Question about Stanley Hand Tools
Having issues finding a replacement kit for a BLACKHAWK1/2 ratchet model # 49975A
Power steering pump replacement
Do you have a set of "Flex/Wobble head" extensions? That may work.
See picture, look at where the socket attaches.
Sep 06, 2016 | 2008 Nissan Quest
The ratchet on craftsman microtork torque wrench 44593 does not work
The ratchet pawls have seized and a ratchet rebuild kit is needed.
Jul 20, 2014 | Craftsman Microtork Torque Wrenches -...
Repair kit for AT200A blue point
This Product is no longer available. and or the Repair Parts.sorry
Nov 14, 2013 | Chicago Pneumatic 1/4" Air Ratchet
Ratchet head has cracked.can i get a new head?
Hi and welcome to FixYa, I am Kelly.
The head kits are available and you can view the replacement parts kit number here:
http://www.ingersollrandproducts.com/IS/Product.aspx-am_en-9620
The part number is here in this manual on page 45 / pdf file page 4:
https://www.airtools-online.com/PDF/IR_Ratchets.pdf
Image:
http://www.ingersollrandproducts.com/IS/viewer.html?pic=http%3A//fileserver.ingersollrand.com/images_tfm_acc/1107-TRK1_l.jpg
Use this page to find a local distributor:
http://www.ingersollrandproducts.com/IS/Category.aspx-am_en-31055 (Must choose country)
Then choose "Tools - assembly - air" and
last enter a zip code. (search location)
a list of local distributors will appear.
Thanks for choosing FixYa,
Kelly
Mar 03, 2011 | Ingersoll Rand 107XP TRK1 Air Ratchet Head...
Very little power to craftsman 3/8 ratchet. air pressure set at 80pi.
add a few drops of marvel mystrey oil to the ail line opening to clean it out and try it again
Feb 24, 2010 | Craftsman 3/8" Pro Air Ratchet Rapid...
Removing Agitator from Kenmore Model 110 Top Loader
How to replace Whirlpool/Kenmore washer
dual action agitator ratchet ‘dogs’, kit # 285770
Tools needed: Screwdriver, 3/8" drive ratchet wrench, 7/16" socket (older models), 3/8" drive to 1/2" adapter (newer models), long 3/8" drive extension, small amt liquid detergent
1) Pry the agitator cap off by inserting a screwdriver into the cap’s notch
2) Pull the inner cap (if present) off – most Whirlpool machines use this inner cap, with a handle, to gain access to the center bolt
3) Remove the bolt in the center of the agitator
(Earlier models used a 7/16" hex-head steel bolt)
(Recent models use a 1/2" square drive plastic nut – use a 3/8" X 1/2" ratchet adapter)
4) On older models, grasp the bottom portion of the agitator and pull the entire ***’y off.
(Recent models allow just the top portion’s removal to access these ‘dogs’)
5) Older models – place the agitator on the floor, and, standing carefully on the bottom portion, pull the top half off. Turn it over, and the dogs will be accessible for replacement.
6) Newer model dogs can be replaced once the ratchet ***’y is removed. There are several versions currently in use, but most can be replaced without removing the bottom agitator half. All‘4-dog’versions use the 285770 kit, regardless of the cam ***’y style. (Older agitators, rarely seen now, used a pair of 2 larger dogs, which are a different part number)
7) On older versions, be careful to align the two tabs when inserting the upper ***’y back onto the agitator bottom half. When these are aligned, they will friction-fit the two halves together, making it easier to reinstall the ***’y. Handle it only by the bottom half to prevent pulling the top half off when reinstalling.
8) Lightly lubricate the agitator cap’s rubber gasket using a bit of dishwasher detergent, and push it back into place. (On the Whirlpools with an inner cap, lube that cap’s o-ring too – makes it easier to snap into place)
9) Reach around and pat yourself on the back! You just saved at least $75.00!
Dec 31, 2008 | Kenmore Washing Machines
Makita 18volt 6347 cordless drill
then you need transmision assy. item 14 in breakdown
see toolpartsdirect.com for further info on your drill
Mar 28, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Hand Tools Logo
47 people viewed this question
Top Stanley Hand Tools Experts
Jim Thurston
Ivan
Ivan
Level 1 Expert
Don Numinen
Don Numinen
Are you a Stanley Hand Tool Expert? Answer questions, earn points and help others
