Question about Whirlpool Dishwashers
My WHIRLPOOL LYMPIA W74 beep and the signal light blink for 6 times
3 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: Dishwasher WHIRPOOL WP 79 LYMPIA F4
F4 is typically related to a drainage problem.
If the water is not draining from your dishwasher, verify the following:
Verify that there is not a clog in the drain hose or air gap. This is typically the reason that a dishwasher won't drain and the clog is usually where the drain hose attaches to the garbage disposal or sink drain pipe. Remove the hose and clear any clogs, then reinstall.
Verify that the pumps drain impeller is working. You can reach the impeller from inside the dishwasher after removing the lower rack, spray arm, and arm support. This typically involves removing a few screws. Once upper parts are removed, inspect the drain impeller, which pushes the water toward the drain port, for any cracks or missing blades. If the impeller is defective, the water will not drain properly and you would need to replace it. Inspect the sump area for any debris or broken glass that could be blocking any ports.
Verify that the drain valve is working; many are controlled with an electric solenoid that opens the valve, sending the water to the drain. There is a chance that the solenoid or the diverting lever could be stuck which would prevent the water to drain. If so, try to free up the solenoid and lubricate the lever. Otherwise the solenoid or pump assembly may have to be replaced.
Verify that the motor is turning/ working and verify that there is power to the motor. If the motor hums but doesn't turn, it may need to be replaced. Motors can get stuck if not used regularly. If the motor is defective, the water will not drain and you would need to replace it.
There are ways to test the pump and motor with a multimeter. If you are not comfortable with doing this, you may want to have a plumber test it for you.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 06, 2010
jnchahn
  • 252 Answers
SOURCE: my dishwasher whirlpool wp 79
Unplugthe power cord to your dishwasher. You can do this by manually removing thedishwasher from the wall and unplugging it, or you can flip the power switch toyour kitchen at the circuit breaker (although you will need light to drain thedishwasher hose). 2 Put on your gloves,and, using your screwdriver, unscrew the screws from the kick plate of yourdishwasher. The kick plate is the panel just below the door of your dishwasher.3 Place your bucket on the floor in front of the dishwasher. 4 Unhook the drainhose by pinching the ends of the clamp and sliding it down the hose. Remove theother end from the pump. There will be two hoses in your dishwasher. The drain hoseis the one that leads from the pump to the underneath of your kitchen sink. 5 Pointthe hose into your bucket to drain any debris. Twist and scrunch the hose tohelp remove the waste. 6 Test the hose by running water through it, and thenreattach your hose in the same manner in which you detached it from yourdishwasher.
Posted on May 11, 2011
My 2hp Panasonic is blinking when turn on and the compressor stop working while the outdoor fan will be blowing cool air.
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard.
Jan 26, 2016 | Panasonic Heating & Cooling
My dishwasher whirlpool wp 79 lympia keeps on beeping due to a drainage block. But now I can't stop it beeping or to reset the dishwasher in order to start the program from scratch
May 11, 2011 | Dishwashers
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
The spacing lights
Check to see that the printwheel is properly installed, then check for debris in the P/W area.
DickyO
Mar 26, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
IBM Wheelwriter 6 Series II beeps
Three beeps and the space lights blinking means the batteries are bad replace them and be sure the holder is clean.
DickyO
Feb 14, 2009 | IBM Office Equipment & Supplies
Whirlpool DWF B00 W
Hunca, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Hunca), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Blinking light cycle won't start
sounds as if you have a bad door latch assy, the unit is not recognizing the door closed, so when the button depressed probly only beeps 3 times at you. check the lock/latch for an obvious broken part
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool DWF B00 W
Raise temperature of your water supply. Open door and press hi-temp srub,then energy saver, then reapeat this within 3 seconds. Close door and hit cancell.
Jun 02, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
691 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
