I want to change my operating system vista to xp so i need xp driver so how can i get driver
  • Computers & ... Master
  • 27,725 Answers
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
the driver should be on the disc
hope this helps
Posted on Dec 30, 2010
Driver for dcr hc 62e
Windows 7
* Drivers:
o The drivers needed to connect your Sony camcorder to a computer and transfer files are already included in the operating system.
* Not Supported:
o The USB streaming feature is not supported with the Windows 7 operating system.
o The Windows 7 Starter edition is not supported.
Windows Vista
* Drivers:
* Not Supported:
o The USB streaming feature is not supported with the Windows Vista operating system.
o The Windows Vista Starter edition is not supported.
* View Detailed Windows Vista compatibility information.
Windows XP
* Drivers:
* Not Supported:
o The Microsoft Windows XP 64-bit operating system is not supported.
o The Windows XP Starter edition is not supported.
Mar 09, 2011 | Sony DCR-HC28E Camcorder
Cannot load drivers
there isnt such thing as impossibility to load and install drivers..if the system refuses the drivers you try ..this means that they are not the one you need to install ...Even if the drivers came on a disk with the laptop ...if you changed the operation system ..or the the bit of the system ..you need another set of drivers..
To be more clear for example if you installed windows 7 and use to have vista ..you need drivers for windows 7 ...even if some of them for common devices may fit from vista 32 to windows 7 32..Or ...if you downgraded from Vista to windows XP..you need drivers for xp ..and the other way around...The only way the drivers you have will fit after re-installation if you have the exact same operating system reinstalled..
So..this will be the site where you should download the drivers for you operating system..
http://www.acersupport.com/drivers_download.aspx
so ...choose the model ...notebook ...aspire/4520..after that choose from the 3 main windows ..xp .....vista ..or windows 7 ..and download all of them one by one ..and install ..
May 12, 2010 | Acer Aspire 4520-5582 Notebook
Does nt work with xp/vista
You probably need to update the drivers for Vista and/or XP to work with this printer. Select the operating system you have and download the drivers.
HP Vista (32-bit) drivers and downloads
HP Vista (64-bit) drivers and downloads
HP XP (standard) drivers and downloads
HP XP (64-bit) drivers and downloads
Link for all other operating systems
HP resources for Laserjet 2550n (troubleshooters, support etc.)
Nov 13, 2009 | HP LaserJet 2550n Printer
Change operating system
You can keep both Vista and XP. Below is the way to install XP, after Vista was already installed... creating a dual boot. First find the drivers for your network components, wireless card or nic, and save them to an external device such as a floppy disk or flash drive. Then you will need to go into the BIOS on your computer startup. Scroll to the System Configuration tab and go down to the SATA Native Support and change its setting to Disabled. Then hit F10 to Save and Exit. Next, insert your Windows XP CD and create the partition you wish to install XP on. After the installation is complete you should boot automatically into XP. Now you need to move some files. First, make sure you have set your folder options to see hidden files and to show protected operating system files. Then open Windows Explorer and go to the drive where Vista is installed. Copy the folder Boot, and the files bootmgr, boot.ini, NTDETECT.COM and ntldr and paste them to the root of your XP drive. Then download Vista Boot Pro and save it to your desktop or somewhere else that you can easily access. Unless you already have .Net Framework (v2.0 at least) it will redirect you to a Microsoft page where you can download this necessary component. Install and run Vista Boot Pro and open the "Bootloader" tab. Select "Reinstall the Vista bootloader" and press Apply. Then go to the Manage OS Entries tab and select "Add new operating system entry" and make sure you select "Windows Legacy". Give the new entry a name (ie: Windows XP) and select the drive letter you have XP on and then select Apply. You can also choose which entry you would like as the default the system will boot to. And now you should be able to dual boot between Vista and a previous OS. Thank you! Sabharish
Jun 15, 2009 | HP Thin Client - AMD Geode NX 1GHz - 256MB...
Respect sir, i have bought your dv41124 nr laptop. in my laptop your hp member should be installed vista. but i don't know about vista family and i easily known about windows xp system. so, i want change...
Yes you can downgrade the Operating System to XP. After installing for drivers you need to download it from web Click Here to Download
Thanks & Regards
Nanda kishore.
Jun 09, 2009 | HP Pavilion dv6000z Notebook
Sound driver
here is the link for the XP drivers
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3739730&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20%BB
Choose windows xp as operating system and download the drivers... install it... it would be fixed..
Nov 22, 2008 | Compaq Presario 700 470024-192 Notebook
Operating system
first of all you will have to format your laptop cause when you have vista u cant install xp with it
u will have to install xp first and then install vista
about the driver u will have to do some settings in cmos setup and will have to change hdd type
that will solve your driver problem
so first install xp and then install vista
regarding drivers for xp u will have to visit hp website and chat with a online technical person and ask him to mail you the link for drivers for xp
Nov 13, 2008 | Computers & Internet
Hp pavilion a6110in
you dont mention the drivers you need, you dont get drivers for software as you say, but if you mean the motherboard drivers, you will have to find out the maker of your board then search the relevant makers web site for drivers. The only problem you may come across is that the bios may have a different version for Vista than that of what you need for XP so there may be some problems stting up the motherboard drivers.
Sep 01, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
David Payne
David Payne
