Question about Kenmore 65924 Electric Dryer
My kenmore dryer 80series mdl #66822694 stopped after few minutes of use. push start button but it would stop immediately. cooled briefly and was able to run a cycle using the timed select not the automatic select. the next day after non-use all night went to use push button and started but stopped almost immediately. then pushed button again and nothing. does this sound like a relay switch issue or motor issue. thanks,eric
  • 2 more comments
  • ehallfors Dec 30, 2010
    inside DUCT on back of dryer? What is this? This isn't the air exhaust duck, right? Is it where the heater element is?
    i just went and pushed start button and the machine tried really hard to get going but never did and then the button stopped working completely and when i pushed it again, nothing. Is thsi thermal fuse the same as the heater relay?
    the thermal fuse has a black covering/piece between the terminals. is this just a cover protecting the wire to the 2 terminals or is this the actual connection. this black piece is solid. there is one terminal hookup that is burned somewhat that goes to the heater itself. normal? part of the problem?
    hey daniel. i took off the fuse and hot wired the 2 wires and pushed start button and briefly the machine ran. i held the button in and then the motor sounded like it got bound up. and did not want to run. if i released the button the machine stopped. does this sound like the motor is shot?
    eric
  • 4,323 Answers
Hi
When dryer won't heat or won't turn on or will behave as its behaving with you it means that the Thermal fuse which is located inside duct on the back has gone bad and should be replaced as it cannot be reset. If their is continuity when you check the fuse then it means that the control board is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Dec 30, 2010
  • Daniel Scott
    Daniel Scott Dec 30, 2010
    Yes right sorry its located inside the back to the exhaust duct on the blower wheel housing.
  • Daniel Scott
    Eric you can test the fuse for continuity between its two pins, if it tests open then replace the fuse. If you hear a hum like sound from the motor then it is the motor that is bad and should be replaced.
Kenmore 90 series heavy duty model 67902, when I push the start button the motor turns on briefly but when I let go of start button it stops.
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
Nov 27, 2010 | Kenmore Dryers
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
The start push button doesn't work kenmore 80series
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 21, 2010 | Dryers
Push start button the dryer will tumble, but immediately stops
there is a relay that latches on when you push the start button .. that relay is released by the "door open" switch .. i would suspect that the "door open" switch is bad .. thats usually a button that is pushed in when the door is closed ..
Sep 19, 2009 | Kenmore Dryers
Icemaking cycle automaticall self stops and cleaning light blinks
ice machine runs one cycle and freezes ice will not release ice block to wire cutter. then after a few minutes the cleaning light starts blinking
Jun 11, 2009 | Kenmore 51lb. Clear Ice Maker
Kenmore dryer start button not working
when I push the start button on my kenmore dryer it will not start and the drum will not turn.
Nov 09, 2008 | Dryers
Dryer problem
Hi. thanks for the question . It looks like you have a faulty motor . I would replace the motor , thanks the appliance doc
Sep 20, 2008 | Kenmore 72802 Gas Dryer
Kenmore Dryer 90 Series will start but suddenly stop...
what starts and stops? the entire dryer or maybe the drum? Do you do anything to make it restart other than pushing the start button? This initially sounds like a temperature switch is opening and resetting after it cools. If you can describe the problem a little more in detail it would help.
Jan 27, 2008 | Kenmore 659 Electric Dryer
62802 stops running after a few minutes
It sounds as if you have a defective drive motor.  After the motor runs for a while and heats up, the internal thermal switch cuts it off before it gets too hot and becomes a hazard.  Once the motor cools down and the thermal switch makes up again, it will run and then repeat this process.
Oct 15, 2007 | Kenmore 62602 Electric Dryer
Kenmore 65924 Electric Dryer Logo
85 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
