Question about Crosley CE35100AA Electric Kitchen Range
F5 e1 in the display of my stove - Crosley CE35100AA Electric Kitchen Range
Activated the self-clean function. When it was done, the display said E1. F5. door is still locked. have pushed the off button, the display says END LOCKED CLEAN, then it goes back to the original E1....
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.D@#$
Jul 24, 2010 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
I just want to know what E1-F5 means in my self cleaning oven.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%#$ER
May 19, 2010 | Stoves 600SiDOm Gas Kitchen Range
Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
Mar 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
What does an E1 F5 error on a Kenmore stove mean.
Dec 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Have Whirlpool Electric Range super capacity 465 with accubake system. Turn off power to stove to clean oven and back of stove. Finished cleaning and turned power back on and get this beeping sound every...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^TF
Sep 24, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
E1 and F5 are on digital read out instead of 500degrees and cleaning
The E1 and F5 is a code that the door latching system is creating a fault. YOu might be able to take apart the door latch mechanism, and recondition it.
Apr 26, 2009 | Kitchen Ranges
Kenmore stove elite 790
**E-1,and F-5**
Some of the codes in the clock where programed backwards....some may show E-1,and F-5 and some may show F5 - E1.
F5 - E0 F5 - E1 and E2
Check door/latch switch
Replace switch if defective
OR
F5,6,7 EOC failure Replace EOC
Feb 22, 2009 | Kitchen Ranges
Whirlpool stove Super Capacity 465 problem
Hi dcisco,
Happy to help you!
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Aug 23, 2008 | Whirlpool GS460 Gas Kitchen Range
Problem codes for self-cleaning ranges
My experience (Kenmore Ultra-bake Model 665-72002102) was that E1 F5 meant an error with the oven lock switch. In our case, the latch was partly stuck from food or other debris. Just moving the latch back and forth loosened the scale that was making it stick, and it worked again.
Dec 05, 2007 | Kitchen Ranges
Crosley CE35100AA Electric Kitchen Range Logo
Top Crosley Kitchen Ranges Experts
Rob
Rob
Level 1 Expert
Lawrence Oravetz
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
