Question about Viking DEDO205 Stainless Steel Electric Double Oven
Self cleaning DED0205 Viking oven
I have a dual oven from viking. The problem is with the self cleaning
the unit will not self clean and the bottom oven will not turn on
  • Kenneth Turnbull
    Kenneth Turnbull May 11, 2010
    does it clean but not get clean?
    The bottom oven will not turn on at all or in self clean?
    Are you trying to clean both ovens at the same time?
  • 832 Answers
SOURCE: Viking double ovens. Can both ovens be cleaned at
Unplug your oven, and clean both at once., Yes, you can.
Posted on Sep 26, 2009
Macmarkus
  • 2605 Answers
SOURCE: Do I remove the racks before self cleaning my
It is a matter of personal choice to whether you remove the rack`s or not, no harm will come to you from not removing them but...If they are chrome finished they will become very dull and look like bbq grills over time and in extreme cases, warp and consequently not fit well.
If they are finished with enamel to match the oven liner, don`t worry, they are designed to be left in place, even during self clean cycles.
As for how you can clean them. You can do this by removing them and with a suitable work space (a bath tub or laundry tub works great) with regular oven cleaner`s, (preferably environmentally friendly...check your local by-laws) or other household cleaners with the assistance of a scrub pad and elbow grease. Be sure and rinse them thoroughly when finished with the cleaner`s.
Hope that help`s. If so, please take a second to rate the solution provided by me here at fixya. Thank you.
Good luck.
macmarkus :)
Posted on Dec 05, 2009
SOURCE: how long to run self clean on viking professional
The "Self Clean" will run for quite a while up to 4 hours I believe, during this time, the stove heats up to about 900 degrees!! and during this time the Door is automatically closed via special locks. It will allow you to open once it is finished, it should "Signal" this event.
Posted on Feb 11, 2010
  • 87 Answers
SOURCE: do I have to take
no u don't
Posted on Oct 14, 2010
who is that
  • 9 Answers
SOURCE: My Viking oven door will not open after self
not sure. its possible that something melted into the hinges and glued it shut. or i guess if it got hot enough the metal could have been heated up to a point where it was bent out of shape and thus it got stuck
Posted on Nov 04, 2010
Viking oven locks up while baking. Cannot open oven door to remove food. What could be causing this problem?
Ovens usually lock when it thinks you are running the self-clean process. Unplug for 15 minutes and plug back in, if that fails call in service
Dec 12, 2017 | Viking Ovens
How long should the self cleaning mode be on?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 12, 2010 | Viking Ovens
The oven will not get hot on the self-clean option, but it will get hot when just using the regular oven
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Oct 26, 2010 | Viking VEDO205 Electric Double Oven
I did the self clean on the upper oven. When the stopped cleaning it cooled down, but the door will not open. (Unlock)
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 15, 2010 | Viking VEDO205 Electric Double Oven
How long to run self clean on viking professional
Feb 11, 2010 | Viking 27" Professional Select Built-in...
Self cleaning oven, locks but doesn't get hot, didn't clean
http://www.vikingrange.com/consumer/index.jsp
start with this web site. Has logs of stuff. Just surf the site for your unit.
Good luck and hope it helps.
Oct 23, 2009 | Viking VESO105 Electric Single Oven
VDSC307-4bss how to operate self-cleaning oven
I continued a search and found a manual on line... simple process to turn on self-cleaning operation... close the door and set to "clean" ... timer on this model is automatic... runs for 3 1/2 hours.. fan continues for an additional 30 minutes ... open the door and the oven is clean. Thanks
Mar 28, 2008 | Viking VCSO244 Dual Oven
Cleaning our viking oven
I had to clean mine the old fashioned way -oven cleaner and elbow grease. Fortunately the oven comes apart in ways I never imagined so I could remove, for instance, the sides and bottom and clean them without bending over with my head in the oven!
Dec 06, 2007 | Ovens
Viking DEDO205 Stainless Steel Electric Double Oven Logo
131 people viewed this question
Top Viking Ovens Experts
Dan Webster
Dan Webster
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Viking Oven Expert? Answer questions, earn points and help others
