Question about Dell DJ MP3 Player
Did you get your dell dj fixed
I have the same problem of it going to the rescue mode when it reboots.
Any help would be appreciated.
Thanks
rko
  • rko1 Jul 11, 2008
    thanks nickster..... wow Dell didn't even offer to have it fixed, trade in allowance, no nothing.
    Probably going to be looking for a I pod.....
    Appreciate your interest though... Have a good one.....
    rko
Did you try resetting it?
Posted on Jul 30, 2008
Its broken dude unfixable. sorry..... your just going to have to get a new mp3. I've tried everything and just threw that stupid piece of technology away.... couldn't even salvage the other parts to fix a cd player
Posted on Jul 11, 2008
  • 3 Answers
Roll your WMP app back to 10.0 if you have upgraded to 11 or beyond. Then get the fixup.zip file from the link below (near bottom of page), unzip it and run it. Follow its instructions to delete the Dell DJ device from the hardware device manager when it prompts. This will allow the Dell DJ to be recognized as a 'MTP' device. Download the Dell DJ 1.02 firmware from the Dell site and run it. You should choose 'firmware upgrade' from the DJ recovery menu prior to starting an upgrade.
fixup.zip file site: gotzune.com
Posted on Aug 11, 2008
Firmware error
Try going into rescue mode by pressing the Play button while inserting the end of a thin object such as a straightened paper clip into the reset at the same time, then hold the Play button until your Dell Pocket DJ turns on.
Scroll to "clean up" and select. This just defragments your players hard drive, you won't lose any data.
If that doesn't fix it try replacing the firmware. Download the most current firmware from Dell's support website. Scroll to and select "reload firmware" in rescue mode. Connect to pc with usb cable and power on player. Double click the firmware file on your pc and let it do it's thing. This won't affect your saved data either.
If neither of those work you may need to reformat the players hard drive. This will wipe out anything you had on the player. Scroll to and select "format all" while in rescue mode. Select "yes" then just watch the progress bar. Good luck!
Feb 17, 2010 | Dell DJ MP3 Player
Dell Digital Jukebox
Anything unusual happen to the player before the problem started? Dropped it or perhaps unplugged it from pc while synchronising? The most likely fixable problem is a loose connector on the HDD/main board cable, or a failing battery/power adaptor giving the HDD a voltage too low. unfortunately however the HDD on these players is a bit vulnerable to rough treatment. When you connect it to a computer, does it still appear as normal or is it not recognised etc. What operating system PC are you using - perhaps formatting from the PC first before trying to install the firmware will help. Are you using the latest firmware from Dell or are you using a cd that came with the player? Is your player still under warranty or do you want to try and open it up and have a check yourself. Let me know more info and what you wish to try :)
Aug 17, 2007 | Dell DJ MP3 Player
The solution to many random problems is to simply reset your Dell DJ. This can be done by using a small, thin object (such as the tip of an ink pen) to press the reset button that is on the bottom-left side of the DJ. -or- Hold down the play/pause button while it's off, insert a paperclip into the reset button, take it out, and then let go of the play/pause. The DJ should open to a rescue mode, then run disc clean-up.
Problem with DELL DJ20 firmware
hello here is an solution...
1. uninstall the windows media player 11(program and runtime) 2. Uninstall all drivers USB ( root and controllers) 3. Restart computer 4. At this point go to your frimware updater and run it..
Sep 19, 2009 | Dell DJ MP3 Player
Dell dj is non functional
Hold play button while inserting a paperclip into reset opening on dell dj. Release paperclip while still holding play. Recovery mode should come up hopefully.
Dec 25, 2008 | Dell DJ MP3 Player
Dell dj gen 20
it is possible the the battery cable is unpluged
Mar 03, 2008 | Dell DJ MP3 Player
Dell DJ won't reload or reboot
I would first suggest reformatting the DJ from Rescue Mode, and then try reloading the firmware from here: http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R107735&SystemID=PDA_MP3_DJ_2&servicetag=&os=WW1&osl=en&deviceid=9420&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=1&libid=31&fileid=139674 If neither of those work, it may be time to look into some repair options. John Dell Customer Advocate
Aug 06, 2007 | Dell DJ MP3 Player
Dell DJ MP3 Player Logo
809 people viewed this question
Top Dell Audio Players & Recorders Experts
dochubert
dochubert
Level 1 Expert
SmartAviator
SmartAviator
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
