Question about Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher
ONCE THE DISHWASHING CYCLE BEGINS, A LOUD, CONTINUOUS BUZZING SOUND IS BEING MADE. SOUNDS LIKE A GARBAGE DISPOSAL THAT IS JAMMED AND NOT FREE TO ROTATE, A MECHANICAL BUZZING
  • Jenn-Air Master
  • 19,396 Answers
Hi.
Problem is likely a jammed impeller pump. The repair is done accessing the hose connected to the impeller pump and removing blockage. In some case the pump is broken and it is necessary to replace the pump.
Before testing anything else ensure that power is off. also rotate manually the spray arm and ensure that this are free to rotate and are not hitting baskets and other parts.
To find parts and diagrams try entering the full model number (as from service tag) in the websites listed at the link below:
Enter the model number ...
Regards.
Ginko.
Posted on Dec 30, 2010
Disposal made loud grinding sound, immediately turned off. Could not find anything jammed in disposal. But now it just makes a humming sound
There is something binding up the garbage disposal. Make sure the power switch is off and trip the breaker for that circuit too! Use a broom handle, plunger handle or something similar and use it to try and turn the inside of the disposal. By prying between the sink opening and any raised surface on the bottom of the inside of the disposal with the broom handle you may be able to break it free. This sometimes takes considerable force so be careful not to smack yourself if the broom handle slips. It may take several attempts. Once you can get the disposal to turn, check inside for any debris that may have been forced back into the disposal and remove it before restoring power and testing the disposal is functioning properly. Repeat the process if it begins working normally and suddenly binds up again. There may be additonal debris in the unit.
Aug 20, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Sounds like its jammed . used tool to free blades. it fools loose,but still wont spin
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
Jan 17, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Stoped running. Is there a re-set button
heatman101
Dec 14, 2010 | GE Continuous Feed Garbage Disposal...
Won't run
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Sep 25, 2010 | Maytag DFC5500AAX 3/4 HP Continuous Feed...
Loud humming sounds.I do not think anything is jammed. Cannot reset!
May 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage disposal's motor sounds jammed
To un jam your disposal you need the wrench that comes with it. It is a six sided piece of metal about 8" long with a bend on each end.
With the power off you stick either end of the wrench into the center of the disposal and engage the disposer. Turning back and forth till you free up the disposal.
Once you have the disposal free you can then turn on the power and it should work for you.
Heatman101
Dec 31, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Open Questions:
See all Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Questions
Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Logo
97 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
