Question about Canon PIXMA MX870 Wireless Office All-in-One InkJet Printer
I don't use an answering machine. My phone has voice mail but the machine is not even recognizing when a fax comes in. The fax call goes into the voice mail each time. The phone line is working-I get a dial tone when I press Hook or pick up the phone. I don't think I even need a phone plugged in the machine as the MX870 is not recognizing when a fax comes in no matter if a phone is hooked up to it or not.
  • Canon Master
  • 4,338 Answers
You need to set your phone to pick up later than the fax machine. set it to pick up on the 4th or 5th ring, set the fax to pick up at 2 or 3. Better yet, get a distintive ring # set up by your phone co. then the fax will only recognize that ring.
Posted on Dec 30, 2010
Canon mf5770 not receiving faxes
Most fax machines allow you to set the number of times the phone rings before it automatically answers the phone. So if you phone goes to voice mail after 4 rings and the fax machine is set to start the fax after the 5th ring it will never receive the faxes because the call went to voice mail. Good Luck
Dec 05, 2013 | Office Equipment & Supplies
Can't send or recive Faxes
Try resetting the machine to it's defualt settings.
Jun 18, 2008 | HP Photosmart C6100 All-In-One Printer
Sharp plain paper ink jet fax ux-b750
to stop the fax automatically switching to fax mode you have to set it to manual to recieve calls and dissable the fax,there should be an auto/fax and call mode, therefore when someone calls it will go to your voicemail, but that means that you will not be able to recieve a fax. Normally auto mode, will first try the fax, if no fax is recognised it will switch to normal line ringer, then if no answer it should go to your voicemail if unanswered.
Oct 01, 2007 | Office Equipment & Supplies
Can lexmark x4650 be set to recognize fax?
For more details on how to setup your Lexmark X4650 printer for faxing, please refer to the User's Guide found on the Lexmark website.
Additional info:If you have an answering on the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
Feb 16, 2012 | Lexmark X4650 InkJet Printer
Printer says DR mode in use what does this mean
DR Mode means distintive ring. This is if you are using two or more phone numbers on one line. For example, you could have your voice mail number and your fax number on the same line, but when a call comes in to your voice mail the fax will recognize the ring pattern and won't pick up the call. If it is truly a Fax, then your fax will pick up the call by recognizing the ring pattern.
Oct 07, 2009 | Brother MFC 8840D All-In-One Laser Printer
Intellifax 2820
Program it so it has more rings in fax mode allowing you time to answer the phone.
Apr 05, 2009 | Brother IntelliFax-2820 Laser Fax
Phone won't go into voicemail, only fax mode
Your cable company is correct. Your printer is set to the phone/fax mode which allows the machine to be act as a phone or fax. It can tell the difference between an incoming voice call and an incoming fax. You should set your printer to Fax Only. Here's how:
  1. Push the menu button
  2. Press 0 (zero)
  3. Press 1 (one)
  4. The display should now show fax only.
  5. Press Ok.
To review what we did:
We set your printer to only recognize faxes when they are sent. Voice calls will now go through to your voice mail, if you do not answer.
If my assistance has been to your satisfaction, please rate my service. Thank you for using Fixya.com
Jan 24, 2009 | Brother Multi-Function Center MFC-240C...
Incoming faxes
Do you have a distinctive ring pattern in the same phone line
If no then you need to get a distinctive rig pattern from your service provider, which will differenciate the type of rings for phone and fax.
If you have a distinctive ring pattern make sure which one it has single rings, double rings, triple rings and double and triple rings.
To enable> First make sure auto answer in turned On
In setup/Menu go to > Rings to answer and set it to 5 or 6, and make sure the rings to answer in you answering machine set to 4(Always Should be lower then you rings to answer in the fax)
In Advance Fax setup> Then Ring pattern should be setup for the one which you service provider as given either double or triple Rings>
And the go to tools and run fax test and check what has failed
Aug 28, 2008 | HP Officejet 5610 All-In-One InkJet...
VOICE MAIL AND FAX
The short answer is no. The JX200 will work with an answering machine because it "listens in" when the answering machine picks up a call. It can't "listen in" to voice mail, because the voice mail is handled by your phone service.
Mar 29, 2008 | Canon FAX-JX200
Answering machine
I have the same machine, and as far as I know, you need an answering machine to effectively do that. Voice mail doesn't work well, according to the manual.
Aug 20, 2007 | Brother IntelliFax-2480C Fax
Canon PIXMA MX870 Wireless Office All-in-One InkJet Printer Logo
397 people viewed this question
old marine
old marine
