Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Computer restarts again and again .some times starts after some break.
  • 32 Answers
This could be one of several issues. The first thing I would look at is the processor cooling.
Leave your case open while starting up your computer and have a look at the processor fan, is it rotating or not? If it is not rotating check the connections to the motherboard. Also ensure that the heatsink and fan are securely fastened to the motherboard and are in the correct place.
Posted on Dec 30, 2010
Once the timing belt break,and replaced,still no starting,,,mechanical guy say its the computer,its the second one.
I think I got most of what you said.
If you can not troubleshoot the problem yourself, you'll have to have it towed to a different shop.
You would need to know if you have spark to the plugs, fuel to the injectors, and normal compression now that the timing belt has been replaced.
Feb 06, 2013 | 1996 Plymouth Voyager
Why does my mac desktop computer screen start to flicker then shut off?
Remove the main battery and try again, the power supply adapter may be breaking down under load, there is no reliable way of testing other than subbing another power supply.
Apr 17, 2012 | Computers & Internet
In the middle of a session the screen turn black, but the computer seem to be on... we need to stop it with the middle button and restart it again. Usualy it start back normaly again. But one time, instead...
You need to start up in safe mode you do this by pressing F8 while it is booting up you will then see a screen that says start normal or safe mode pick safe mode if it boots up and it will take a little while then shut down the computer by selecting shut down and then restart this will most likley solve your problem
Jan 13, 2011 | Acer Aspire 4520-5582 Notebook
When the engine is hot and you shot the the engine off and then you start it up again I am having hard time start it up.
If I recall correctly this bike has C.D.I. but down on the crank are two pick up coils.If this is the bike I'm thinking of these coils are bad for breaking inside.When you cold start the break is together but when they get warm the break expands apart and you have trouble restarting.Does one of the pistons cut out when you are riding along? If yes this is most likely the problem
Aug 18, 2010 | 1984 Honda VT 500 C Shadow
Umm... can't boot to windows at all so the program that was provided wont work, can't reinstall windows automatic disk eject on startup!
Restart your computer. Immediately after the screen goes blank for the first time, press the F8 key repeatedly. The Windows Advanced Options menu appears. If the menu does not appear, restart your computer and try again. Use the cursor keys on your keyboard (your mouse will not work) to select Last Known Good Configuration, and then press ENTER. Windows XP attempts to start.
If you recently installed new hardware, shut down your computer and disconnect the hardware. Then, restart Windows XP and troubleshoot your hardware to get it working properly.
Restart your computer and press F8 again. This time, choose Safe Mode and press ENTER. Windows XP attempts to start in Safe Mode, which does not automatically start programs and hardware, and displays very primitive graphics. If Windows XP starts successfully in Safe Mode, you can remove any programs or updates you have recently installed. Then, restart your computer normally.
And Thanks.
Mar 19, 2010 | Microsoft Windows XP Professional With...
I can't clear cancel a document waiting to print
In Windows, if cancelling the print job does not work, the command prompt can be a very useful tool. Go Start button, All Programs, Accessories, Command Prompt (if standard user, right click and run as administrator) (These are for Vista and Win7, XP is similar and older were similar)
Type "net stop spooler" without the quotes and hit enter. When a new prompt appears, type "net start spooler" (again without the quotes and hit enter). You can also do these one line at a time: Start Run and the two phrases. Once the commands have executed restart the computer.
If you only type the first line and then reboot, plan on taking a coffee break before the command finishes processing on the restart.
I hope this helps.
Feb 27, 2010 | HP Office Equipment & Supplies
I cannot uninstall antivir on my computer how do i do it!
Hi, you can remove Norton by following ways:
First: you can try to use the Norton Removal Tool provided by Symentec: http://service1.symantec.com/SUPPORT/tsgeninfo.nsf/docid/2007080716270339?Open&docid=2005033108162039&nsf=tsgeninfo.nsf&view=docid
Second: If you want to remove it manually try the below steps:
go to Start --> Control Panel --> Add/Remove Programs.
Scroll down to your Norton program
Click Change --> Remove All.
You will be asked to restart your PC. Please restart the computer.
After restart go to Start --> My Computer --> Program Files. Right click on each Symantec folder and select Delete.
While you are in Program Files go to the Common Files folder at or near the top of the Program Files window. Delete every Symantec folder there. And, again, restart your PC.
Go to Start --> Search --> All Files and Folders --> More Advanced Options. Check each option except for "Case sensitive"
Now type in Norton and delete each Norton folder from the search results (Again, right click, choose "Delete"). One more time, restart your PC.
Now type in Symantec and delete each Symantec folder from the search results (Again, right click, choose "Delete"). One more time, restart your PC.
Feb 25, 2010 | Norton AntiVirus 2004 (0003764823191)
Computer never continue to start up, it just continue restarting at least 2 times then it hang. when i try to reboot monitor never display any images anymore and what i noticed when that happens is that...
run it in safemode with networking and install safemsi.exe and then run malawarebytes which is free to download ,update it and run this will fix the problem
May 08, 2009 | Microsoft Windows XP Professional for PC
Computer not started properly
the window is corrupt try to repair the window with window xp
May 30, 2008 | Intel D845GVSR Motherboard
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
29 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
