Without knowing the camera make and model I can only suggest you check your owners manual on how to format your memory card, your manual may also call it initialize.
I'm also going to include a diagram that shows the SD sliding lock, if this lock is in the lock position a whole sea of problems can "pop" up. the lock function is there top protect pictures or files on the card from being deleted by mistake. However sometimes these annoying little trouble makers get pulled down into the lock position.
Here is the diagram. Remember check the lock and then format/initialize your memory card also after each time you download your images from the camera or the optional card reader you must format the memory card to have the camera properly function with the memory card.
Hope this helps have fun with your camera
The following digital camera memory cards are
compatible with your BenQ DC E53. Every digital camera memory card we
offer is manufactured to the highest standard and carries a 2 year
minimum warranty.Your BenQ DC E53 accepts SD Card cards.The largest SD Card card you can use in your BenQ DC E53 is 2GB
So you can buy up to 2GB SD cards.
