Question about Hoover HP6150 Front Load Washer
Loud bang bad vibration - Hoover HP6150 Front Load Washer
A loud banging noise at start of spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
May 04, 2011 | Tricity Bendix AW1054 Front Load Washer
The tub inside of the washing is very loose and bangs very loud when washing especially on yhe spin cycle
heatman101
Oct 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Very loud banging on fast spin
heatman101
Sep 17, 2010 | Whirlpool AWM8113 Front Load Washer
Whirlpool WFS1276AW bangs loudly when rinsing and spinning
Check out this tip I wrote about the noise and vibration that front load washers can make..
heatman101
Sep 06, 2010 | Whirlpool LHW0050PQ Front Load Washer
I hear a loud ratteling noise coming from where
The rattle is likely a loose shield or a bad catalytic converter. As for the loud banging, Have you checked the front U-joints behind the brake rotors. As for the Reverse noise? Auto or stick shift?
Apr 16, 2010 | 1996 Jeep Grand Cherokee
Washer spin cycle extreme vibration and loud bang when it stops
check the vibration damper rods for breakage - especially the mounts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore Washing Machines
Very loud banging noise when spinning
sounds like a balance problem may be when the drum was replaced they didn't fit the new drum in the correct spot the other thing that would cause load banging and excessive vibrations in the machine is if the shockers are worn out,
believe it our not even washing machines have shockers to dampen the movement of the drum spinning
Dec 19, 2008 | Indesit W 123 Front Load Washer
Loud noise
The vibrating sound you hear could be due to "water hammer" when the fill valve tries to close against high water line pressure. I had that problem and solved it by putting a small valve in the line to the ice maker and closing it little by little until the vibrating went away. You know, the banging could also be water hammer. It only happens at night when the entire neighborhood is asleep and the water pressure is at its highest. You need to check this out because water hammer can be very destructive to the plumbing and the valve.
Tom
Sep 08, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Loud banging noise commencing spin operation.
one or two of your dampners are either lose or broken.
Open machine and check all dampeners . replace the roken ones. Dont use the machine as it will increase damage
Jun 22, 2008 | Creda W100FW Front Load Washer
Hoover HP6150 Front Load Washer Logo
23 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
