Question about De Dietrich Dishwashers
I have a built under de dietrich dishwasher approx 4 years old and out of warranty. The various numbers on the identification are 1) 02062A 2) V29996U1/1 3) 36VLDHGB1 4) 9 44 02319. The drop down door has lost it's tension from the hinge/hinges,and crashes down when opened. I have to hold and lower it down when opening. Can this be repaired or do I need a new dishwasher? May Mc Pherson
  • 42 Answers
SOURCE: Difficult to pull door open and loud click coming from left hinge
I would check for obstruction in the path of the door spring areas. If appropriate, remove the bottom access panel (typically 2 screws); open/close the door in attempt to observe the inside bottom left and right for the clicking sound.
If not already done so, also ensure your dish-washer is raised of the floor a little bit; leveled and properly secured to counter top with 2 screws.
-C
Fremont, CA
Posted on Jan 30, 2009
landsend
  • 1066 Answers
SOURCE: sears dishwasher soap dispenser door wont open-loose spring
with new parts ...yes.
Posted on Mar 13, 2009
CarMan
  • 33 Answers
SOURCE: Where can I order the part and fix it myself???
Here's a suggestion that I use all the time.  Sears carries most brands now.  Their service and parts departments are 2nd to none.  Go to sears.com - parts - see if your kitchenaid is listed,  if so you will find all the parts you need with super delivery right to your door.
Good Luck,
Doug
Posted on Jun 07, 2009
  • 457 Answers
SOURCE: how do i adjust the tension of the door hinges on
you cant you only can change the springs. probably one is broken
Posted on Feb 25, 2010
  • 457 Answers
SOURCE: leaking door on Bosch dishwasher
I DONT THINK THERE IS A ASSEMBLY MANUAL BUT THE DOOR HINGES IS LOCATED UNDER THE LEFT AND RIGHT SIDE OF THE MACHINE. YOU HAVE TO CHECK THE HINGE PULLEY THEN CHECK THE LOCK.
Posted on Apr 19, 2010
How do I find the instructions manual for De Dietrich DOP705X Multifunction Plus Electric Built In Single Oven (DOP705X)
Go here: http://www.dedietrich.sg/sg/collections/oven.html#/others/user-manuals-10/ then look under User Manuals. Put in Model Number Collection - Cooking Range (or Product Number, if known), Available Language (EN), then download Manual in PDF
Dec 26, 2014 | De Dietrich Ovens
Where is the flood switch on die dietrich dishwasher dvh640ju1
these are normally in the bottom of the dish washer
micro switch controlled by a float
Feb 15, 2014 | De Dietrich DVH610JU1 24 in. Built-in...
It does not rinse properly, leaving a film on
Pump worn out, using too much soap and depending on where you live there may be a more concentrated amount of minerals in the water. Florida residents are having that problem in spades due to our drought.
Oct 10, 2009 | De Dietrich 18 in. VZ9456 Built-In...
Washer starts program but sound much noisier than
Suggest you check the water pressure out the pipe, then clean the inner sieve which is usually in the valve inlet. if all is clean and still little water enters, i would replace valve.Also, chech the pressure switch line an make sure it is not partially filled with water.
Sep 21, 2009 | De Dietrich 24 in. DVF120J Built-in...
Frigidaire = Garbage
go with a kenmore reasonable price ....work very well and sears is very good re their appliances per warranty
Aug 23, 2009 | Frigidaire 24 in. PLD3465REC Stainless...
Leak from a De Dietrich Integrated Dishwasher has caused 3 red lights on the left of the Control Panel to flash and also a Blue Light on the right hand side of the Control Panel to flash. On resetting...
Pull the built in unit out and tilt towards the rear right leg and the water will drain on to the floor. The Dishwasher then restarts but the anti flood sensor will reactivate after 2-3 more washes. Do not know final fix yet.
Oct 05, 2008 | De Dietrich Dishwashers
Dishwasher
WAS IT IN A CERTAIN CYLE WHEN FUSE BLEW
Jan 17, 2008 | De Dietrich 18 in. VW7451 Built-in...
Built in De Dietrich dishwasher
I suggest you get all your staff to search tirelessly for an answer, ChrissyJ!
Oct 02, 2007 | De Dietrich 24 in. DVF120J Built-in...
Dishwashers Logo
37 people viewed this question
Top De Dietrich Dishwashers Experts
richie46
Are you a De Dietrich Dishwasher Expert? Answer questions, earn points and help others
