Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Front metal piece that the seal goes against - between freezer and fridge
Strip of metal between freezer and refrigerator sections is too hot to touch
  • ealindsey Dec 30, 2008
    What is the answer to why the strip between the fridge and freezer is too hot? Is this dangerous? Should we unplug the refrigerator?
  • 125 Answers
Clean the coils under the ref, and check the condensor fan, in back of the unit behind cover on bottom by compressor. replace fan motor if not running.
Posted on Jul 19, 2008
ED5VHGXMQ10 Whirlpool Fridge
I have the same problem. Too hot to touch between the freezer and refrigerator door. Is
this normal?
Posted on Jul 16, 2008
2 Suggested Answers
mikedurland
  • 481 Answers
SOURCE: front metal piece that the seal goes against - between freezer and fridge
clean the coils under the machine and make sure the airflow under the machine is not obstructed at all.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 23, 2008
The front vertical fascia that separates the frozen from the fresh food side on our fridge is actually getting too hot to touch. This is the area where both door seals contact the fascia and actually seal...
There is a heater in there to keep condensation from froming on the metal. There should be a thermostat somewhere that controls the heat and that is where your problem is... the t-stat is not shutting down the heater...
look for that t-stat in an exploded veiw of that unit. Many parts suppliy sites have the exploded views.
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Aug 20, 2010 | Maytag MSD2756G Side by Side Refrigerator
Very hot to touch between fridge and freezer on front panel
on front panel around the door where the door seal goes up against is this what is hot check the compressor fan in the back of the machine when it doesnt run or is unoperational then the sides around the door get hot you might have to replace the compressor fan
Aug 12, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Front metal , top heating element very hot
This should be OK. There are heat strips placed behind the door frame to prevent sweating around the door frame due to the metal being cold normally without the strips. Thanks, Sea Breeze
Jul 21, 2009 | Refrigerators
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Overheating, seals on Roper side by side are hot to the touch
Hi, When that strip gets hot, it is a sign the temperatures are not cold enough. Put a thermomitor in the freezer. You should get a reading of 0 to 5 above. If not, let me know and we can try and get you through this.
Thanks
Vic
May 15, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Samsung model # rs2630sh side by side fridge. center strip is hot
I had the same problem, and it was the condenser fan motor. I ordered mine from www.partstore.com. It was half the price of sears.
I would suggest ordering the 2 "plastic bushings" for front and back of motor. I was able to reuse mine, but for a few dollars more it's worth it.
Jan 20, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Mike
Jul 23, 2008 | Whirlpool ED5SHAXM Side by Side...
Whirlpool Refrigerator Door Seal surface is HOT.
If the air flow on the condenser under the fridge is too low, the hot gas won't be cooled enough before it goes to the door jamb to stop condensation. Remove the plastic cover under the doors and look at the condenser (tube/wire thing underneath). If it is clogged with fluff, get a vacuum and nozzle and give it a good clean so the air can pass through. Other than that, your condenser fan may have stopped.
Jul 13, 2008 | Whirlpool GC5SHEXNS Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
445 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
