Question about GE Televison & Video
My VCR won't turn on. Where can I get it checked?
  • GE Master
  • 6,771 Answers
Take the vcr to your local tv repair shop.
Posted on Dec 30, 2010
VCR won't record, just ejects tape
You have not mentioned the make and model number of the vcr. Any way the problem is due to end sensor or related circuit. End sensors are photo diods which you can check the shorting with a multy meter.
Jan 13, 2013 | Emerson Televison & Video
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
Can't get my vcr off auto. It keeps flashing and vcr won't shut off. Can't get to the menu long enough to see how to shut it off
Try unplugging the VCR for 20 seconds and plugging it back in. It probably will still flash because the clock needs to be reset but you should be able to turn it on and off.
Feb 21, 2012 | Televison & Video
Vcr not working
Hello!
Sorry to admit, but your VCR's signal processor is down. On screen display is generated by microprocessor, but video signal by different circuitry. Anyway, there is nothing you can do, except surrender to repair shop. Or, worst case scenario: buy another one. Even though I won't recommend to do so. "Modern" VCRs are cheap plastic toys, won't last too long, no replacement parts available, etc. If you have some technician's background, you may open the unit and look for "bloated" capacitors in power supply area or check electrolytic capacitors with "in circuit" capacitor checked, if you have one. If not: try to look for reputable repair shop, what stays in business for a while. there, still might be the people, familiar with VCR problems.
good luck with your project,
thanks,
Alex.
Jan 15, 2012 | Panasonic PV-8451 VCR
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
I have a Sony Handycam DCR-HC-48 and the tape door won't close along with a 32.11 error code.....HELP
Try these steps:
1. Open the tape cover fully until it clicks open.
2. Turn the camcorder on to "VCR Mode."
3. With the cover still open and the camera in "VCR mode," take out the battery.
4. Put the battery back in--out should pop your tape.
Keep us updated.
Jun 06, 2011 | Sony Handycam DCR-TRV140E Digital...
The vcr stopped working, tape goes in but won 't work. the dvd stills works.
most likely a mechanical issue , look inside for anything laying inside the VCR section.
a piece of a label or a toy etc. if all looks well it could be a bad sensor , bad (dirty)mode switch
or sinply a jammed gear or arm.
a good way to check the VCR section is to turn the loading motor and see that it moves correctly
hope this helps
Dec 17, 2010 | Emerson EWR20V4 DVD Recorder/VCR
SAFE
Pro-Tect Plus™ Locking Feature
To disable VCR usage or to protect set timer recordings, the unit can be locked so that the
buttons on the VCR or remote control don’t work.
• To Lock: Press and hold either the remote control’s ON•OFF or VCR button until SAFE
appears in the display to indicate Pro-Tect Plus is active. SAFE also appears if the VCR is
turned on while the feature is activated.
To Unlock: Press and hold either the remote control’s ON•OFF or VCR button until SAFE
disappears from the front panel display. Unlocking is the only way to use the VCR.
May 10, 2008 | Televison & Video
Won 't stay on
Contact Insignia if it is still under warranty and get it checked out. I had a problem with another version of insignia and it was not able to be repaired or replaced so they gave me a complete refund.
Jan 11, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Televison & Video Logo
83 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
