Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
MAGNAVOX DVD/VCR RECORDER
DOES NOT DO TIME RECORDERS
  • jwatkins602 Nov 21, 2008
    My machine also shuts itself off after approx 15 seconds. I turn it back on and it will shut off. HELP
I have been using my machine with no problems, until recently. The machine will not stay on more than a few minutes when I try to use it, either watch a tape or tape a show. It starts, then just shuts down. When the machine is turned back on it ejects the tape????
Can you help, please.
Thanks
Sharon
Posted on Sep 16, 2008
SOURCE: dvd/vcr recorder/magnavox
I'm on my second Magnavox MWR20V6 recorder in less than a year. I've made close to 1,000 DVDs, mostly dubbing from homemade videos of TV shows, but it's not been easy. They have some finicky quirks that aren't mentioned in the manual.
The second Magnavox I got worked far better than the first, and really has been pretty satisfactory. The first one (which finally just died) never had decent tracking, even when I was copying a video tape I'd made on the same machine to DVD!
I got the error e4 54043e02 on both machines. I'd be using the exact same brand and type of DVD that I'd used for hundreds of other times, but I'd get a new spindle of DVDs and few or none of them could be formatted, and were unusable.
I think the problem might be with the DVDs. I have tried all the brands I could find. I first tried Maxell, as recommended in the manual. They worked fine (both -RW and +RW) until one day they just quit working for me. The worst were the ones that had CPRM printed on the DVDs around the inner hub, but I couldn't find any way to tell (before buying them and opening the package) which disks were this type because the label on the package was identical to the Maxell DVDs that worked. I contacted the company and sent them all the DVD numbers and error codes but they didn't tell me anything. It seems to be some kind of company secret.
Then I tried Memorex DVD+RW 4x and they worked very reliably-- until the last pack I got. I'm getting the e4 54043e02 error again!!! I emailed the company but haven't heard back yet, due to the holiday weekend.
So my big complaint is that I can't find ANY DVDs to use for recording. What I've seen so far on the internet gives me the idea that blank DVDs are kinda junky or unreliable in general, also that it's a VERY good idea to keep those old video tapes, which might end up lasting far longer that DVDs anyway. I'd hoped to get rid of the old VHS tapes due to the storage space needed for them, but it looks like I won't be. Unless I can find good DVDs, I'll just go back to VHS recording.
Incidentally, Memorex gives me the impression that they'll refund my purchase price, while Maxell had no interest in making a refund!!
Also I think the DVD-R give fewer problems, but I use +RW for nearly all my recording because I like to edit them. I'd suggest trying a DVD-R if you get desperate.
Posted on Jan 01, 2008
SOURCE: can't setup Magnavox DVD VCR recorder
Put your TV onto chanel 3 to pick up your Magnvox signal
Posted on Jan 06, 2008
  • 173 Answers
SOURCE: Magnavox VCR/DVD recorder model ZV450mw8.
You will need a technical person to open the unit. This problem can be as simple as a dirty sensor, or bad tape drive parts, or burned out computer chip.
Posted on Feb 03, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Magnavox DVD recorder...finalizing problem
The manual isn't too helpful either - "Recording error other than below," it says. There are a couple of possibilities. The Philips/Magnavox/Funai recorders automatically record in VR mode when you use +R discs (there are two possible recording modes - V Mode and VR Mode). Is it possible that you have switched disc types lately? If you are currently using -R discs, switch to +R and vice versa. The manual states that +/-RW discs take a while to initialize.
I couldn't find a full factory reset on that one, so you may have to unplug the unit for about 20 minutes to restore all the defaults.
Another possibility: Finalization requires some extra space on the disc. If you accidentally pressed the button that changes the recording format between SP, EP, LP, etc., you may not be able to fit the same amount of video on the disc that you were able to fit before. You can change the format by pressing the Disc Mode button on the remote - LP Mode will fit 3 hours worth of recordings onto a 2-hr disc and is considered a "medium quality" recording. Try changing the Disc Mode to LP and see if it will finalize the next disc that you record. The downside of this possibility is that the discs that you have already made that are giving you errors are not "fixable" - you will will have to re-record the shows to a new disc in LP mode.
-Tha Mp3 Doctor
Posted on Feb 15, 2009
  • 814 Answers
SOURCE: Dont know how to finalize dvd after recording on magnavox vcr/dvd
You can find a copy of the manual on the web link provided here:http://tv.manualsonline.com/manuals/mfg/magnavox/mwr20v6_1.html Print a pdf copy for yourself. If you need more help the customer care for you dvd/vcr player is at this telephone number. 1-800-605-8453 give them the model number of your dvd/vcr unit and they will be able to help you. I hope this information helps you with your problem.
Posted on Jun 02, 2009
Have philips univerasal remote need codes for my panasonic dmr-ez28 dvd recorder
Panasonic DMR-ES30VS DVD Recorder/VCR Universal ...
www.fixya.com > ... > Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DMR-ES30VS DVD Recorder/VCR, universal remote related issues. Getfree help ... My remote does not work anymore. what is the code for a universal remote? Thanks in ... Question about Philips DVD & Blu-Ray Players ... How do I getremote code for GE universal remote control Need remote code? How to ...
Philips Magnavox MWR20V6 DVD Recorder/VCR Remote ...
www.fixya.com > ... > Philips Magnavox MWR20V6 DVD Recorder/VCR
Dec 20, 2015 | Panasonic Televison & Video
I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have...
I have a phillips magnavox Problem with the Philips Magnavox MWR20V6 DVD Recorder / VCR Combo I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have cleaned the lens with a disc cleaner and still didnt help,same thing is happening. i am also using the same type of disc that I have been since day 1. Can you help??
Mar 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I am attempting to record from a VCR tape to
I have a Magnavox MWR20V6 and I am attempting to record a Tv show but when I play it back the recording is just black.
Jan 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Hi! I have a Magnavox DVD recorder/VHS combo. I
alot of times when the video cord gets pinched it will go to black and white you just have to replace it if that dont work. then its one of the machines.
Nov 06, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox ZV450MW8A DVD/VCR Recorder Dubbing.
I bought a ;magnavox dvd disc and cassette recorder combo.
I am having trouble with setup items? I get nothing on the screen to select from?
Oct 24, 2009 | Televison & Video
Want 2 record from my DVR 2 Magnavox DVD Recordable/VCR MWR 2046
should have avi scrat out at back of DVR place scrat lead here and the other end into avi scrat input on your DVD recordable & feed to screen as normal.
if no scrat scoket avaible you can get a converter to switch from one to other.See your local dealer.
And happy days of u go.
Aug 07, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
May 10, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dubbing vcr to dvd-
its the copy protection system doing this. if you have another dvd player or vcr, you can hook that up to a time base corrector box and run the output out of that to the dvd recorder, allows recording from any source.
Oct 04, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My vcr won't play back
I have a Magnavox zv457mg9 DVD&VCR combo ,and the vcr records for a short period(10minutes) and then cuts off. This happens each time I try to record on the VCR. Any suggestions??
Feb 26, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox MWR20V6 problem
on my magnavox mwr20v6 i cant record my vhs to dvd i get black screen every time and my DVD are new and I just open my magnavox after a long long time and ecsup for get my VHS record to DVD it is fine I would like to fix this issue :(
Jan 01, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
254 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
