges will come away from the oven complete with door.... reverse to refit.
May 06, 2009 | Bosch HBL 755 Stainless Steel Electric...
Electrolux EOB5630 door hinge locked closed
Look for a release button. If not, it may have a locking mechanism that needs to be released. Try some of these: push the hinge to one side while lifting, press the hinge down then lift, pull up on the hinge while pulling. Good luck!
Oct 24, 2008 | Electrolux EOB5630 Ultrafan Electric...
Smeg se375mfx5 / stainless steel
i suspect you took the door off without locking the hinges
you will have to put the hinges in the lock position before putting back.
lay door on a blanket with hinges upwards. force the hinges back and bring the locking arm up to lock the hinges.
this requires considerable strength
Jul 05, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg Double Oven SD08
this can be hard to do as you should have locked the hinges with the door fully opened before taking it off. the hard part now is (with the door off) you have to push the spring loaded hinges down and lock them with small hook located on each hinge once locked the door will go back on the oven. you then open the door fully and unlock the hinges, good luck
Feb 17, 2008 | Smeg DO81CSS Electric Double Oven
Bosch HBN 131560B / 131520 hot-air Electric Single Oven Logo
498 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
