Question about Amana SXD524VW Side by Side Refrigerator
AMANA SIDE BY SIDE circa 2001 model number SBDE522VW Need the bottom grill under the doors
aborcass
  • 2651 Answers
SOURCE: Amana side by side red turn knob at the bottom what is it?
thats the defrost timer. its merely a clock thatcycles the refrig in and out ofdefrost cycles,shouldnt be set to any particular place, it will free turn just a s as clock will
Posted on Feb 03, 2009
  • 531 Answers
SOURCE: side by side leaks out front door on freezer side
you may have defrost problem
Posted on Apr 07, 2009
  • 4 Answers
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Posted on Apr 19, 2009
woodchuck789
  • 4059 Answers
SOURCE: cracked leaking door seal
Part 201 on this diagram and you can look at the freezer door diagram for it. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=18149&diagram_id=782438#d782438
Posted on May 29, 2010
Jahn27
  • 1554 Answers
SOURCE: I need a wiring diagram
Here's the diagram you need.
Posted on Sep 01, 2010
How do I replace the water filter in Amana sbde522vw
Amana Water Filters Refrigerator Water Filters
Scroll down the above page. Instructions are further down. Video is on the left.
Jun 29, 2017 | Amana Refrigerators
Were is the water filter on a amana sxde 526 m does it have one
I looked up your Model with both P#'s. Sadly no water filters for your Refrigerator. Amana only has a few models with water filters.
Sep 04, 2012 | Amana 22.6 cu. ft. Side-By-Side...
How do i reverse the refrigerator door of an amana arb2217csl
you canot reverse the handles on this model. There are no predrilled holes or covering plugs on the opposite side. The model number ends in an "l" signifying left hinges. The companion model ends in an "r" with hinges on the right. These fridges were designed so you could purchase them as a pair seting them side by side.
Oct 09, 2010 | Amana ARB2217CSL Bottom Freezer...
I do not have the manual of my kiched aid superba cooking rangeANd I dont know how to find the model number .Can you please help me in finding the model number of my cooking range so that I can find the...
Usually the model number is on the leg behind your bottom pull-out drawer. If not there, then look where the oven door sets into the oven frame on both sides, or the very bottom where the door hinges. If you have an older unit that has a top that lifts up, then look under the top. Some brands hide their model number behind a oven vent or grill, shine your flashlight through the oven air grills and see if their is a model number plate behind the grill. Finally some units will have the model number removed by the factory if it was a unit returned under a lemon law. These are not supposed to be sold to the public, but we have seen them. In these cases the only way to get some parts is to pull the actual part and see if their is a part number on it. Good Luck, Appliance Specialists
Dec 23, 2009 | Kitchen Ranges
Plastic grid - plastic holders have fallen off. Piece of ****. Is there anyway to replace this? It is the piece under the bottom of the drawer.
is it the grille you are talking about? if so your clips on the grille could be broke or missing. check the grille plate.
Oct 22, 2009 | Amana AFD2535DES French Door Refrigerator
Amana Microwave stays on when I shut the door.
It'll be a bad door switch or a loose door switch mount.
See :
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
William E. Miller
prototech@usa.net
Sep 09, 2009 | Amana Radarange Microwave Oven
Need to replace water filter, can't locate where.
Look down at the grill at the bottom of the frig under the freezer door will be a section of the grill the looks like the grill but has a ring around it twist it counter clock wise and the filter will twist out and the grill front slide off the old filter on to the new filter good luck.
Apr 02, 2009 | Kenmore 57029 Side by Side Refrigerator
Clips missing from grill covering evaporator
you can put your model number in here, and look up the part and order from sears.
http://www.searspartsdirect.com/partsdirect/index.action
Jan 17, 2009 | Amana ABB1927DE Bottom Freezer...
Bottom grill
All of the bottom grills are removable. They snap in very tight and I always worry that Ill break it. They push into a clip on each end. On the Amana they instruct to pull out from the bottom on each side. Suggest looking for user manuel on web for your simular model for specific instructions!
Jan 09, 2009 | Whirlpool GS6NBEXR Side by Side...
Amana BX22RW Freezer Compartment Icing
Ya hit it right on the head. Sounds like a classic "pulling in moisture" problem. See if you can seal that air leak any way you can. That moisture can freeze up air channels and block the refer compartment from getting cool air from the freezer compartment eventually.
Nov 04, 2006 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana SXD524VW Side by Side Refrigerator Logo
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
