Question about Pioneer Audio Players & Recorders
I have this pioneer receiver model VSXD608 in which when the volume goes below 20db the unit goes in protection and after some time it tries to switch on back but goes to protection again and keeps on doing this on / off i have repalced the sound op ics but the result is same as it was.
    Genius:
  • Pioneer Master
  • 1,689 Answers
Check to see that the electrolytic capacitors that are in the output stage circuits and driver stage circuits are not high in ESR.
Check to see that the power supply is in specs. The main electrolytic caps may not be up to specs. To test the power supply it is best to run a load test on it. You will need the proper setup for this.
The supply current to the output stage may be high, and thus causing the protection to turn on. You will need to have the service manual for details.
It is also possible that the speakers are too low impedance, or their crossovers are going defective and causing a miss-match for their loading impedance.
Look with a scope to see that there are no high frequency oscillations in the output of the amp going to the speakers. A common cause of this type of fault are worn de-coupler caps in the bias circuits for the various stages along the signal path.
Check to see that there is no DC out to the speakers with any position of the volume control with no signal going in. The speakers must be disconnected for this test. Do the same with a sine-wave signal from the test generator. 1 kHz is good to use for this test. Use a proper rated 8 ohm dummy load for your amplifier when applying the test signal. Do not put steady strong tone in to your speakers. You will have to refer to the service manual to know the allowable DC offset at the output stage to the speaker terminals. Most consumer amplifiers must be less than 50 mv. The higher end amplifiers are down to less than 10 mv.
It is also good to do a distortion test to see if there is too high a distortion that is causing the protection to trip.
You can also use the dummy load and the audio generator along with the scope to do power handling tests. This gets involved to put over this type of email.
These are only some basic examples of what to check. You will need the service manual, a scope, ESR meter, DVM, audio generator, and distortion analyzer to go through all the tests to find out where the fault is.
Jerry G.
Posted on Jul 08, 2008
I have Pioneer VSX-1027; the volume drops 3 digits every three minutes and it keeps dropping three digits every three minutes until it reaches to the minimum..! Why does this happen? How to fix it?
It is a problem with the temp sensor circuit. The unit thinks it is getting hot, so it is trying to turn the volume down to avoid overheating. You either has a bad thermal resistor on the amp board, or you need to change the cpu board. Best to have it looked at by a pro.
Sep 26, 2016 | Pioneer Audio Players & Recorders
How do you get a pioneer receiver model vsxD702s out of protect mode
Most of the time the receiver goes into protect mode because one or more cores from the speaker cables touch the chassis and cause a short circuit. Check if all the speaker cables are properly connected (twist them so no cores stick out)
Mar 21, 2016 | Pioneer Audio Players & Recorders
My Pioneer volume button on my car stereo does not work it stays at 1 volume
check your documentation...it may be that you have a volume limiter control on your unit. Some audion devices have these to protect the owner's eardrums.
Do a web search for the owner's manual
Jun 29, 2015 | Pioneer Car Audio & Video
Pioneer vsx 52
I am trying to work out which has got the high volume.
If it is the Pioneer then it could be the volume control chip that is faulty. These days volume is no longer determined by a control that adjusts the signal level. The signal is passed to a chip and the volume control setting information is also passed to the same chip. If the chip goes faulty then the volume will sometimes go to max, regardless of the volume control setting. This can also apply to the TV sound as well.
If the sound level is high on other functions of the receiver, such as the radio, then it is certain to be the sound volume control IC.
Nov 10, 2017 | Pioneer Elite VSX-52
Dear Sirs, I have a Pioneer AV Receiver model VSX-817 and is connected to Monitor Audio Speakers (Fronts: BR5, Center: BR-LCR, Rears: BR1), Sub: MS309 (Mordaunt Short). I have connected each front...
Did you remember to remove the shorting link on the MA BR5 speaker terminal ..When you biwire the speakers you should remember to loosen the speaker terminal nuts and remove the shorting link plate between the HF and the LF terminals or you will short the amplifiers two channels together through the link. And modern amplifiers will take a lot of abuse at low volumes but at high volumes the protection circuit will turn off the device.
Apr 10, 2011 | Pioneer VSX-817-S
On my Pioneer vsx-55txi, the protection circuit cuts in whenever I raise the volume to a reasonable level. If I sit 10 feet or more, the volume is too low. I don't like my music or movies loud, but this...
The protection circuit is enabling because the output transistors are 1. drawing too much current causing them to heat-up 2. the transistors are going out 3. the threshold level for the quiesce state is set too high and may need to be adjusted internally. Try to cool down the Unit and see if it occurs again.
Nov 28, 2010 | Pioneer VSX-55TXi 6.1 Channels Receiver
Flashing Red MCACC Light
hold the tune down (-) button and multi zone on/off button for two seconds then receiver should reset on the VSX-1019AHK model!!!
May 22, 2010 | Pioneer VSX-1019AHK A/V receiver
Overheating and shutting off
Most commonly there could be a place where wires are touching from + and minus, check all wiring to the speakers. Extra speakers would create too much load, disconnect all the speakers. Check the wires and speakers by hooking one speaker at a time back up. Of course you must turn the receiver off every time you make any changes there. Add one speaker at a time.
If it's overheating it will shut off because its likely that you are asking for more then the amp can deliver. It's protecting itself. Try turning it down and gradually increasing the volume until you find the level below shutdown. If that fixes it that's all it can deliver.
Mar 30, 2010 | Pioneer VSX-D711 Receiver
Pioneer VSX-1019 with a flashing red MCACC
you can "release" the error by pressing the "down arrow" and the "zone 2 on/off" for 2 seconds.
Mar 11, 2010 | Pioneer VSX-1019AHK A/V receiver
Protect is ON
Either there is a bad capacitor in the protection unit or you can find the wire that goes from volume control to protection unit and unplug it.
You can also try turning the volume all the way off before turning on, then slowly turn up from there
Jul 20, 2009 | Denon AVR-900 Receiver
94 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
