Question about CorningWare K5607 Slow Cooker
I have power to the slow cooker and it shows a red light on warm but i keep pressing the hours button on the right and the hours are not displaying in the digital area. Do I have to wait until it warms to change the hours and such?
Yes you have to wait til the warm red button goes off than punch in hours and than hit on. I cant figure out how to put it to low though! lol
Posted on Jan 16, 2011
How do you work the pc crock pot
How to operate: Plug in. Set timer to amount of hours to cook. Press the SELECT button to scroll thru 4 settings - "warm", "1" (Low), "2" (Medium)", "3" (High). Once the desired cooking temp selected, press the "round circle" power button to begin cooking. The time display will now start to count down to "0:00" When the cooking time has been reached, the slow cooker will automatically go into "warm" mode for a maximum of 6 hours, then automatically turn off. Quoted from manuals on line
http://www.manualsonline.com/support/other/slow-cooker/manual-2538852
Sep 07, 2017 | Crock Pots & Slow Cookers
I pushed the cook time button but it still says zero what do I do
Hit the on/off button, so that the cooker looks like it is off, then hit the cook time button up the the number of hours you need to cook. This slow cooker has three settings: LOW, HIGH and WARM..... When your corningware slow cooker is initially plugged into a wall outlet, the display will show "0". This display indicates the programmed number of hours for which ameal will cook. The slow cooker can be programed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears. If 1,2,3,4,5, or 6 hours are selected, then the slow cooker will operate on the high setting. If 7,8,9, or 10 hours are selected then the slow cooker will operate on the low setting. To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the warm setting.
May 11, 2010
Nov 19, 2012 | CorningWare SC60 Slow Cooker
How do I work it temp,time
wait for warm red button to go off than use right button to set time in hours and than hit on. not sure myself how to make it low. mine only wants to go to hot!
Jan 07, 2011 | CorningWare SC60 Slow Cooker
I need an owners manual for the SCVC651
I couldn't find the specific manual for this, but I did find some basic instructions on a personal review:
"Rival calls this a SmartPot and describes this unit as "programmable". All this really means is that you can program the slow cooker to cook either on "High" or "Low" for up to 20 hours, in 30 minute increments and then it will automatically switch to the "Keep Warm" setting and keep your meal warm for hours. You cannot program multiple steps, such as going from the "High" to the "Low" setting. The red, LCD clearly displays the remaining cook time.
Simply plug in the slow cooker, and then push the clearly marked buttons (with a pleasant, audible tone) to move from "Low" to "High" to "Keep warm" settings. Then push the Timer Button to set the desired cook time."
Hopefully, this helps answer your questions!
Nov 23, 2010 | Rival SCVC651-F Slow Cooker
Slow cooker will only stay on warm. How do I put
This slow cooker has 3 settings LOW, HIGH, & WARM
When you plug the slow cooker in the display should show a "0". When you press the "COOK TIME" button, the display should go to 1 then 2 then 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the "HIGH" setting. If 7,8,9, or 10 hours are selected, then the slow cooker will operate on the "LOW" setting. To start the cooking cycle press the "ON/OFF" button. To interrupt the cooking cycle at any time, press the "ON/OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the "WARM" setting. If the "ON/OFF" button is pressed when the the digital display shows "0", then the slow cooker will automatically start on the "WARM" setting.
If the "COOK TIME" button does not change the display numbers then unplug the slow cooker and hold both buttons down as you plug the slow cooker in. Keep the buttons pressed for a count of ten, then release them and the slow cooker should work correctly
Feb 11, 2010 | CorningWare SC60 Slow Cooker
How do I start the cooker on low?
The manual says "When your corningware slow cooker is initially plugged into a wall outlet, the display will show"0". This display indicates the programmed number of hours for which a meal will cook.
The slow cooker can be programmed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears.
If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on HIGH setting. If 7,8,9 or 10 hours are selected, then the slow cooker will operate on the low setting.
To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
When the full cooking cycle is complete, your corningware slow cooker will automatically switch to the warm setting, to keep food at a warm serving temperature."
If, after you plug the slow cooker into the outlet, the COOK TIME button does not work, unplug the cooker, hold both ON/OFF and COOK TIME buttons down, plug into wall socket and wait till the display flashes. Release both buttons and the slow cooker buttons should both work.
Dec 18, 2009 | CorningWare SC60 Slow Cooker
Need a manual for the corningware sc60
The manual basically says... This slow cooker has 3 settings LOW, HIGH, and WARM. W hen you plug the slow cooker in the display shows "0". When you press the "COOK TIME" button, the display should go from 0 to 1 to 2 to 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the HIGH setting. If 7,8,9,or 10 hours are selected, the slow cooker will operate on the LOW setting. To start the cooking cycle, press the "ON/OFF" button. To interrupt the cooking cycle at any tim, press the "ON?OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the WARM setting. If the "ON/OFF" button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
If the "COOK TIME" button does not change the display numbers, unplug the slow cooker. Hold down both buttons and plug the slow cooker in and keep them pressed down for a count of 10. Release the buttons and the slow cooker should work now.
Nov 28, 2009 | CorningWare SC60 Slow Cooker
Can't change temperature-stays on "warm"
Push the COOK TIME button, if the time changes then if you leave the number of hours between 1 and 6, and press the ON/OFF button, it will cook on high that many hours. If you leave the number between 7 and 10, and press the ON/OFF button, it will cook on low that many hours. If you leave the number at "0" then the slow cooker will cook on WARM. If the COOK TIME button does not work, unplug the slow cooker, hold both the ON/OFF button and the COOK TIME buttons down and plug it into a wall socket. After the lights flash a few times, release the buttons. the switches should work.
May 19, 2009 | CorningWare SC60 Slow Cooker
Need directions for presidents choice slow cooker
Heat intensity is warm, 1, 2, 3 (highest)
How to operate: Plug in. Set timer to amount of hours to cook. Press the SELECT button to scroll thru 4 settings - "warm", "1" (Low), "2" (Medium)", "3" (High). Once the desired cooking temp selected, press the "round circle" power button to begin cooking. The time display will now start to count down to "0:00" When the cooking time has been reached, the slow cooker will automatically go into "warm" mode for a maximum of 6 hours, then automatically turn off. NOTE: Not recommended using the WARM setting for more than 4 hours at a time. NOTE2: To stop the cooking process at any time, press the "round circle" power button. The unit will default to "0:00" time but the indicator light in the "3" high position will remain on.
Apr 11, 2009 | Crock Pots & Slow Cookers
Rival 38601 Smart Pot 6-Quart Slow Cooker can't get to to go to warm
Here is the manual for this cooker; http://www.crockpot.com/manuals/38601-C_English.pdf page E4 and E5 tells you details of programming/timer/temperature. Check through everything and see if you can figure anything out. after cooking, the unit should automatically switch to warm mode, if it isn't doing this then unfortunately i think it needs a replacement control board - probably not worth doing. If you want to give it a try then post again and we can try and source you the bits Hope this helps :)
Mar 16, 2007 | Rival 38601 Smart Pot 6-Quart
CorningWare K5607 Slow Cooker Logo
153 people viewed this question
Top CorningWare Crock Pots & Slow Cookers Experts
charles
Gerry Harvey
Gerry Harvey
raysaw
Are you a CorningWare Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
