SOURCE: how to download games through internet
i have a psp and go on the net to but you can't download them on to your psp i tryed but you jest can't
soury
SOURCE: game download
To download games through the internet, you need a USB cable and choose USB Cable on the psp menu. Go to psp.connect.com and choose your game. After signing in, choose download and it will begin. After it is done, go to the memory stick content icon and choose your game.
SOURCE: how to connect my psp to the internet
You need to get to the main menu from wherever you are on your PSP. You can do that by pressing the Home button, a tiny button just to the lower left of the screen.
Now you'll want to move left (pressing the "<" button) until you get to Settings, then down (pressing the "V" button) until you get to Network Settings:
Now you'll have two choices: "Ad Hoc" is when you want to connection
two PSPs together with any sort of Internet wifi base station / access
point involved, and "Infrastructure Mode" is when you connect to your
local wifi device. The infrastructure mode is what you want.
You'll probably only have the one choice of New Connection, but if you don't, choose it anyway:
First option is to specify a mnemonic connection name. The default here
is "Connection 2" but yours might be "Connection 1", or similar. I
recommend you actually enter a different name so you'll be able to
remember what location works where.
To enter a new connection name, press the "X" button and you'll get to the "keyboard" screen:
When you're done struggling to enter your selected name :-) move to the
green "Enter" box and press the "X" button. Now you'll be ready for the
big important step: a Network Scan:
If everything's working well with your device and you've turned on the WLAN switch (How to turn on the PSP WLAN Switch) you'll see the following status message:
Hopefully, you'll see at least one network listed, if not more. If
you don't see any networks, then you're out of luck. If the only
networks you see have some sort of security setting, either WPA or WEP,
then you must know the security password to access that network.
Once you're ready, the next step you'll want to take is to select an access point:
In this case I'm going to select Steve Hardesty since it's the strongest network with the Security setting of "None":
Now you'll have a chance to confirm your security setting from the
different choices. Notice that the default is just about always the
correct choice, which you can select by pushing the ">" button again
and again:
Now you can also step right past the Address Settings:
You'll get a confirmation screen that shows all the settings you've specified:
Press the ">" button again, and you'll be able to save your settings
That's what you'll want to do: press "X".
Now, the most important step in the process - to Test Connection.
You'll most definitely want to do this! Press "X" to start the test...
If your test succesfully passed then you are online. If you failed start from step one.
Please rate my answer. I hope this helps you.
SOURCE: how to transfer downloaded games to my psp?
You should create an iso folder, put your games in there: XXX/ISO if it is in cso or iso format. Do not put 7Z format or just winzip, etc
