Emerson lcd tv lc320em82s turns on and displays digital video but then shuts off.
  • 6,993 Answers
This problem is more or less like a bad capacitor on the power board which is making the TV switch on and off by itself.
I know of someone that had this same problem and the cause was because the capacitors used on the TV were only 10V and the welding was poor. The capacitor was replaced with 25V capacitor and re-soldered the bad welds. Now it's working normally again.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Compliments of the season.
Posted on Dec 30, 2010
Emerson LC320EM82S Unit works ok with manual buttons at top of set but Emerson remote and after market remotes wont work at all
Hello
The remote sensor inside the front panel of your TV is faulty. This is a three terminal device, can be located just behind the infrared window at the front panel of your TV. You have to open your TV, and unscrew out the front panel circuit board to access it.
Sep 05, 2011 | Emerson LC320EM8 32 in. LCD TV
Looking for parts list and or service manual for Emerson model number LC320EM82 or part number for transformer on power/inverter PC Board (note/theirs 6 of them on the board)
Tries websites like Shopjimmy.com,Ebay.com.To buy a whole refurbish LCD inverter board.No,body will sell it to u in by componnents to componnents.
Apr 24, 2010 | Emerson LC320EM8 32 in. LCD TV
I have a LCD Color TV, but when turn on, green
The most common problem is the Power/Backlight Inverter Board. There are 6 mini transformers on the board, one goes bad and the TV will turn itself OFF automatically for " Protection Mode". Replace the whole board or replace the bad mini transformer.
Part number#
Whole board, BA71F0F01042
Mini Transformer, LTZ2PC0MS008
Mar 02, 2010 | Emerson LC320EM8 32 in. LCD TV
Emerson LC320EM82 S red light will come on and when you go to power the tv on it blinks green and never turns on
Power supply board is dead,if green light on keep blinkings,notthing come on.Power green light is solid,nothing come on.Than ur Tuner signal board is dead.
Feb 09, 2010 | Emerson LC320EM8 32 in. LCD TV
When we power on our Emerson TV Model LC320EM82
The flashing light is a code for the issue with the television. Find exactly what the code is and look it up in a service manual. Then you will know what is wrong and can move forward with the repair
Sep 11, 2009 | Emerson Televison & Video
My flat screen tv does not have a picture or sound. The stand by red button is on once we press the power button the picture will come on with a message that reads digital television for about a second or...
I've had the same problem with a 32" model LC320EM82S. All the Emerson TV ( no matter what size ) are having the same issue.
I'm sure with your TV, the green light is blinking before the TV automatically turns OFF. Basically, the TV is trying to power up the screen and has failed. Protection mode turns the TV OFF to prevent other parts from being damaged inside.
My solution for fixing my TV was replacing one bad inverter transformer of six on the Backlight Inverter/Power Board. Here is what my board looks like: 767c946.jpg
You can see the six inverter transformer on the bottom of the board. It's what supplies power to the screen. Your board may look similar. You can sometimes find a whole replacement board over the internet for a good price. Shopjimmy.com is a good place to start. Just start searching by your TV model number.
If you have some electronic experience, you can repair the board itself by finding a Service Manual over the internet for less than $20. It will have all the part numbers, schematics, and diagrams you need. I would investigate the inverter transformer for your problem.
I hope I helped you out with your problem.
Sep 03, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Emerson lc320em82s need help checking inverters
OK,
1. On the power inverter board unplug all 6 wires that go to the LCD screen.
2. Test each of those ports for resistance.( the one without the resistance is the bad one.)
3. Or, test each port for Voltage output ( this will happen very briefly since the TV will turn itself off automatically).( The one without voltage will be the bad one).
Mar 21, 2009 | Emerson LC320EM8 32 in. LCD TV
Lc320em82 emerson tv
I've had the same problem with mine. Only had it for 3 months and the warranty sucks. I found out that the inverter transformer goes bad on these LCD TVs. It takes 6 of those on my power inverter board to power my 32' screen. After replacing the one bad inverter transformer, it's working again. There should be a recall for this junk part.
Jan 01, 2009 | Emerson EWL3706 37 in. LCD Television
Emerson LC320EM82S 32' LCD TV won't stay turned on. Immediately shuts down.
These have bad inverter boards, the part number is: 1FSA10164 for the MUT cba which includes the inverter board. The boards have about ten plugs and 8 screws after you get the back off.
Aug 27, 2008 | Televison & Video
Televison & Video Logo
129 people viewed this question
Top Televison & Video Experts
