Question about Visonik Dual Bass Box with Amplifier Car Audio Amplifier
I dont know why my amp is not getting any power? the power light wont even come on? everything seems to be connected properly, but its not getting any power?
    Guru:
  • 680 Answers
Make sure you have both power wires hooked up. There's the main power lead/cable going to to the battery, and the trigger wire from the accessory wire from the radio (antenna) to the amplifier. Hope that's what you were looking for. If so please rate my assistance and leave a testimonial.
Posted on Dec 30, 2010
My monitor won't turn on properly. It just cycles power on and off at the opening Dell Screen.
please check proper powersupply & when power is ok then open the monitor & check fuse ,main filter capacitor& bridge diode.
Jul 04, 2013 | Dell ST2210 21" Monitor
Theres a light on inside my amp, but the power light wont come on. ive rewired it several times and it still wont work, i really dont want to buy a new amp. what do i do?
First and foremost, check your fuse at the battery terminal. Then make sure you are getting your 12V from your remote turn on, and lastly make sure all of the connections are properly terminated.
Sep 19, 2010 | American Pro VS1404 Car Audio Amplifier
I just dont know how to plug everything with it...Power button comes on if you move the amp...sparks if touches with a a screw....dont know which connections to put where
Black is ground(hook to a bolt going into metal on vehicle). Red is switched power(only on with ignition on). Yellow is power(power even if ignition is off). Blue is amp turn-on(located at radio and sends signal for amp to turn on). It is sparking because you do not have it grounded properly. You can damage your amp and or you car's electrical system....be careful. Always pull a main fuse or disconnect the battery when wiring a car audio system.
Sep 16, 2009 | Boss Car Audio & Video
I have an 87 prelude si thats been sitting in the garage for three years. i got it to start the other day and everything sounded in great shape still. the only problem is that now, even while everything is...
You need to start with the battery. It should be load tested to verify that it's good or not. You can take it to a auto parts store to be tested, usually for free.
Sep 11, 2009 | 1987 Honda Prelude
Xplod amp will not get off of power protection mode
if the protect light stays on the amp is blown or has flawed components and is only repairable by expirenced sony tech
May 18, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
SuperMicro H8DCE-O R Motherboard no video
did you plug up toe power to the video card, the problem seems to be that the video card is getting no power, if the power is hooked up properly to the video card, the your power supply is probably not powerful enough.
Dec 04, 2008 | SuperMicro H8DCE-O R Motherboard
Hifonics Brutus BXi 1208d Amplifier
Possibly you need to return the amp and get a new one cause that could mean an internal problem and its deffective, you could try replacing the fuses or try changing the ground wire, this problem is very unusual
Sep 13, 2008 | Hifonics Car Audio & Video
My kenwood amp wont turn on
What kind of "Clips" did you put on? They may be causing too much resistance and preventing the amp from getting the current it needs. Double-check with a voltmeter that you are getting at least 12 volts at the amp power connections and make sure your ground lead is as short as possible and connected to solid metal of the vehicle's chassis.
Aug 10, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Siemens gigaset se587 error message 106
Look in Start - Connect to - Show all connections - If you have an Internet Gateway and the Internet connection shows disconnected - Double click the line and it will connect.
Now if I could only work out why it doesn't do this automatically ....
Also Use Internet Explorer to connect to http://192.168.1.1/ which should allow you to log into the router directly and set the log on details and logon password.
Regards
May 29, 2008 | Computers & Internet
My phone dosent turn on or nothinq
When the battery is totally depleted, you will need to use a charger that came with the phone. Sometimes it will take a few mintues (give it 10) for the battery/charging circuit to come on.
Sometimes you can charge from other sources than the charger that came with the phone. You generally will need enough charge on the battery to start the phone.
Example: If I have enough battery to where the boots and turns off, I can generally get it to charge from USB or my car adapter. You will need to get the phone to turn on and boot most of the way up before it will take a low current charge. If my phone is so dead it will not even turn on, I must plug it into the AC adapter. Sometimes even then the light does not turn on right away.
The problem is probably due to the number of amps provided by the charger. When the battery is totally dead, the charging circuit is drawing so many amps that it will prevent low amp chargers from being able to do the job. That's why these phones have such heavy duty AC adapters.
Apr 28, 2006 | T-Mobile Sidekick II
Visonik Dual Bass Box with Amplifier Car Audio Amplifier Logo
64 people viewed this question
Top Visonik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Joe Alexander
Joe Alexander
Jerry Umali
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
