When i install some thing the bios not comes.tel me what is the booting key with step by step
  • 27,725 Answers
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
hope this helps
Posted on Dec 30, 2010
I want to reformat my hp presariov6000 pls provide step by step process
First you need to have a dvd-rom. If not plug in a usb dvd-rom. Boot into your bios. F8 or F1 or F2 or Esc press once a second while booting up. In the bios set your boot order to boot first from dvd-rom, then hard drive 0 then whatever. Place you windows install DVD into the dvd-rom and reboot. Press any key to continue. Once windows install comes up choose to format the partition that windows was in previously. (hopefully you salvaged any personal files, photos, music, videos, software, serial numbers, favorites, bookmarks etc. on another partition or a usb stick etc.) after the format is over install windows. Get updates.
Nov 13, 2013 | Computers & Internet
Hp blue screen says "entering setup ..." but it is locked up instead
ok, an A6512p0b PC desk top.
VISTA.
HP media kit,? a real kit not using home made kit? from HP.
New HDD causes the F11 key to go dead (or F10 older PC)
F11/10, is the VIRTUAL install CDs/
HP put the install CDs in its own hidden install partition.
making the f10/11 key run that virtual CD installer.
now you have a new HDD, and guess what, all that is gone.
so step 2 is what, REAL MEDIA KIT. from HP.
HP has a huge pages on this, every step every way possible to restore, at hp.com ever see HP.com?
what worries me is this statement by you/'
"but cannot open BIOS." this is serious all screens must work.
you can remove the HDD and CD drives and BIOS always works
BIOS IS IN ROM, it always works or it has very very serious problems if it is DEAD. BIOS DEAD.
the screen is not dead, you see its works.
like:
  1. PSU bad.
  2. CPU overheating or heat sink bad or fell off.
  3. memory bad, try 1 stick at a time?
  4. other things plugged in to mobo that are shorted..
  5. mobo bad.
  6. GPU card bad or has problems if it has one. see #4
  7. desktops can have lots of things added, i cant see yours. inside/.
the correct kits are from HP, here.
comes with all drivers, and all HP apps. and is turn key.
https://support.hp.com/us-en/document/bph07143
there are other ways to do this, using MS disks and long day of work.
ill not teach that here.
Jun 23, 2017 | HP Pavilion a6512p-b PC Bundle PC Desktop
I need all settings and a installation guide for installing the seagate u6 st340810a into my desktop
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults)
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
as for the software if installaing from a cd/dvd insert the cd or dvd and folow the prompts if you are installing from a download once the program has been downloaded click on it select install
if you need more help with this post a reply
hope it helps
hope this helps
Apr 26, 2012 | Seagate U6 (ST340810A) 40 GB Hard Drive
HAVE REALTEK RTL8101E/8102E ETHERNET CONTROLLER PXE-E61 MEDIA TEST FAILURE CHECK CABLE PXE-MOF EXITING PXE ROM LOOP. HAVE TRIED ADVANCED BOOT . CAN I USE RECOVERY DISK INSTEAD OF VISTA DVD WHICH I DO NOT...
It is important to isolate the cause of the "PXE-E61 Media Test Failure, Check Cable" error and solve it. To do this, follow the steps below:
  1. A loose or improper hard disk cable connection can be the cause of the error. This typically happens if the hard disk has recently been installed or moved. Check all of the hard disk's cable connections before trying anything else to solve the error.
  2. Make sure that no other storage device is connected to the computer. If there is a storage device connected, remove it.
  3. When computer start up is being attempted, enter the BIOS to see if the hard disk has been set up correctly and detected in BIOS. To enter the BIOS, follow these steps:
a. The key that must be pressed to enter the BIOS varies depending on the computer model. The key is most likely the Del key or one of the F keys. Many computers refer to this as Entering Setup and Setup is just another term used for the BIOS.
b. Try setting one's BIOS to any safe default settings. That might fix the error.
  1. Verify that the boot options in CMOS are setup correctly. Follow these steps to do this:
a. Enter the CMOS by pressing one of the following keys: F1, F2, Del, Esc, or F10. Press one of these keys when trying to start up the computer. If these keys do not work, try holding one or more keys on the keyboard when the computer is booting. This may cause a Stuck Key Error, which should allow the user to enter the setup.
b. If the CMOS setup shows an option to boot from the LAN, disable this option.
c. Try to set the CMOS settings to any safe default settings, then save and exit. After changing any settings, reboot the computer.
  1. It is possible that physical failure caused the error if the hard disk cannot be detected. If this is the case, replace the hard disk and restore one's data if a good backup is available. If one does not have a good backup, contact a company that provides data recovery services. These companies perform hard disk recovery and securely retrieve one's valuable data.
Check that the drive is detected in BIOS:
  1. Press F2 during boot to enter BIOS Setup.
  2. Go to the Boot menu.
  3. Check the Boot Drive Order.
  4. Press F10 to exit BIOS Setup.
If Boot Drive Order shows No Boot Drive:
  • Check that the drive is properly installed in the computer.
  • Try installing a different known good drive.
If PXE Boot is enabled in BIOSTo check the BIOS option:
  2. Go to the Boot menu and check for Boot to Network.
  3. Press F10 to exit BIOS Setup.
If you do not plan to boot to a network, disable this option.
If you do want to boot to a network, check that the network cable connection is working properly.
Dec 29, 2017 | Toshiba Satellite Laptop
My notebook from one moment to another black screen appears a lock in the corner and I asked for a password, I can do? hopefully can help me. thank you very much from chile.
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
now for the password
If you are talking about problem with your password
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
or
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
hope this helps
or
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change first boot back to your hard drive) Hope this helps
Apr 12, 2011 | Computers & Internet
How do I boot up an operating system after my hard drive has been wiped
If your hard drive has been wiped then it means you will need to re-install your operating system onto it. To do so follow these simple instructions:
Step 1) Press the Delete key as your PC boots up. This will take you to the BIOS.
Step 2) In the BIOS find the boot disk priority. Set priority 1 to your CD/DVD drive and set priority 2 to your hard drive.
Step 3) Save and exit the BIOS.
Step 4) Insert your operating system install disk into your CD/DVD drive.
Step 5) The installation should now start.
Mar 05, 2011 | HP Computers & Internet
How to boot to CDROM? unit: IBM Intel Pentium 4 1.8 ghz
At power on, you should have an option to hit F12 or another key for boot options. From there choose CD/ROM
Aug 08, 2010 | IBM Netvista Intel Pentium 4 2.4GHz /...
Please help, I have a Proliant DL380 G3 which does not display windows. I am able to see the post boot. I can boot with smarstart cd, but when its time to install Windows 2003 or 2008, nothing comes on the...
hmm probably the boot from cd is not initiate ..go to bios settings and restore optimal factory defaults..after that rearrange the boot device order to boot first from cd..after that save changes and reboot.. ....make a boot-able cd with server 2003 ...(it is enough cause it will update to the latest if it is genuine ..) and when its done insert and reboot...it will prompt you to press any key to boot from cd ..
for most of them pressing the F8 on during the boot will get you directly to the boot menu ..and selecting the device here will bypass the bios settings ..but not all supports this ..or have the same key for boot menu ..usually it is written on the screed near the key for bios..
anyway ..I will link a fully described step by step installation ...be careful cause there are steps that are not a must to choice..but in general it almost like a Xp installation ..
the thing that keeps you in this moment is the boot device order..(probably the boot from cd is disabled in the bios)so ..go there and check ..and thats all..
here is the link to have something to consult with on the run ..
http://www.petri.co.il/install_windows_2003.htm
Mar 30, 2010 | HP Compaq ProLiant DL380 G3 Server
How do I re-format my acre aspire 5610 & install XP.
go to bios (hit del on start up) rearange boot sequence , that first boot device is cd drvie ...put winx xp in you dvd /cd drive
restart computer when it says press any key too booot from cd hit enter
žand it will start procedure for checking you configuratin and you will come to the section when it will post you your installed hard drives, format drive and install fresh copy iof xpp it is really streath forward ..you can mistake, just read.:)))
Nov 08, 2009 | Acer Computers & Internet
Cannot startup XP if connected to the 1T Buffalo HD
set first device as your harddisk is bios.
When you power up the computer press F2 or "del" key to enter in bios.then go to boot option then set first boot as hdd.
Jul 13, 2009 | Buffalo Technology 1TB DriveStation...
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
